icmp sequence number
2,024 次查看
sandeep_c
iam developing driver for ksz8851snli using lwip stack + ksz8851(spi to etehrnet and vice versa)
arp protocol is working fine
when i received an icmp reply ping id is matching but ping sequence is not matching what might be the solution for this
5 回复数
2,012 次查看
Sanket_Parekh
Hello @sandeep_c ,
I hope you are doing well.
Please kindly share the below things to debug the issue.
-which evk are you using?
-which linux kernel version are you using?
-Kindly share the console logs as well as dmesg logs.
-Kindly share the environment details.
Thanks & Regards,
Sanket Parekh
2,005 次查看
sandeep_c
IDE DETAILS:
i.MX RT1170 First GHz Crossover MCU with Arm® Cortex®-M7 and Cortex-M4 Cores
MCUXpresso IDE v11.6.0 [Build 8187] [2022-07-13]
problem:
iam trying ping between pc to mc and vice versa during this time i will get all for responses and sometimes i will loss 3 or 2 or 1 packets or all packets please refer the document .
i havent found at what frequency clock will generated by the laptop (pc) for request or reply
what are the procedure or how can i solve this issue i need some insight from the community.
my processor clock configured as 500khz
Microsoft Windows [Version 10.0.19045.2728]
(c) Microsoft Corporation. All rights reserved.
C:\Users\admin>ping 192.168.0.102
Pinging 192.168.0.102 with 32 bytes of data:
Reply from 192.168.0.100: Destination host unreachable.
Ping statistics for 192.168.0.102:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=1746ms TTL=255
Request timed out.
Approximate round trip times in milli-seconds:
Minimum = 1746ms, Maximum = 1746ms, Average = 1746ms
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=2574ms TTL=255
Minimum = 2574ms, Maximum = 2574ms, Average = 2574ms
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=2773ms TTL=255
Request timed out.
Request timed out.
Minimum = 2773ms, Maximum = 2773ms, Average = 2773ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
General failure.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=2039ms TTL=255
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=2056ms TTL=255
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 2039ms, Maximum = 2056ms, Average = 2047ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=919ms TTL=255
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=1229ms TTL=255
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=1783ms TTL=255
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=3489ms TTL=255
Minimum = 919ms, Maximum = 3489ms, Average = 1855ms
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=869ms TTL=255
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=1410ms TTL=255
Minimum = 869ms, Maximum = 1410ms, Average = 1139ms
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=2085ms TTL=255
Minimum = 2085ms, Maximum = 2085ms, Average = 2085ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=1253ms TTL=255
Request timed out.
Request timed out.
Request timed out.
Minimum = 1253ms, Maximum = 1253ms, Average = 1253ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=811ms TTL=255
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=1160ms TTL=255
Request timed out.
Request timed out.
Minimum = 811ms, Maximum = 1160ms, Average = 985ms
Request timed out.
Reply from 192.168.0.102: bytes=32 - MISCOMPARE at offset 30 - time=3658ms TTL=255
Request timed out.
Request timed out.
Minimum = 3658ms, Maximum = 3658ms, Average = 3658ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
thank you
2,005 次查看
sandeep_c
hi everyone iam developing the driver for ksz 8851snli by using lwip stack which spi to ethernet and vice versa
IDE DETAILS:
problem:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
General failure.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
thank you
1,940 次查看
jingpan
Hi @sandeep_c ,
You can try to print lwip debug message, such as ARP information and IP information. The information print switch are in opt.h.
Jing
1,928 次查看
sandeep_c
done succesfullyksz8851_fifo_read
ksz8851_reg_clrbits= RX step21:end RXQ read access
ksz8851_reg_read ksz8851_reg_setbits
ksz8851_reg_write ksz8851_reg_setbits
step22-23
ksz8851snl_low_level_inputksz8851snl_low_level_input: DMA buffer 0x20008BCC received, size=110 [tail=1 head=0]
ksz8851snl_rx_populate_queuepbuf_alloc(length=1516)
pbuf_alloc(length=1516) == 200091B8
ksz8851snl_rx_populate_queue: new pbuf allocated with size 1516: 0x200091B8 [pos=1]
after ksz8851snl_low_level_input
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 cd 0 0 80 11 6f c c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 7d bb 66 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 43 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64
IAM PRINTING IN ethernet_input FUN
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 cd 0 0 80 11 6f c c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 7d bb 66 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 43 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:fc:3f:db:fb:58:8b, type:800
ETHTYPE_IP
pbuf_remove_header: old 20008BCC new 20008BDA (14)
pass to IP layer ip4_input
IAM PRINTING RECIEVED PAYLOAD ip4_input
45 0 0 60 48 cd 0 0 80 11 6f c c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 7d bb 66 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 43 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 1
2
3
test-4
test-5
ip_input: iphdr->dest 0xff00a8c0 netif->ip_addr 0x6600a8c0 (0xa8c0, 0xa8c0, 0xff000000)
ip4_input: packet accepted on interface en
test-6
test-7
test-8
test-9
/* send to upper layers */
ip4_input:
IP header:
| 4 | 5 | 0x00 | 96 | (v, hl, tos, len)
| 18637 |000| 0 | (id, flags, offset)
| 128 | 17 | 0x6f0c | (ttl, proto, chksum)
| 192 | 168 | 0 | 100 | (src)
| 192 | 168 | 0 | 255 | (dest)
ip4_input: p->len 96 p->tot_len 96
test-10
raw_input
IAM PRINTING RECIEVED PAYLOAD in raw_input fun
1
count= 2 drop the packet
3
pbuf_remove_header: old 20008BDA new 20008BEE (20)
test-11
udp_input: received datagram of length 76
UDP header:
| 137 | 137 | (src port, dest port)
| 76 | 0xc77d | (len, chksum)
udp (
192.168.0.255
, 137) <-- (
192.168.0.100
, 137)
pbuf_free(20008BBC)
pbuf_free: deallocating 20008BBC
sct calling h=dhcp_fine_tmr t=439 arg=3002139C
tcpip: dhcp_fine_tmr()
sys_timeout: 20006684 abs_time=10834 handler=dhcp_fine_tmr arg=3002139C
sct calling h=ip_reass_tmr t=441 arg=30021378
tcpip: ip_reass_tmr()
sys_timeout: 200066C0 abs_time=11345 handler=ip_reass_tmr arg=30021378
sct calling h=etharp_tmr t=438 arg=30021384
tcpip: etharp_tmr()
etharp_timer
sys_timeout: 200066AC abs_time=11360 handler=etharp_tmr arg=30021384
sct calling h=acd_tmr t=409 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=10917 handler=acd_tmr arg=300213A8
sct calling h=ping_timeout t=322 arg=20005A88
ping: send
192.168.0.100
pbuf_alloc(length=40)
pbuf_alloc(length=40) == 200002C4
IAM PREPARING ping_prepare_echo static seq num=6 lwip_htons(++ping_seq_num) =1536
IAM PREPARING ping_prepare_echo static seq num=6 lwip_htons(++ping_seq_num) =1536raw_sendto
netif_is_up=1netif_is_link_up=1,ip4_addr_isany_val
FORWADING IP PACKETS for IP ADDRESS--> IP4ROUTE
ip4 route FOUND TO SEND
FINDING raw_sendto_if_src
pbuf_add_header: old 200002F8 new 200002E4 (20)
pbuf_remove_header: old 200002E4 new 200002F8 (20)
ip4_output_if: en0
IP header:
| 4 | 5 | 0x00 | 60 | (v, hl, tos, len)
| 5 |000| 0 | (id, flags, offset)
| 255 | 1 | 0x39a1 | (ttl, proto, chksum)
| 192 | 168 | 0 | 102 | (src)
| 192 | 168 | 0 | 100 | (dest)
ip4_output_if: call netif->output()
pbuf_add_header: old 200002E4 new 200002D6 (14)
ethernet_output: sending packet 200002C4
SENDING PACKET TO THE KSZ8851SNLI FILE
fc 3f db fb 58 8b 2 12 13 10 15 11 8 0 45 0 0 3c 0 5 0 0 ff 1 39 a1 c0 a8 0 66 c0 a8 0 64 8 0 57 49 af af 0 6 0 1 2 3 4 5 6 7 8 9 a b c d e f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
ksz8851snl_low_level_output
RECIEVED PACKET FROM ethernet_output FILE address=200002C4
fc 3f db fb 58 8b 2 12 13 10 15 11 8 0 45 0 0 3c 0 5 0 0 ff 1 39 a1 c0 a8 0 66 c0 a8 0 64 8 0 57 49 af af 0 6 0 1 2 3 4 5 6 7 8 9 a b c d e f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f ksz8851snl_low_level_output: out of free descriptor! [tail=1 head=1]
pbuf_free(200002C4)
pbuf_free: deallocating 200002C4
sys_timeout: 2000665C abs_time=12026 handler=ping_timeout arg=20005A88
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
ksz8851_reg_read RX step6: get RX packet status
ksz8851_reg_read RX step7:read frame lengthksz8851snl_update: RX start packet receive len=116 [tail=0 head=0]
ksz8851_reg_clrbits=RX step9:reset RX frame pointer.
ksz8851_reg_setbits RX step10: start RXQ read access
Remove CRC and update pbuf length
step11-17: start FIFO read operation
IAM PRINTING FIRST 125 BYTES of RX BUFFER
0 0 0 0 0 c8 81 74 0 2b 2 ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 ce 0 0 80 11 6f b c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c 4d 86 bb 67 29 10 0 1 0 0 0 0 0 1 20 46 48 45 50 46 43 45 4c 45 48 46 43 45 50 46 46 46 41 43 41 43 41 43 41 43 41 43 41 43 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 c0 0 c0 a8 0 64 e9 78 1b b1
BUFFFER ARRAY =112
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 ce 0 0 80 11 6f b c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c 4d 86 bb 67 29 10 0 1 0 0 0 0 0 1 20 46 48 45 50 46 43 45 4c 45 48 46 43 45 50 46 46 46 41 43 41 43 41 43 41 43 41 43 41 43 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 c0 0 c0 a8 0 64 i= 121
step22-23
ksz8851snl_low_level_inputksz8851snl_low_level_input: DMA buffer 0x200097C4 received, size=110 [tail=0 head=1]
pbuf_alloc(length=1516) == 20008BBC
ksz8851snl_rx_populate_queue: new pbuf allocated with size 1516: 0x20008BBC [pos=0]
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 ce 0 0 80 11 6f b c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c 4d 86 bb 67 29 10 0 1 0 0 0 0 0 1 20 46 48 45 50 46 43 45 4c 45 48 46 43 45 50 46 46 46 41 43 41 43 41 43 41 43 41 43 41 43 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 c0 0 c0 a8 0 64 ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:fc:3f:db:fb:58:8b, type:800
ETHTYPE_IP
pbuf_remove_header: old 200097C4 new 200097D2 (14)
45 0 0 60 48 ce 0 0 80 11 6f b c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c 4d 86 bb 67 29 10 0 1 0 0 0 0 0 1 20 46 48 45 50 46 43 45 4c 45 48 46 43 45 50 46 46 46 41 43 41 43 41 43 41 43 41 43 41 43 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 c0 0 c0 a8 0 64 1
2
3
test-4
test-5
test-6
test-7
test-8
test-9
ip4_input:
IP header:
| 18638 |000| 0 | (id, flags, offset)
| 128 | 17 | 0x6f0b | (ttl, proto, chksum)
test-10
raw_input
1
count= 3 drop the packet
3
pbuf_remove_header: old 200097D2 new 200097E6 (20)
test-11
UDP header:
| 76 | 0x4d86 | (len, chksum)
udp (
192.168.0.255
, 137) <-- (
192.168.0.100
, 137)
pbuf_free(200097B4)
pbuf_free: deallocating 200097B4
sct calling h=dhcp_fine_tmr t=662 arg=3002139C
sys_timeout: 20006684 abs_time=12002 handler=dhcp_fine_tmr arg=3002139C
sct calling h=acd_tmr t=592 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=11614 handler=acd_tmr arg=300213A8
sct calling h=ip_reass_tmr t=175 arg=30021378
sys_timeout: 200066C0 abs_time=12345 handler=ip_reass_tmr arg=30021378
sct calling h=etharp_tmr t=173 arg=30021384
tcpip: etharp_tmr()
etharp_timer
sys_timeout: 200066AC abs_time=12360 handler=etharp_tmr arg=30021384
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
ksz8851_reg_read RX step7:read frame lengthksz8851snl_update: RX start packet receive len=66 [tail=1 head=1]
IAM PRINTING FIRST 77 BYTES of RX BUFFER
0 0 0 0 0 c8 81 42 0 e9 78 ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 3a dd 25 79 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 9 c8 76 fd 9 c8
BUFFFER ARRAY =62
ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 3a dd 25 79 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 i= 71
step22-23
ksz8851snl_low_level_inputksz8851snl_low_level_input: DMA buffer 0x200091C8 received, size=60 [tail=1 head=0]
pbuf_alloc(length=1516) == 200097B4
ksz8851snl_rx_populate_queue: new pbuf allocated with size 1516: 0x200097B4 [pos=1]
ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 3a dd 25 79 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:fc:3f:db:fb:58:8b, type:806
ETHTYPE_ARP
pbuf_remove_header: old 200091C8 new 200091D6 (14)
/* pass p to ARP module etharp_input */
acd_arp_reply()
etharp_update_arp_entry: 192.168.0.100 - fc:3f:db:fb:58:8b
etharp_find_entry: found matching entry 0
etharp_update_arp_entry: updating stable entry 0
ARP_REQUEST
etharp_input: incoming ARP request
etharp_input: ARP request was not for us.
pbuf_free(200091B8)
pbuf_free: deallocating 200091B8
sct calling h=acd_tmr t=196 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=11916 handler=acd_tmr arg=300213A8
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
ksz8851_reg_read RX step7:read frame lengthksz8851snl_update: RX start packet receive len=66 [tail=0 head=0]
0 0 0 0 0 c8 81 42 0 5c 76 ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 c0 a8 0 66 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 33 4d eb a 33 4d
BUFFFER ARRAY =62
ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 c0 a8 0 66 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 i= 71
step22-23
ksz8851_reg_write RX step24: enable INT_RX flag if transfer complete
INTERRUPT OCCURED ENTER KEY
ksz8851snl_low_level_inputksz8851snl_low_level_input: DMA buffer 0x20008BCC received, size=60 [tail=0 head=1]
ksz8851snl_rx_populate_queue: new pbuf allocated with size 1516: 0x200091B8 [pos=0]
ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 c0 a8 0 66 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:fc:3f:db:fb:58:8b, type:806
ETHTYPE_ARP
acd_arp_reply()
ARP_REQUEST
/* send ARP response */
pbuf_alloc(length=28)
pbuf_alloc(length=28) == 200002C4
etharp_raw: sending raw ARP packet.
fc 3f db fb 58 8b 2 12 13 10 15 11 8 6 0 1 8 0 6 4 0 2 2 12 13 10 15 11 c0 a8 0 66 fc 3f db fb 58 8b c0 a8 0 64
fc 3f db fb 58 8b 2 12 13 10 15 11 8 6 0 1 8 0 6 4 0 2 2 12 13 10 15 11 c0 a8 0 66 fc 3f db fb 58 8b c0 a8 0 64 ksz8851snl_low_level_output: out of free descriptor! [tail=1 head=1]
IAM FREEING THE ARP QUERY ADDRESS=200002C4
IAM FREEING THE ARP QUERY ADDRESS=200002C4pbuf_free(200002C4)
pbuf_free(20008BBC)
sct calling h=acd_tmr t=273 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=12294 handler=acd_tmr arg=300213A8
sct calling h=dhcp_fine_tmr t=198 arg=3002139C
sys_timeout: 20006684 abs_time=12502 handler=dhcp_fine_tmr arg=3002139C
sct calling h=ping_timeout t=187 arg=20005A88
ping: send
192.168.0.100
IAM PREPARING ping_prepare_echo static seq num=7 lwip_htons(++ping_seq_num) =1792
IAM PREPARING ping_prepare_echo static seq num=7 lwip_htons(++ping_seq_num) =1792raw_sendto
ip4_output_if: en0
IP header:
| 6 |000| 0 | (id, flags, offset)
| 255 | 1 | 0x39a0 | (ttl, proto, chksum)
fc 3f db fb 58 8b 2 12 13 10 15 11 8 0 45 0 0 3c 0 6 0 0 ff 1 39 a0 c0 a8 0 66 c0 a8 0 64 8 0 57 48 af af 0 7 0 1 2 3 4 5 6 7 8 9 a b c d e f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
fc 3f db fb 58 8b 2 12 13 10 15 11 8 0 45 0 0 3c 0 6 0 0 ff 1 39 a0 c0 a8 0 66 c0 a8 0 64 8 0 57 48 af af 0 7 0 1 2 3 4 5 6 7 8 9 a b c d e f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f ksz8851snl_low_level_output: out of free descriptor! [tail=1 head=1]
pbuf_free(200002C4)
sys_timeout: 2000665C abs_time=13416 handler=ping_timeout arg=20005A88
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING TX
ksz8851_reg_read TX step1: check if TXQ memory size is available for transmit
ksz8851_reg_write TX step2: disable all interruptsksz8851snl_update: TX start packet transmit len=74 [tail=1 head=1]
ksz8851_reg_setbits TX step3:enable TXQ write access
ksz8851_fifo_write_begin =TX step4-8 perform FIFO write operation PING PING
fifowrite total legth=74
FIFO WRITE Q ADDRESS == 2000021C
ksz8851_fifo_write= writing the tx buffer till q == NULL received length 74
fc 3f db fb 58 8b 2 12 13 10 15 11 8 0 45 0 0 3c 0 2 0 0 ff 1 39 a4 c0 a8 0 66 c0 a8 0 64 8 0 57 4c af af 0 3 0 1 2 3 4 5 6 7 8 9 a b c d e f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
c0 fc 3f db fb 58 8b 2 12 13 10 15 11 8 0 45 0 0 3c 0 2 0 0 ff 1 39 a4 c0 a8 0 66 c0 a8 0 64 8 0 57 4c af af 0 3 0 1 2 3 4 5 6 7 8 9 a b c d e f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
ksz8851_fifo_write_end=TX step9-10: pad with dummy data to keep dword alignment
ksz8851_fifo_write_end padding=2
ksz8851_reg_clrbits= TX step12 disable TXQ write access
ksz8851_reg_setbits step12.1: enqueue frame in TXQ
ksz8851_reg_write RX step13: enable INT_RX flag
INTERRUPT OCCURED ENTER KEYpbuf_free(2000021C)
pbuf_free: deallocating 2000021C
Buffer sent, free the corresponding buffer and mark descriptor as owned by software
RECIEVED PBUF IS NULL NULLL NULLsct calling h=acd_tmr t=377 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=12776 handler=acd_tmr arg=300213A8
sct calling h=ip_reass_tmr t=337 arg=30021378
sys_timeout: 200066C0 abs_time=13345 handler=ip_reass_tmr arg=30021378
sct calling h=etharp_tmr t=335 arg=30021384
tcpip: etharp_tmr()
etharp_timer
sys_timeout: 200066AC abs_time=13360 handler=etharp_tmr arg=30021384
sct calling h=dhcp_fine_tmr t=206 arg=3002139C
sys_timeout: 20006684 abs_time=13002 handler=dhcp_fine_tmr arg=3002139C
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING TX
ksz8851_reg_write TX step2: disable all interruptsksz8851snl_update: TX start packet transmit len=42 [tail=0 head=1]
fifowrite total legth=42
FIFO WRITE Q ADDRESS == 20000280
ksz8851_fifo_write= writing the tx buffer till q == NULL received length 42
c0 fc 3f db fb 58 8b 2 12 13 10 15 11 8 6 0 1 8 0 6 4 0 2 2 12 13 10 15 11 c0 a8 0 66 fc 3f db fb 58 8b c0 a8 0 64
INTERRUPT OCCURED ENTER KEYpbuf_free(20000280)
pbuf_free: deallocating 20000280
RECIEVED PBUF IS NULL NULLL NULLsct calling h=acd_tmr t=179 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=13060 handler=acd_tmr arg=300213A8
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
ksz8851_reg_read RX step1: read interrupt status for INT_RX flag
ksz8851_reg_write RX step2:disable all interrupts
ksz8851_reg_setbits RX step3:clear INT_RX flag
ksz8851_reg_read RX step4-5:check for received frames
pending_frame value=
ksz8851_reg_read RX step7:read frame lengthksz8851snl_update: RX start packet receive len=116 [tail=1 head=1]
0 0 0 0 0 c8 81 74 0 eb a ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 cf 0 0 80 11 6f a c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 80 bb 65 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 e0 4b 3 47
BUFFFER ARRAY =112
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 cf 0 0 80 11 6f a c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 80 bb 65 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 i= 121
step22-23
ksz8851snl_low_level_inputksz8851snl_low_level_input: DMA buffer 0x200097C4 received, size=110 [tail=1 head=0]
ksz8851snl_rx_populate_queue: new pbuf allocated with size 1516: 0x20008BBC [pos=1]
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 cf 0 0 80 11 6f a c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 80 bb 65 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:fc:3f:db:fb:58:8b, type:800
ETHTYPE_IP
45 0 0 60 48 cf 0 0 80 11 6f a c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 80 bb 65 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 1
2
3
test-4
test-5
test-6
test-7
test-8
test-9
ip4_input:
IP header:
| 18639 |000| 0 | (id, flags, offset)
| 128 | 17 | 0x6f0a | (ttl, proto, chksum)
test-10
raw_input
1
count= 4 drop the packet
3
test-11
UDP header:
| 76 | 0xc780 | (len, chksum)
udp (
192.168.0.255
, 137) <-- (
192.168.0.100
, 137)
pbuf_free(200097B4)
sct calling h=dhcp_fine_tmr t=483 arg=3002139C
sys_timeout: 20006684 abs_time=13502 handler=dhcp_fine_tmr arg=3002139C
sct calling h=acd_tmr t=438 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=13604 handler=acd_tmr arg=300213A8
sct calling h=ip_reass_tmr t=164 arg=30021378
sys_timeout: 200066C0 abs_time=14345 handler=ip_reass_tmr arg=30021378
sct calling h=etharp_tmr t=162 arg=30021384
tcpip: etharp_tmr()
etharp_timer
sys_timeout: 200066AC abs_time=14360 handler=etharp_tmr arg=30021384
sct calling h=ping_timeout t=119 arg=20005A88
ping: send
192.168.0.100
pbuf_alloc(length=40) == 2000021C
IAM PREPARING ping_prepare_echo static seq num=8 lwip_htons(++ping_seq_num) =2048
IAM PREPARING ping_prepare_echo static seq num=8 lwip_htons(++ping_seq_num) =2048raw_sendto
pbuf_add_header: old 20000250 new 2000023C (20)
pbuf_remove_header: old 2000023C new 20000250 (20)
ip4_output_if: en0
IP header:
| 255 | 1 | 0x399f | (ttl, proto, chksum)
pbuf_add_header: old 2000023C new 2000022E (14)
ethernet_output: sending packet 2000021C
fc 3f db fb 58 8b 2 12 13 10 15 11 8 0 45 0 0 3c 0 7 0 0 ff 1 39 9f c0 a8 0 66 c0 a8 0 64 8 0 57 47 af af 0 8 0 1 2 3 4 5 6 7 8 9 a b c d e f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
RECIEVED PACKET FROM ethernet_output FILE address=2000021C
copying address to ksz8851snli 2000021Cksz8851snl_low_level_output: DMA buffer 0x2000022E sent, size=74 [tail=1 head=1]
IAM PRINTING RESTORED DATA==fc 3f db fb 58 8b 2 12 13 10 15 11 8 6 0 1 8 0 6 4 0 2 2 12 13 10 15 11 c0 a8 0 66 fc 3f db fb 58 8b c0 a8 0 64
pbuf_free(2000021C)
pbuf_free: 2000021C has ref 1, ending here.
sys_timeout: 2000665C abs_time=14776 handler=ping_timeout arg=20005A88
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
0 0 0 0 0 c8 81 74 0 e0 4b ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d0 0 0 80 11 6f 9 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c 4d 86 bb 67 29 10 0 1 0 0 0 0 0 1 20 46 48 45 50 46 43 45 4c 45 48 46 43 45 50 46 46 46 41 43 41 43 41 43 41 43 41 43 41 43 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 c0 0 c0 a8 0 64 8a 70 af 4d
BUFFFER ARRAY =112
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d0 0 0 80 11 6f 9 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c 4d 86 bb 67 29 10 0 1 0 0 0 0 0 1 20 46 48 45 50 46 43 45 4c 45 48 46 43 45 50 46 46 46 41 43 41 43 41 43 41 43 41 43 41 43 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 c0 0 c0 a8 0 64 i= 121
step22-23
ksz8851snl_low_level_inputksz8851snl_low_level_input: DMA buffer 0x200091C8 received, size=110 [tail=0 head=1]
ksz8851snl_rx_populate_queue: new pbuf allocated with size 1516: 0x200097B4 [pos=0]
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d0 0 0 80 11 6f 9 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c 4d 86 bb 67 29 10 0 1 0 0 0 0 0 1 20 46 48 45 50 46 43 45 4c 45 48 46 43 45 50 46 46 46 41 43 41 43 41 43 41 43 41 43 41 43 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 c0 0 c0 a8 0 64 ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:fc:3f:db:fb:58:8b, type:800
ETHTYPE_IP
45 0 0 60 48 d0 0 0 80 11 6f 9 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c 4d 86 bb 67 29 10 0 1 0 0 0 0 0 1 20 46 48 45 50 46 43 45 4c 45 48 46 43 45 50 46 46 46 41 43 41 43 41 43 41 43 41 43 41 43 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 c0 0 c0 a8 0 64 1
2
3
test-4
test-5
test-6
test-7
test-8
test-9
ip4_input:
IP header:
| 18640 |000| 0 | (id, flags, offset)
| 128 | 17 | 0x6f09 | (ttl, proto, chksum)
test-10
raw_input
1
count= 5 drop the packet
3
pbuf_remove_header: old 200091D6 new 200091EA (20)
test-11
UDP header:
udp (
192.168.0.255
, 137) <-- (
192.168.0.100
, 137)
pbuf_free(200091B8)
sct calling h=dhcp_fine_tmr t=744 arg=3002139C
sys_timeout: 20006684 abs_time=14752 handler=dhcp_fine_tmr arg=3002139C
sct calling h=acd_tmr t=655 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=14364 handler=acd_tmr arg=300213A8
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
0 0 0 0 0 c8 81 74 0 8a 70 ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d1 0 0 80 11 6f 8 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 7d bb 66 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 43 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 3b 10 21 cf
BUFFFER ARRAY =112
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d1 0 0 80 11 6f 8 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 7d bb 66 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 43 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 i= 121
step22-23
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d1 0 0 80 11 6f 8 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 7d bb 66 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 43 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:fc:3f:db:fb:58:8b, type:800
ETHTYPE_IP
45 0 0 60 48 d1 0 0 80 11 6f 8 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 7d bb 66 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 43 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 1
2
3
test-4
test-5
test-6
test-7
test-8
test-9
ip4_input:
IP header:
| 18641 |000| 0 | (id, flags, offset)
| 128 | 17 | 0x6f08 | (ttl, proto, chksum)
test-10
raw_input
1
count= 6 drop the packet
3
test-11
UDP header:
udp (
192.168.0.255
, 137) <-- (
192.168.0.100
, 137)
pbuf_free(20008BBC)
sct calling h=ip_reass_tmr t=389 arg=30021378
sys_timeout: 200066C0 abs_time=15345 handler=ip_reass_tmr arg=30021378
sct calling h=etharp_tmr t=387 arg=30021384
tcpip: etharp_tmr()
etharp_timer
sys_timeout: 200066AC abs_time=15360 handler=etharp_tmr arg=30021384
sct calling h=acd_tmr t=396 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=14865 handler=acd_tmr arg=300213A8
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
0 0 0 0 0 c8 81 42 0 3b 10 ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 c0 a8 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 44 5c 59 2b 44 5c
BUFFFER ARRAY =62
ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 c0 a8 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 i= 71
step22-23
ksz8851snl_low_level_inputksz8851snl_low_level_input: DMA buffer 0x200097C4 received, size=60 [tail=0 head=1]
ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 c0 a8 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:fc:3f:db:fb:58:8b, type:806
ETHTYPE_ARP
acd_arp_reply()
ARP_REQUEST
pbuf_free(200097B4)
sct calling h=dhcp_fine_tmr t=283 arg=3002139C
sys_timeout: 20006684 abs_time=15252 handler=dhcp_fine_tmr arg=3002139C
sct calling h=ping_timeout t=272 arg=20005A88
ping: send
192.168.0.100
pbuf_alloc(length=40) == 20000280
IAM PREPARING ping_prepare_echo static seq num=9 lwip_htons(++ping_seq_num) =2304
IAM PREPARING ping_prepare_echo static seq num=9 lwip_htons(++ping_seq_num) =2304raw_sendto
pbuf_add_header: old 200002B4 new 200002A0 (20)
pbuf_remove_header: old 200002A0 new 200002B4 (20)
ip4_output_if: en0
IP header:
| 255 | 1 | 0x399e | (ttl, proto, chksum)
pbuf_add_header: old 200002A0 new 20000292 (14)
ethernet_output: sending packet 20000280
fc 3f db fb 58 8b 2 12 13 10 15 11 8 0 45 0 0 3c 0 8 0 0 ff 1 39 9e c0 a8 0 66 c0 a8 0 64 8 0 57 46 af af 0 9 0 1 2 3 4 5 6 7 8 9 a b c d e f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
RECIEVED PACKET FROM ethernet_output FILE address=20000280
copying address to ksz8851snli 20000280ksz8851snl_low_level_output: DMA buffer 0x20000292 sent, size=74 [tail=1 head=0]
pbuf_free(20000280)
pbuf_free: 20000280 has ref 1, ending here.
sys_timeout: 2000665C abs_time=16257 handler=ping_timeout arg=20005A88
sct calling h=acd_tmr t=399 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=15369 handler=acd_tmr arg=300213A8
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
0 0 0 0 0 c8 81 42 0 ad a6 ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 8 8 8 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 58 eb 5a f1 58 eb
BUFFFER ARRAY =62
ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 8 8 8 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 i= 71
step22-23
ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 8 8 8 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:fc:3f:db:fb:58:8b, type:806
ETHTYPE_ARP
acd_arp_reply()
ARP_REQUEST
pbuf_free(200091B8)
sct calling h=dhcp_fine_tmr t=286 arg=3002139C
sys_timeout: 20006684 abs_time=15752 handler=dhcp_fine_tmr arg=3002139C
sct calling h=ip_reass_tmr t=206 arg=30021378
sys_timeout: 200066C0 abs_time=16345 handler=ip_reass_tmr arg=30021378
sct calling h=etharp_tmr t=203 arg=30021384
tcpip: etharp_tmr()
etharp_timer
sys_timeout: 200066AC abs_time=16360 handler=etharp_tmr arg=30021384
sct calling h=acd_tmr t=208 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=15682 handler=acd_tmr arg=300213A8
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
0 0 0 0 0 c8 81 42 0 a7 ee ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 c0 a8 0 66 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 33 4d eb a 33 4d
BUFFFER ARRAY =62
step22-23
ETHTYPE_ARP
acd_arp_reply()
ARP_REQUEST
pbuf_alloc(length=28) == 200002E4
pbuf_add_header: old 20000304 new 200002F6 (14)
ethernet_output: sending packet 200002E4
RECIEVED PACKET FROM ethernet_output FILE address=200002E4
IAM FREEING THE ARP QUERY ADDRESS=200002E4
IAM FREEING THE ARP QUERY ADDRESS=200002E4pbuf_free(200002E4)
pbuf_free: deallocating 200002E4
pbuf_free(20008BBC)
sct calling h=acd_tmr t=253 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=16040 handler=acd_tmr arg=300213A8
sct calling h=dhcp_fine_tmr t=194 arg=3002139C
sys_timeout: 20006684 abs_time=16252 handler=dhcp_fine_tmr arg=3002139C
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
0 0 0 0 0 c8 81 74 0 eb a ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d2 0 0 80 11 6f 7 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 80 bb 65 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 e3 a a6 4e
BUFFFER ARRAY =112
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d2 0 0 80 11 6f 7 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 80 bb 65 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 i= 121
step22-23
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d2 0 0 80 11 6f 7 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 80 bb 65 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:fc:3f:db:fb:58:8b, type:800
ETHTYPE_IP
45 0 0 60 48 d2 0 0 80 11 6f 7 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 80 bb 65 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 1
2
3
test-4
test-5
test-6
test-7
test-8
test-9
ip4_input:
IP header:
| 18642 |000| 0 | (id, flags, offset)
| 128 | 17 | 0x6f07 | (ttl, proto, chksum)
test-10
raw_input
1
count= 7 drop the packet
3
test-11
UDP header:
udp (
192.168.0.255
, 137) <-- (
192.168.0.100
, 137)
pbuf_free(200097B4)
sct calling h=acd_tmr t=383 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=16528 handler=acd_tmr arg=300213A8
sct calling h=dhcp_fine_tmr t=182 arg=3002139C
sys_timeout: 20006684 abs_time=16752 handler=dhcp_fine_tmr arg=3002139C
sct calling h=ping_timeout t=190 arg=20005A88
ping: send
192.168.0.100
pbuf_alloc(length=40) == 200002E4
IAM PREPARING ping_prepare_echo static seq num=10 lwip_htons(++ping_seq_num) =2560
IAM PREPARING ping_prepare_echo static seq num=10 lwip_htons(++ping_seq_num) =2560raw_sendto
pbuf_add_header: old 20000318 new 20000304 (20)
pbuf_remove_header: old 20000304 new 20000318 (20)
ip4_output_if: en0
IP header:
| 255 | 1 | 0x399d | (ttl, proto, chksum)
fc 3f db fb 58 8b 2 12 13 10 15 11 8 0 45 0 0 3c 0 9 0 0 ff 1 39 9d c0 a8 0 66 c0 a8 0 64 8 0 57 45 af af 0 a 0 1 2 3 4 5 6 7 8 9 a b c d e f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
fc 3f db fb 58 8b 2 12 13 10 15 11 8 0 45 0 0 3c 0 9 0 0 ff 1 39 9d c0 a8 0 66 c0 a8 0 64 8 0 57 45 af af 0 a 0 1 2 3 4 5 6 7 8 9 a b c d e f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f ksz8851snl_low_level_output: out of free descriptor! [tail=1 head=1]
pbuf_free(200002E4)
sys_timeout: 2000665C abs_time=17650 handler=ping_timeout arg=20005A88
sct calling h=ip_reass_tmr t=312 arg=30021378
sys_timeout: 200066C0 abs_time=17345 handler=ip_reass_tmr arg=30021378
sct calling h=etharp_tmr t=309 arg=30021384
tcpip: etharp_tmr()
etharp_timer
sys_timeout: 200066AC abs_time=17360 handler=etharp_tmr arg=30021384
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
0 0 0 0 0 c8 81 74 0 e3 a ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d3 0 0 80 11 6f 6 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c 4d 86 bb 67 29 10 0 1 0 0 0 0 0 1 20 46 48 45 50 46 43 45 4c 45 48 46 43 45 50 46 46 46 41 43 41 43 41 43 41 43 41 43 41 43 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 c0 0 c0 a8 0 64 ea 39 be b8
BUFFFER ARRAY =112
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d3 0 0 80 11 6f 6 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c 4d 86 bb 67 29 10 0 1 0 0 0 0 0 1 20 46 48 45 50 46 43 45 4c 45 48 46 43 45 50 46 46 46 41 43 41 43 41 43 41 43 41 43 41 43 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 c0 0 c0 a8 0 64 i= 121
step22-23
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d3 0 0 80 11 6f 6 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c 4d 86 bb 67 29 10 0 1 0 0 0 0 0 1 20 46 48 45 50 46 43 45 4c 45 48 46 43 45 50 46 46 46 41 43 41 43 41 43 41 43 41 43 41 43 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 c0 0 c0 a8 0 64 ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:fc:3f:db:fb:58:8b, type:800
ETHTYPE_IP
45 0 0 60 48 d3 0 0 80 11 6f 6 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c 4d 86 bb 67 29 10 0 1 0 0 0 0 0 1 20 46 48 45 50 46 43 45 4c 45 48 46 43 45 50 46 46 46 41 43 41 43 41 43 41 43 41 43 41 43 41 41 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 c0 0 c0 a8 0 64 1
2
3
test-4
test-5
test-6
test-7
test-8
test-9
ip4_input:
IP header:
| 18643 |000| 0 | (id, flags, offset)
| 128 | 17 | 0x6f06 | (ttl, proto, chksum)
test-10
raw_input
1
count= 8 drop the packet
3
test-11
UDP header:
udp (
192.168.0.255
, 137) <-- (
192.168.0.100
, 137)
pbuf_free(200091B8)
sct calling h=acd_tmr t=619 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=17252 handler=acd_tmr arg=300213A8
sct calling h=dhcp_fine_tmr t=406 arg=3002139C
sys_timeout: 20006684 abs_time=17252 handler=dhcp_fine_tmr arg=3002139C
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
0 0 0 0 0 c8 81 74 0 ea 39 ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d4 0 0 80 11 6f 5 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 7d bb 66 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 43 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 c6 93 77 c1
BUFFFER ARRAY =112
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d4 0 0 80 11 6f 5 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 7d bb 66 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 43 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 i= 121
step22-23
ff ff ff ff ff ff fc 3f db fb 58 8b 8 0 45 0 0 60 48 d4 0 0 80 11 6f 5 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 7d bb 66 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 43 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 ethernet_input: dest:ff:ff:ff:ff:ff:ff, src:fc:3f:db:fb:58:8b, type:800
ETHTYPE_IP
45 0 0 60 48 d4 0 0 80 11 6f 5 c0 a8 0 64 c0 a8 0 ff 0 89 0 89 0 4c c7 7d bb 66 29 10 0 1 0 0 0 0 0 1 20 45 45 45 46 46 44 45 4c 46 45 45 50 46 41 43 4e 45 43 44 43 46 44 44 45 45 43 45 43 46 41 43 41 0 0 20 0 1 c0 c 0 20 0 1 0 4 93 e0 0 6 40 0 c0 a8 0 64 1
2
3
test-4
test-5
test-6
test-7
test-8
test-9
ip4_input:
IP header:
| 18644 |000| 0 | (id, flags, offset)
| 128 | 17 | 0x6f05 | (ttl, proto, chksum)
test-10
raw_input
1
count= 9 drop the packet
3
test-11
UDP header:
udp (
192.168.0.255
, 137) <-- (
192.168.0.100
, 137)
pbuf_free(20008BBC)
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=17740 handler=acd_tmr arg=300213A8
sct calling h=dhcp_fine_tmr t=394 arg=3002139C
sys_timeout: 20006684 abs_time=17752 handler=dhcp_fine_tmr arg=3002139C
sct calling h=ip_reass_tmr t=314 arg=30021378
sys_timeout: 200066C0 abs_time=18345 handler=ip_reass_tmr arg=30021378
sct calling h=etharp_tmr t=312 arg=30021384
tcpip: etharp_tmr()
etharp_timer
sys_timeout: 200066AC abs_time=18360 handler=etharp_tmr arg=30021384
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
0 0 0 0 0 c8 81 42 0 c6 93 ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 c0 a8 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 44 5c 59 2b 44 5c
BUFFFER ARRAY =62
step22-23
ETHTYPE_ARP
acd_arp_reply()
ARP_REQUEST
pbuf_free(200097B4)
sct calling h=ping_timeout t=298 arg=20005A88
ping: send
192.168.0.100
IAM PREPARING ping_prepare_echo static seq num=11 lwip_htons(++ping_seq_num) =2816
IAM PREPARING ping_prepare_echo static seq num=11 lwip_htons(++ping_seq_num) =2816raw_sendto
ip4_output_if: en0
IP header:
| 10 |000| 0 | (id, flags, offset)
| 255 | 1 | 0x399c | (ttl, proto, chksum)
fc 3f db fb 58 8b 2 12 13 10 15 11 8 0 45 0 0 3c 0 a 0 0 ff 1 39 9c c0 a8 0 66 c0 a8 0 64 8 0 57 44 af af 0 b 0 1 2 3 4 5 6 7 8 9 a b c d e f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
fc 3f db fb 58 8b 2 12 13 10 15 11 8 0 45 0 0 3c 0 a 0 0 ff 1 39 9c c0 a8 0 66 c0 a8 0 64 8 0 57 44 af af 0 b 0 1 2 3 4 5 6 7 8 9 a b c d e f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f ksz8851snl_low_level_output: out of free descriptor! [tail=1 head=1]
pbuf_free(200002E4)
sys_timeout: 2000665C abs_time=19152 handler=ping_timeout arg=20005A88
sct calling h=acd_tmr t=418 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=18263 handler=acd_tmr arg=300213A8
sct calling h=dhcp_fine_tmr t=417 arg=3002139C
sys_timeout: 20006684 abs_time=18252 handler=dhcp_fine_tmr arg=3002139C
IAM IN WHILE LOOP
ethernetif_input
ksz8851snl_update
IAM HANDLING RX
IAM HANDLING RX
IAM HANDLING RX
0 0 0 0 0 c8 81 42 0 59 2b ff ff ff ff ff ff fc 3f db fb 58 8b 8 6 0 1 8 0 6 4 0 1 fc 3f db fb 58 8b c0 a8 0 64 0 0 0 0 0 0 8 8 8 8 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 58 eb 5a f1 58 eb
BUFFFER ARRAY =62
step22-23
ETHTYPE_ARP
acd_arp_reply()
ARP_REQUEST
pbuf_free(200091B8)
sct calling h=dhcp_fine_tmr t=193 arg=3002139C
sys_timeout: 20006684 abs_time=18752 handler=dhcp_fine_tmr arg=3002139C
sct calling h=acd_tmr t=195 arg=300213A8
tcpip: acd_tmr()
sys_timeout: 20006670 abs_time=18563 handler=acd_tmr arg=300213A8
sct calling h=ip_reass_tmr t=124 arg=30021378
sys_timeout: 200066C0 abs_time=19345 handler=ip_reass_tmr arg=30021378
sct calling h=etharp_tmr t=122 arg=30021384
tcpip: etharp_tmr()
etharp_timer
sys_timeout: 200066AC abs_time=19360 handler=etharp_tmr arg=30021384
@jingpan @Sanket_Parekh
