OPERATION_MODE of DDRC_STAT remains at Init and does not become Normal on i.MX7D
ソリューションへジャンプ
932件の閲覧回数
tamotsu
Contributor V
Hi.
It uses DDR3L.
I used the configuration file "MX7D_DDR3_register_programming_aid_v1_2.xlsx" and "/mx7dsabresd/imximage.cfg" in u-boot as references.
At the end of the setup, I read DDRC_STAT, but OPERATING_MODE remains Init.
How do I get to Normal mode?
I think this mode probably doesn't become Normal, so reading 0x80000000 causes the computer to freeze.
Best regards.
909件の閲覧回数
patterson123
The user wants a short paragraph summarizing the detailed response about their DDR initialization issue.
I need to extract the key points from the previous response:
* **The Problem:** The DDR controller's `OPERATING_MODE` is stuck in `Init` mode, meaning memory initialization failed.
* **The Cause:** This usually happens due to an incomplete initialization sequence or incorrect register values.
* **The Solution:** The user must ensure their code correctly initiates the training sequence by setting the `DDRC_MSTR` register. They should then poll the `DDRC_STAT` register, waiting for the `OPERATING_MODE` to transition to `Normal`. Double-checking the register values from the programming aid is also a critical step.
I'll combine these points into a single, concise paragraph.
Your DDR controller's `OPERATING_MODE` is stuck in `Init` because the memory initialization sequence has failed to complete. This is most often caused by an incomplete code sequence or incorrect register values. To fix it, ensure your code correctly initiates the memory training by writing the appropriate value to the `DDRC_MSTR` register. You must then poll the `DDRC_STAT` register, waiting for the `OPERATING_MODE` to transition to `Normal`, which signals a successful initialization. Double-checking your timing and calibration register values against the provided programming aid is also a critical step.
4 返答(返信)
910件の閲覧回数
patterson123
893件の閲覧回数
tamotsu
Contributor V
Hi patterson123.
I appreciate the specific advice.
I'll try again following your advice and will get back to you with the results.
Best regards.
914件の閲覧回数
pengyong_zhang
Hi @tamotsu
What changes did you make to the code?and How do you read the register value?
B.R
890件の閲覧回数
tamotsu
Contributor V
Hi Pengyong_zhang.
Thanks.
First, since I was using the same Micron DDR3, I wrote the code according to the "i.MX7D DDR Controller Configuration Spreadsheet."
However, I was unable to access the DDR. At the time, I was unaware that initialization had not yet finished.
Next, I found the SABRE board settings in u-boot, changed it to this code and tried it.
However, this was also not accessible. I confirmed that initialization had not yet finished.
Below is the write code.
DDRC_MSTR : 0x01040001
DDRC_DFIUUPD0: 0x80400003
DDRC_DFIUUPD1: 0x00100020
DDRC_DFIUUPD2: 0x80400004
DDRC_RFSHTMG: 0x00400046
DDRC_MP_PCTRL_0: 0x00000001
DDRC_INIT0: 0x00020083
DDRC_INIT1: 0x00690000
DDRC_INIT3: 0x09300004
DDRC_INIT2: 0x00000000
DDRC_INIT4: 0x04080000
DDRC_INIT5: 0x00200004
DDRC_RANKCTL: 0x0000033F
DDRC_DRAMTMG0: 0x09081109
DDRC_DRAMTMG1: 0x0007020D
DDRC_DRAMTMG2: 0x03040407
DDRC_DRAMTMG3: 0x00002006
DDRC_DRAMTMG4: 0x04020205
DDRC_DRAMTMG5: 0x03030202
DDRC_DRAMTMG8: 0x00000803
DDRC_ZQCTL0: 0x00800020
DDRC_ZQCTL1: 0x02000100
DDRC_DFITMG0: 0x02098204
DDRC_DFITMG1: 0x00030303
DDRC_ADDRMAP0: 0x0000001F
DDRC_ADDRMAP1: 0x00080808
DDRC_ADDRMAP5: 0x04040404
DDRC_ADDRMAP6: 0x0F040404
DDRC_ODTCFG: 0x06000604
DDRC_ODTMAP: 0x00000001
SRC_DDRC_RCR: 0x00000000
I read DDRC_STAT here, but it was not set to Normal.
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2144898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX7D%E3%81%A7%E3%81%AFDDRC_STAT%E3%81%AEOPERATION_MODE%E3%81%8CInit%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3EDDR3L%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eu-boot%E5%86%85%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8CMX7D_DDR3_register_programming_aid_v1_2.xlsx%E3%80%8D%E3%81%A8%E3%80%8C%2Fmx7dsabresd%2Fimximage.cfg%E3%80%8D%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81DDRC_STAT%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81OPERATING_MODE%20%E3%81%AF%20Init%20%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%80%9A%E5%B8%B8%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E3%80%81SO%200x80000000%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%A8%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%99%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2145710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20OPERATION_MODE%20of%20DDRC_STAT%20remains%20at%20Init%20and%20does%20not%20become%20Normal%20on%20i.MX7D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2145710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Pengyong_zhang%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%BE%E3%81%9A%E3%80%81%E5%90%8C%E3%81%98Micron%20DDR3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%80%8Ci.MX7D%20DDR%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E6%A7%8B%E6%88%90%E3%82%B9%E3%83%97%E3%83%AC%E3%83%83%E3%83%89%E3%82%B7%E3%83%BC%E3%83%88%E3%80%8D%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81DDR%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%81%9D%E3%81%AE%E6%99%82%E3%81%AF%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%8C%E3%81%BE%E3%81%A0%E7%B5%82%E3%82%8F%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%AC%A1%E3%81%AB%E3%80%81u-boot%20%E3%81%A7%20SABRE%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E6%8E%A2%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%82%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%8C%E3%81%BE%E3%81%A0%E7%B5%82%E3%82%8F%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EDDRC_MSTR%20%3A%200x01040001%3C%2FP%3E%3CP%3EDDRC_DFIUUPD0%3A%200x80400003%3C%2FP%3E%3CP%3EDDRC_DFIUUPD1%3A%200x00100020%3C%2FP%3E%3CP%3EDDRC_DFIUUPD2%3A%200x80400004%3C%2FP%3E%3CP%3EDDRC_RFSHTMG%3A%200x00400046%3C%2FP%3E%3CP%3EDDRC_MP_PCTRL_0%3A%200x00000001%3C%2FP%3E%3CP%3EDDRC_INIT0%3A%200x00020083%3C%2FP%3E%3CP%3EDDRC_INIT1%3A%200x00690000%3C%2FP%3E%3CP%3EDDRC_INIT3%3A%200x09300004%3C%2FP%3E%3CP%3EDDRC_INIT2%3A%200x00000000%3C%2FP%3E%3CP%3EDDRC_INIT4%3A%200x04080000%3C%2FP%3E%3CP%3EDDRC_INIT5%3A%200x00200004%3C%2FP%3E%3CP%3EDDRC_RANKCTL%3A%200x0000033F%3C%2FP%3E%3CP%3EDDRC_DRAMTMG0%3A%200x09081109%3C%2FP%3E%3CP%3EDDRC_DRAMTMG1%3A%200x0007020D%3C%2FP%3E%3CP%3EDDRC_DRAMTMG2%3A%200x03040407%3C%2FP%3E%3CP%3EDDRC_DRAMTMG3%3A%200x00002006%3C%2FP%3E%3CP%3EDDRC_DRAMTMG4%3A%200x04020205%3C%2FP%3E%3CP%3EDDRC_DRAMTMG5%3A%200x03030202%3C%2FP%3E%3CP%3EDDRC_DRAMTMG8%3A%200x00000803%3C%2FP%3E%3CP%3EDDRC_ZQCTL0%3A%200x00800020%3C%2FP%3E%3CP%3EDDRC_ZQCTL1%3A%200x02000100%3C%2FP%3E%3CP%3EDDRC_DFITMG0%3A%200x02098204%3C%2FP%3E%3CP%3EDDRC_DFITMG1%3A%200x00030303%3C%2FP%3E%3CP%3EDDRC_ADDRMAP0%3A%200x0000001F%3C%2FP%3E%3CP%3EDDRC_ADDRMAP1%3A%200x00080808%3C%2FP%3E%3CP%3EDDRC_ADDRMAP5%3A%200x04040404%3C%2FP%3E%3CP%3EDDRC_ADDRMAP6%3A%200x0F040404%3C%2FP%3E%3CP%3EDDRC_ODTCFG%3A%200x06000604%3C%2FP%3E%3CP%3EDDRC_ODTMAP%3A%200x00000001%3C%2FP%3E%3CP%3ESRC_DDRC_RCR%3A%200x00000000%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%93%E3%81%A7DDRC_STAT%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81Normal%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2145697%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20OPERATION_MODE%20of%20DDRC_STAT%20remains%20at%20Init%20and%20does%20not%20become%20Normal%20on%20i.MX7D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2145697%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81patterson123%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AA%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E9%A0%82%E3%81%8D%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%80%81%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2145102%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20OPERATION_MODE%20of%20DDRC_STAT%20remains%20at%20Init%20and%20does%20not%20become%20Normal%20on%20i.MX7D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2145102%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF%E3%80%81DDR%20%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A9%B3%E7%B4%B0%E3%81%AA%E5%9B%9E%E7%AD%94%E3%82%92%E8%A6%81%E7%B4%84%E3%81%97%E3%81%9F%E7%9F%AD%E3%81%84%E6%AE%B5%E8%90%BD%E3%82%92%E5%B8%8C%E6%9C%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%89%8D%E5%9B%9E%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%8B%E3%82%89%E9%87%8D%E8%A6%81%E3%81%AA%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E6%8A%9C%E7%B2%8B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20*%20**%E5%95%8F%E9%A1%8C%3A**%20DDR%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%20%60OPERATING_MODE%60%20%E3%81%8C%20%60Init%60%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20**%E5%8E%9F%E5%9B%A0%3A**%20%E3%81%93%E3%82%8C%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%8C%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%80%A4%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20**%E8%A7%A3%E6%B1%BA%E7%AD%96%3A**%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF%E3%80%81%60DDRC_MSTR%60%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%20%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%60DDRC_STAT%60%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%80%81%60OPERATING_MODE%60%20%E3%81%8C%20%60Normal%60%20%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E8%A3%9C%E5%8A%A9%E3%81%8B%E3%82%89%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%80%A4%E3%82%92%E4%BA%8C%E9%87%8D%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E9%87%8D%E8%A6%81%E3%81%AA%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E7%82%B9%E3%82%92%201%20%E3%81%A4%E3%81%AE%E7%B0%A1%E6%BD%94%E3%81%AA%E6%AE%B5%E8%90%BD%E3%81%AB%E3%81%BE%E3%81%A8%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81DDR%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%20%60OPERATING_MODE%60%20%E3%81%8C%20%60Init%60%20%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%B3%E3%83%BC%E3%83%89%20%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%8D%E6%AD%A3%E3%81%AA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%80%A4%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%60DDRC_MSTR%60%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E9%81%A9%E5%88%87%E3%81%AA%E5%80%A4%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%60DDRC_STAT%60%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%80%81%60OPERATING_MODE%60%20%E3%81%8C%20%60Normal%60%20%E3%81%AB%E9%81%B7%E7%A7%BB%E3%81%97%E3%81%A6%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%81%BE%E3%81%A7%E5%BE%85%E6%A9%9F%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E8%A3%9C%E5%8A%A9%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A8%E7%85%A7%E3%82%89%E3%81%97%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E5%80%A4%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E9%87%8D%E8%A6%81%E3%81%AA%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2145008%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20OPERATION_MODE%20of%20DDRC_STAT%20remains%20at%20Init%20and%20does%20not%20become%20Normal%20on%20i.MX7D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2145008%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203270%22%20target%3D%22_blank%22%3E%40tamotsu%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%80%A4%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%3C%2FLINGO-BODY%3E
