imx25 OTG(device) ISOC multi-transaction issue
tomfang
Hi guys:
I have a project using imx25 and a sensor to make a webcam,
using imx25 OTG device function to connect a host, video data transfered in ISOC endpoint,
software is your linux-2.6.31 SDK, now all functions are ok, but there is a problem:
if I configure this endpoint worked in "1 transaction", video data can be transfered, but the frame rate is only around 10,
for improving frame rate, I try to configure the endpoint worked in "3 transactions", but there isn't any data in USB line.
how can i do to make the "3 transactions" work?
I attached some pictures from USB analysis:
<<one transaction.PNG>>: configure imx25 ISOC endpoint worked in "1 transaction".
<<three transaction.PNG>>: configure imx25 ISOC endpoint worked in "3 transaction".
<<one transaction microsoft.PNG>>: microsoft webcam worked in "1 transaction".
<<isoc register>>: "1 transaction" and "3 transactions" configuration table from imx25 data sheet.
waiting for your response from heart.
Labels (2)
karina_valencia
NXP Apps Support
NXP Apps Support
Ning ChenEmployee
What's the resolution for your camera? ususally, it is not reasonable you only get 10 frame/sec for 1 transaction.
If you want to support high bandiwdith for ISOC, please refer below patch:
https://git.kernel.org/cgit/linux/kernel/git/next/linux-next.git/commit/?id=2fc5a7dace3c43e62402ab4e...
jamesbone
We are doing some research with our team, to provide an answer.
karina_valencia
NXP Apps Support
NXP Apps Support
Ning ChenEmployee
