iMx28 power rail voltage problem
1,287 次查看
ashutosh
We have designed a board using iMx28. Two boards are fabricated, assembled & working fine.
Now, our plan is to go for production. Before that we got another 2 boards assembled.
But, in these boards, not getting processor voltages properly.
Getting 0.7v for 3.3v & 0.9v for 1.8v.
What can be the reason?
We are having very less time to meet the schedules.
Pl help us to resolve the issue ASAP.
Thank You
1,194 次查看
weidong_sun
Hello Ashutosh,
   The current situation you are facing is :
(1) Two boards are working fine, no any problem.
(2) Another 2 boards with the same design as above, but they don't normally work. Getting 0.7v for 3.3v & 0.9v for 1.8v. RIGHT?
If yes,  my advice is :
(1) check if there exists on SMT.
(2) measuring volatge of PSWITCH pin. The pin's voltage will determine if DC-DC converter starts up. see below, please!
Have a nice day!
Weidong Sun
