imx35 ltib error
imx35 ltib error
1,240 次查看
steven_zhang
Contributor V
i tried to compile the i.mx35 SDK  on my ubuntu 9.04 with kernel 2.6.31..14 got belows
:rpm  build errors:
bad  exit status  from /home/steven/ltib/tmp/rpm-tmp.64356(%build)
see details in the attachment.
标记 (3)
1,141 次查看
gusarambula
Would you please confirm if you’re using SDK Source 2.6.31_09.12.01 (link below)? This is the latest official release from Freescale.
https://www.freescale.com/webapp/Download?colCode=L2.6.31_09.12.01_SDK_SOURCE&appType=license&locati...
I would check if your host does have all the packages required and since the error appeared when building pot I would recommend double checking that the popt files are available. These should be part of the SDK source package (L2.6.31_09.12.01_SDK_source\pkgs\ popt-1.7.tar.gz)
