imx6 android 4.4 volume control
1,977件の閲覧回数
weikeng-jimmy
We are using iMX6 running with Android 4.4. (Android 4.3 same as Android 4.4)
When we adjust the audio volume of HDMI output from Android Setting,  audio volume does not change.
ラベル(2)
2 返答(返信)
1,501件の閲覧回数
boris-benshapir
Hi. Jimmy. Did you manage to solve the issue.. i am having the same issue as yours.. Board imx6dq
Please help :smileyhappy:
1,501件の閲覧回数
SergioSolis
Hello Jimmy,
Which board are you using?, are you pressing the volume buttons in the board?, which board version do you have?
