imx6 android 4.4 volume control
1,981 次查看
weikeng-jimmy
We are using iMX6 running with Android 4.4. (Android 4.3 same as Android 4.4)
When we adjust the audio volume of HDMI output from Android Setting,  audio volume does not change.
标签 (2)
1,505 次查看
boris-benshapir
Hi. Jimmy. Did you manage to solve the issue.. i am having the same issue as yours.. Board imx6dq
Please help :smileyhappy:
1,505 次查看
SergioSolis
Hello Jimmy,
Which board are you using?, are you pressing the volume buttons in the board?, which board version do you have?
