imx6 compile error
imx6 compile error
1,406 次查看
tomgao
bitbake any image ,it will bring up the next error :
ERROR: ParseError at /home/zhq/workspace/imx6/fsl-arm-yocto-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-bsp/firmware-imx/firmware-imx_5.4.bb:3: Could not include required file recipes-bsp/firmware-imx/firmware-imx.inc
best regards!
1,279 次查看
gusarambula
Hello Tom Gao,
Are you still having issues baking images? Would you please provide more information on your Host and the BSP you are using? Also, did you installed all the packages required by the host?
