[imx6] can i write a value to ocopt on c code?
1,307 次查看
myungjinhwang
dear nxp team.
i know we can write otp values to ocotp, with mfg tool, linux(echo 0x10000000 > /sys/fsl_otp/HW_OCOTP_CFG5), uboot commands(fuse prog 0 0 0x00000001) .
question.
i need to write a value to OCOTP_CFG5 register.
could i write opt values on the c code?
best regards
MyungJin
1,113 次查看
Hi MyungJin
one can look at attached sdk example, also please check Chapter 25
Configuring the OCOTP Driver pdf document.
