imx6 compile error
imx6 compile error
1,403件の閲覧回数
tomgao
bitbake any image ,it will bring up the next error :
ERROR: ParseError at /home/zhq/workspace/imx6/fsl-arm-yocto-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-bsp/firmware-imx/firmware-imx_5.4.bb:3: Could not include required file recipes-bsp/firmware-imx/firmware-imx.inc
best regards!
1,276件の閲覧回数
gusarambula
Hello Tom Gao,
Are you still having issues baking images? Would you please provide more information on your Host and the BSP you are using? Also, did you installed all the packages required by the host?
