imx-automotive-14.0.0_2.3.0 build issue
2,154件の閲覧回数
VarunK1
I am trying to build "imx-automotive-14.0.0_2.3.0" in ubuntu 22.04 desktop. when I initiated the android build (I ran this command " ./imx-make.sh -j4 2>&1 | tee build-log.txt "). The build is started, ran for few minutes and terminated. I am attaching build-log.txt file for your reference. Kindly, help me with this issue. Thank you in advance
5 返答(返信)
2,138件の閲覧回数
Zhiming_Liu
Hi @VarunK1
Please install necessary host packages referring the user guide.
Zhiming
2,092件の閲覧回数
VarunK1
I have installed necessary packages and initiated build. After that, I got an error saying "libbpf: BTF header not found
pahole: .tmp_vmlinux.btf: Invalid argument
LD .tmp_vmlinux.kallsyms1
NM .tmp_vmlinux.kallsyms1.syms
KSYMS .tmp_vmlinux.kallsyms1.S
AS .tmp_vmlinux.kallsyms1.S
LD .tmp_vmlinux.kallsyms2
NM .tmp_vmlinux.kallsyms2.syms
KSYMS .tmp_vmlinux.kallsyms2.S
AS .tmp_vmlinux.kallsyms2.S
LD vmlinux
BTFIDS vmlinux
FAILED: load BTF from vmlinux: Invalid argument
make[4]: *** [/home/sdv/Music/android_build/vendor/nxp-opensource/kernel_imx/scripts/Makefile.vmlinux:37: vmlinux] Error 255
make[4]: *** Deleting file 'vmlinux'
make[3]: *** [/home/sdv/Music/android_build/vendor/nxp-opensource/kernel_imx/Makefile:1237: vmlinux] Error 2
make[2]: *** [/home/sdv/Music/android_build/vendor/nxp-opensource/kernel_imx/Makefile:252: __sub-make] Error 2
make[2]: Leaving directory '/home/sdv/Music/android_build/out/target/product/mek_8q/obj/KERNEL_OBJ'
make[1]: *** [Makefile:252: __sub-make] Error 2
make[1]: Leaving directory '/home/sdv/Music/android_build/vendor/nxp-opensource/kernel_imx'
make: *** [/home/sdv/Music/android_build/device/nxp/common/build/kernel.mk:197: /home/sdv/Music/android_build/out/target/product/mek_8q/obj/KERNEL_OBJ/arch/arm64/boot/Image.lz4] Error 2
make: Leaving directory '/home/sdv/Music/android_build'". So, I have unchecked the Generate BTF typeinfo option.
I have initiated a fresh build again but build ran for few minutes and stopped. I am attaching the build-log file for reference. Kindly, help me with this issue. Thanks in advance.
2,086件の閲覧回数
Zhiming_Liu
As it is saying need libbpf header, you need install libbpf-dev.
Zhiming
2,074件の閲覧回数
VarunK1
I have installed libbpf-dev but still facing issue while building. I am attaching build-log file. Kindly, help me resolve this issue.
Other changes I have done
1) In this path /home/sdv/Music/imx-automotive-14.0.0_2.3.0/android_build/vendor/nxp-opensource/kernel_imx/scripts/
inside file link-vmlinux.sh, commented below piece of code.
#if ! [ -x "$(command -v ${PAHOLE})" ]; then
# echo >&2 "BTF: ${1}: pahole (${PAHOLE}) is not available"
# return 1
#fi
2) In this path,/home/sdv/Music/imx-automotive-14.0.0_2.3.0/android_build/out/target/product/mek_8q/obj/KERNEL_OBJ/
Inside .config file,
changed CONFIG_DEBUG_INFO_BTF=y to # CONFIG_DEBUG_INFO_BTF is not set
changed CONFIG_DEBUG_INFO_DWARF5=y to # CONFIG_DEBUG_INFO_DWARF5 is not set
2,028件の閲覧回数
joanxie
could you build android 14 successfully if you don't change anything? suggest you to build the android 14 without any modification, to improve your building environment is fine at least
%3CLINGO-SUB%20id%3D%22lingo-sub-2137998%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx-%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96-14.0.0_2.3.0%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137998%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EUbuntu%2022.04%20%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%A7%E3%80%8C%20%3CSTRONG%3Eimx-%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96-14.0.0_2.3.0%3C%2FSTRONG%3E%20%E3%80%8D%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Android%20%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%20(%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%80%8C%20.%2Fimx-make.sh%20-j4%202%26gt%3B%26amp%3B1%20%7C%20tee%20build-log.txt%20%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F)%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%80%81%E6%95%B0%E5%88%86%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%ABbuild-log.txt%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%81%86%E3%81%9E%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2145902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx-automotive-14.0.0_2.3.0%20build%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2145902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%95%E3%82%82%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81Android%2014%20%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3FAndroid%2014%E3%82%92%E6%94%B9%E9%80%A0%E3%81%9B%E3%81%9A%E3%81%AB%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E7%92%B0%E5%A2%83%E3%82%92%E6%94%B9%E5%96%84%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx-automotive-14.0.0_2.3.0%20build%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CSTRONG%3Elibbpf-dev%3C%2FSTRONG%3E%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E4%B8%AD%E3%81%AB%E3%81%BE%E3%81%A0%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B1%BA%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%8C%E8%A1%8C%E3%81%A3%E3%81%9F%E4%BB%96%E3%81%AE%E5%A4%89%E6%9B%B4%3CBR%20%2F%3E1)%20%E3%81%93%E3%81%AE%E3%83%91%E3%82%B9%20%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fsdv%2FMusic%2Fimx-%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96-14.0.0_2.3.0%2Fandroid_build%2Fvendor%2Fnxp-opensource%2Fkernel_imx%2Fscripts%2F%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CSTRONG%3Elink-vmlinux.sh%3C%2FSTRONG%3E%E5%86%85%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CDIV%3E%EF%BC%83%E3%82%82%E3%81%97%20%EF%BC%81%5B%20-x%20%22%24(%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20-v%20%24%7BPAHOLE%7D%20)%22%20%5D%3B%20%E3%81%9D%E3%81%AE%E5%BE%8C%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23%20echo%20%26gt%3B%26amp%3B2%20%22BTF%3A%20%24%7B1%7D%20%3A%20pahole%20(%20%24%7BPAHOLE%7D%20)%20%E3%81%AF%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23%201%20%E3%82%92%E8%BF%94%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23fi%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%202)%20%E3%81%93%E3%81%AE%E3%83%91%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fsdv%2FMusic%2Fimx-%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96-14.0.0_2.3.0%2Fandroid_build%2Fout%2Ftarget%2F%E8%A3%BD%E5%93%81%2Fmek_8q%2Fobj%2FKERNEL_OBJ%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E.config%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSTRONG%3E%E5%86%85%E3%81%A7%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CSTRONG%3ECONFIG_DEBUG_INFO_BTF%3Dy%3C%2FSTRONG%3E%E3%82%92%3CSTRONG%3E%23%20CONFIG_DEBUG_INFO_BTF%20%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FSTRONG%3E%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CSTRONG%3ECONFIG_DEBUG_INFO_DWARF5%3Dy%3C%2FSTRONG%3E%E3%82%92%3CSTRONG%3E%23%20CONFIG_DEBUG_INFO_DWARF5%20%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2143051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx-automotive-14.0.0_2.3.0%20build%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143051%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%20libbpf%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81libbpf-dev%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2142710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx-automotive-14.0.0_2.3.0%20build%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%80%8Clibbpf%3A%20BTF%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%91%E3%83%9B%E3%83%BC%E3%83%AB%3A%20.tmp_vmlinux.btf%3A%E7%84%A1%E5%8A%B9%E3%81%AA%E5%BC%95%E6%95%B0%3CBR%20%2F%3ELD%20.tmp_vmlinux.kallsyms1%3CBR%20%2F%3ENM%20.tmp_vmlinux.kallsyms1.syms%3CBR%20%2F%3EKSYMS%20.tmp_vmlinux.kallsyms1.S%3CBR%20%2F%3E%20AS%20.tmp_vmlinux.kallsyms1.S%3CBR%20%2F%3E%20LD%20.tmp_vmlinux.kallsyms2%3CBR%20%2F%3ENM%20.tmp_vmlinux.kallsyms2.syms%3CBR%20%2F%3EKSYMS%20.tmp_vmlinux.kallsyms2.S%3CBR%20%2F%3E%20AS%20.tmp_vmlinux.kallsyms2.S%3CBR%20%2F%3E%20LD%20vmlinux%3CBR%20%2F%3E%20BTFIDS%20vmlinux%3CBR%20%2F%3E%E5%A4%B1%E6%95%97%3A%20vmlinux%20%E3%81%8B%E3%82%89%20BTF%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%3A%20%E7%84%A1%E5%8A%B9%E3%81%AA%E5%BC%95%E6%95%B0%3CBR%20%2F%3Emake%5B4%5D%3A%20***%20%5B%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fsdv%2FMusic%2Fandroid_build%2Fvendor%2Fnxp-opensource%2Fkernel_imx%2Fscripts%2FMakefile.vmlinux%3A37%3Avmlinux%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%20255%3CBR%20%2F%3E%20make%5B4%5D%3A%20***%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20'vmlinux'%20%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Emake%5B3%5D%3A%20***%20%5B%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fsdv%2FMusic%2Fandroid_build%2Fvendor%2Fnxp-opensource%2Fkernel_imx%2FMakefile%3A1237%3A%20vmlinux%5D%20%E3%82%A8%E3%83%A9%E3%83%BC2%3CBR%20%2F%3E%20make%5B2%5D%3A%20***%20%5B%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fsdv%2FMusic%2Fandroid_build%2Fvendor%2Fnxp-opensource%2Fkernel_imx%2FMakefile%3A252%3A%20__sub-make%5D%20%E3%82%A8%E3%83%A9%E3%83%BC2%3CBR%20%2F%3E%20make%5B2%5D%3A%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fsdv%2FMusic%2Fandroid_build%2Fout%2Ftarget%2F%E8%A3%BD%E5%93%81%2Fmek_8q%2Fobj%2FKERNEL_OBJ'%20%E3%81%8B%E3%82%89%E5%87%BA%E3%81%BE%E3%81%99%3CBR%20%2F%3Emake%5B1%5D%3A%20***%20%5BMakefile%3A252%3A%20__sub-make%5D%20%E3%82%A8%E3%83%A9%E3%83%BC2%3CBR%20%2F%3E%20make%5B1%5D%3A%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fsdv%2FMusic%2Fandroid_build%2Fvendor%2Fnxp-opensource%2Fkernel_imx'%20%E3%81%8B%E3%82%89%E5%87%BA%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%A1%E3%82%A4%E3%82%AF%3A%20***%20%5B%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fsdv%2FMusic%2Fandroid_build%2Fdevice%2Fnxp%2Fcommon%2Fbuild%2Fkernel.mk%3A197%3A%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fsdv%2FMusic%2Fandroid_build%2Fout%2Ftarget%2F%E8%A3%BD%E5%93%81%2Fmek_8q%2Fobj%2FKERNEL_OBJ%2Farch%2Farm64%2Fboot%2FImage.lz4%5D%E3%82%A8%E3%83%A9%E3%83%BC2%3CBR%20%2F%3E%20make%3A%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%20'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Fsdv%2FMusic%2Fandroid_build'%20%E3%81%8B%E3%82%89%E5%87%BA%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%81%20%3CSTRONG%3EBTF%20typeinfo%20%E3%81%AE%E7%94%9F%E6%88%90%3C%2FSTRONG%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%92%E5%A4%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%86%8D%E5%BA%A6%E6%96%B0%E8%A6%8F%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E6%95%B0%E5%88%86%E9%96%93%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%80%81%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%81%86%E3%81%9E%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%89%8D%E3%82%82%E3%81%A3%E3%81%A6%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx-automotive-14.0.0_2.3.0%20build%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F249224%22%20target%3D%22_blank%22%3E%40VarunK1%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%9B%E3%82%B9%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Zhiming_Liu_0-1753231653984.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Zhiming_Liu_0-1753231653984.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348919i0F2E27620D02ABF9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Zhiming_Liu_0-1753231653984.png%22%20alt%3D%22Zhiming_Liu_0-1753231653984.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E
