imx-yocto-bsp revision control
1,000件の閲覧回数
razriel
NXP provides a bsp based on yocto.
I have downloaded the bsp and did modifications. some of the modifications are in customized layer I have created.
some of the modification are in the source files of the recipes in other layers.
Is there any common practice how to do revision control of the meta-layers provided in the bsp in our own remote repository.
I dont want to invent the wheel. can someone direct me to a good documentation that suggest options how to do the revision control.
983件の閲覧回数
Chavira
Hi @razriel !
Thank you for contacting NXP Support!
NXP doesn't have documentation about that, but for the control version, you can use git.
If you intend to do long-term support for your product, I recommend using a Docker Yocto builder container, with Docker Yocto builder you can build your images with the same Yocto Project over several years.
I think is possible to use Docker Yocto builder and git to have better revision control, but I am not sure.
Please read the git and Docker documentation.
Git - Documentation (git-scm.com)
Docker overview | Docker Documentation
