imx6 android 4.4 volume control
weikeng-jimmy
We are using iMX6 running with Android 4.4. (Android 4.3 same as Android 4.4)
When we adjust the audio volume of HDMI output from Android Setting,  audio volume does not change.
Labels (2)
boris-benshapir
Hi. Jimmy. Did you manage to solve the issue.. i am having the same issue as yours.. Board imx6dq
Please help :smileyhappy:
SergioSolis
Hello Jimmy,
Which board are you using?, are you pressing the volume buttons in the board?, which board version do you have?
