iMXRT Timer Clock Connections
1,492件の閲覧回数
Lukas_Frank
Senior Contributor I
Hi all,
I just looking forward to explore "How can I access configuration information detail of Timer Clock Connections with iMX RT1024. I have evaluation kit. But I do not know "How can I achieve design details(input/output configuration) of timer control component on the board?". Which document can help me? I looked up every document on the official site.
Thanks for your help.
1,478件の閲覧回数
Alexis_A
Hello @Lukas_Frank,
In the SDK you could find many examples that shows how to use most of the timers found in the MCU. These can be found in the driver example folder:
Also, using the config tools could help configuring any of the timer modules:
For more information about the config tools check the following link:
 Quick Start Guide for MCUXpresso Config Tools (nxp.com)
Alexis Andalon
