imx6 duallite configuration file
1,308 次查看
shankovai
Hello support team,
Kindly refer the attached snapshot machine.png from the folder meta-freescale
configuration file for imx6dlsabresd is not available in the meta-freescale. why the conf file is not included?
  Can i use  imx6qdlsabresd.conf for imx6dl?
kindly give your suggestion
thank you
1,296 次查看
shankovai
n the meta-imx layer, i.MX provides new or updated machine configurations that overlay the meta-freescale machine
configurations. These files are copied into the meta-freescale/conf/machine directory by the imx-setup-release.sh script.
then for the machine setup do i need to refer meta-imx/meta-bsp/conf/machine.
please confirm
