iMX93 Windows 11 IoT bluescreens when connecting USB device
ソリューションへジャンプ
2,623件の閲覧回数
KFriedrich
The Windows 11 IoT version from the "i.MX Windows 10/11 IoT Enterprise Quick Start Guide​" has working USB but is outdated.
I am trying to use a newer version of Windows 11 IoT Enterprise LTSC 2024.
Using the the Steps outlined in the Quick Start Guide, I
- first downloaded Windows W21H2-1-5-1 BSP prebuilt binaries
- then downloaded the newest Win 11 IoT LTSC 2024 arm64 .iso and extracted its install.wim
- after that I built an image using make-winpe-enterprise.cmd
- applied it to an sd-card and installed windows to a board
Now the moment I plug any USB device into one of the USB-Host ports windows bluescreens.
I am using the same board and uboot+uefi as with the older (working) version.
Analyzing the bluesceen dump shows that Windows crashes usbehci!InterlockedOr
0c ffff888a`9c04f630 fffff800`45c3b0cc     nt!KeBugCheck2+0xaf0
0d ffff888a`9c04fc10 fffff800`45d1193c     nt!HalBugCheckSystem+0x8c
0e ffff888a`9c04fc50 fffff800`45d11d40     nt!WheaRecoveryBugCheck+0x6c
0f ffff888a`9c04fc70 fffff800`470a185c     nt!WheaReportHwError+0x3f0
10 ffff888a`9c04fd30 fffff800`45d156a4     RADARM!RadArmSeaCallback+0x2bc
11 ffff888a`9c04fee0 fffff800`45c4108c     nt!WheaSignalHandlerOverride+0x34
12 ffff888a`9c04fef0 fffff800`45a5f440     nt!HalWheaHandleSea+0x4c
13 ffff888a`9c04ff80 fffff800`45a5f534     nt!KiAbortException+0x280
14 ffff888a`9c04ffc0 fffff800`45993c00     nt!KiSynchronousException+0x94
15 ffff888a`9c0500b0 fffff800`4599285c     nt!KzSynchronousException+0x24
16 ffff888a`9c050110 fffff800`442b10dc     nt!KiArm64ExceptionVectors+0x5c
17 ffff888a`9c050480 fffff800`442bcaa4     usbehci!InterlockedOr+0xc
18 ffff888a`9c050480 fffff800`442b6d48     usbehci!EHCI_AllocTd+0x84
19 ffff888a`9c0504b0 fffff800`442be784     usbehci!EHCI_OpenBulkOrControlEndpoint+0x148
1a ffff888a`9c050520 fffff800`442d3164     usbehci!EHCI_OpenEndpoint+0x134
1b ffff888a`9c050590 fffff800`44302e04     USBPORT!MPx_OpenEndpoint+0xd4
1c ffff888a`9c0505d0 fffff800`44301af8     USBPORT!USBPORT_OpenEndpoint+0x994
1d ffff888a`9c050650 fffff800`442dede0     USBPORT!USBPORT_NeoCreateDevice+0x300
1e ffff888a`9c0506d0 fffff800`494f7f00     USBPORT!USBPORTBUSIF_CreateUsbDeviceV7+0xa0
1f ffff888a`9c050750 fffff800`49519e18     usbhub!UsbhCreateDevice+0x278
20 ffff888a`9c050830 fffff800`49518278     usbhub!UsbhReset1Complete+0x118
21 ffff888a`9c0508a0 fffff800`494ef838     usbhub!UsbhEnumerate1+0x218
22 ffff888a`9c0508f0 fffff800`494effe8     usbhub!UsbhHubDispatchPortEvent+0x6f0
23 ffff888a`9c050960 fffff800`494f61b4     usbhub!UsbhHubRunPortChangeQueue+0x288
24 ffff888a`9c050a10 fffff800`494eeb54     usbhub!Usbh_PCE_wRun_Action+0x194
25 ffff888a`9c050a50 fffff800`494f1ce4     usbhub!UsbhDispatch_PortChangeQueueEventEx+0x12c
26 ffff888a`9c050aa0 fffff800`494efa88     usbhub!UsbhPCE_wRun+0x8c
27 ffff888a`9c050ad0 fffff800`459f2618     usbhub!UsbhHubProcessChangeWorker+0x148
28 ffff888a`9c050b20 fffff800`45b27818     nt!IopProcessWorkItem+0x98
29 ffff888a`9c050b80 fffff800`45a9ca80     nt!ExpWorkerThread+0x148
2a ffff888a`9c050d50 fffff800`4599be4c     nt!PspSystemThreadStartup+0x50
2b ffff888a`9c050d90 00000000`00000000     nt!KiStartSystemThread+0x24
more specifically on this "ldsetal" instruction:
usbehci!InterlockedOr:
fffff800`442b10d0 900000f0 adrp    xip0, usbehci!__security_cookie (fffff800442c4000)
fffff800`442b10d4 101240b9 ldr     wip0, [xip0, usbehci!_AtomicsV81Support (x16+10h)]
fffff800`442b10d8 70000036 tbz     wip0, #0, usbehci!_InterlockedOr+0x14 (fffff800442b10e4)
fffff800`442b10dc 0030e1b8 ldsetal w1, w0, [x0]
 I verified that usbehci_fix.inf from BSP is installed and the registry key "NoInterlockedOpOnCommonBuffers" is present.
How can I fix this crash?
2,473件の閲覧回数
KFriedrich
Thank you for your reply.
I used the install.wim from en-us_windows_11_iot_enterprise_ltsc_2024_x64_dvd_f6b14814.iso
I am unable to reproduce the issue now. I think the Issue was caused by a defective sd-card. In theory it could also be caused by make-winpe-enterprise.cmd /apply failing to copy install.swm  correctly.
I used FastCopy to verify the files on the sd-card were identical to those in out\winpe-imx-sdcard-layout and noticed the corrupted install.swm. Since then I started to verify the files are copied correctly and haven't had any more problems.
I am marking this as resolved.
2 返答(返信)
2,487件の閲覧回数
anthonychen-msft
Can you share the exact name of the ISO?
2,474件の閲覧回数
KFriedrich
%3CLINGO-SUB%20id%3D%22lingo-sub-1990360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX93%20Windows%2011%20USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E6%8E%A5%E7%B6%9A%E6%99%82%E3%81%AEIoT%E3%83%96%E3%83%AB%E3%83%BC%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%80%8C%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DIMXWQSG%26amp%3BappType%3Dlicense%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%20Windows%2010%2F11%20IoT%20Enterprise%20%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%20%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%20%E3%82%AC%E3%82%A4%E3%83%89%3C%2FA%3E%E3%80%8D%E3%81%AE%20Windows%2011%20IoT%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81USB%20%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%8F%A4%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%20Windows%2011%20IoT%20Enterprise%20LTSC%202024%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%3C%2FP%3E%3CP%3E-%20%E6%9C%80%E5%88%9D%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%20Windows%20W21H2-1-5-1%20BSP%20%E3%83%93%E3%83%AB%E3%83%89%E6%B8%88%E3%81%BF%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%3C%2FP%3E%3CP%3E-%20%E6%AC%A1%E3%81%AB%E3%80%81%E6%9C%80%E6%96%B0%E3%81%AE%20Win%2011%20IoT%20LTSC%202024%20arm64%20.iso%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%81%AEinstall.wim%E3%82%92%E6%8A%BD%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E-%20%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81make-winpe-enterprise.cmd%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E-%20SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%97%E3%80%81Windows%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%81%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92USB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE1%E3%81%A4%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Windows%E3%81%8C%E3%83%96%E3%83%AB%E3%83%BC%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E5%8F%A4%E3%81%84(%E5%8B%95%E4%BD%9C%E4%B8%AD%E3%81%AE)%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8%E5%90%8C%E3%81%98%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8uboot%20%2B%20uefi%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ebluesceen%E3%83%80%E3%83%B3%E3%83%97%E3%82%92%E5%88%86%E6%9E%90%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Windows%E3%81%8Cusbehci%E3%82%92%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AD%E3%83%83%E3%82%AF%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E0c%20ffff888a%609c04f630%20fffff800%6045c3b0cc%20%20%20%20%20nt!KeBugCheck2%2B0xaf0%0A0d%20ffff888a%609c04fc10%20fffff800%6045d1193c%20%20%20%20%20nt!HalBugCheckSystem%2B0x8c%0A0e%20ffff888a%609c04fc50%20fffff800%6045d11d40%20%20%20%20%20nt!WheaRecoveryBugCheck%2B0x6c%0A0f%20ffff888a%609c04fc70%20fffff800%60470a185c%20%20%20%20%20nt!WheaReportHwError%2B0x3f0%0A10%20ffff888a%609c04fd30%20fffff800%6045d156a4%20%20%20%20%20RADARM!RadArmSeaCallback%2B0x2bc%0A11%20ffff888a%609c04fee0%20fffff800%6045c4108c%20%20%20%20%20nt!WheaSignalHandlerOverride%2B0x34%0A12%20ffff888a%609c04fef0%20fffff800%6045a5f440%20%20%20%20%20nt!HalWheaHandleSea%2B0x4c%0A13%20ffff888a%609c04ff80%20fffff800%6045a5f534%20%20%20%20%20nt!KiAbortException%2B0x280%0A14%20ffff888a%609c04ffc0%20fffff800%6045993c00%20%20%20%20%20nt!KiSynchronousException%2B0x94%0A15%20ffff888a%609c0500b0%20fffff800%604599285c%20%20%20%20%20nt!KzSynchronousException%2B0x24%0A16%20ffff888a%609c050110%20fffff800%60442b10dc%20%20%20%20%20nt!KiArm64ExceptionVectors%2B0x5c%0A17%20ffff888a%609c050480%20fffff800%60442bcaa4%20%20%20%20%20usbehci!InterlockedOr%2B0xc%0A18%20ffff888a%609c050480%20fffff800%60442b6d48%20%20%20%20%20usbehci!EHCI_AllocTd%2B0x84%0A19%20ffff888a%609c0504b0%20fffff800%60442be784%20%20%20%20%20usbehci!EHCI_OpenBulkOrControlEndpoint%2B0x148%0A1a%20ffff888a%609c050520%20fffff800%60442d3164%20%20%20%20%20usbehci!EHCI_OpenEndpoint%2B0x134%0A1b%20ffff888a%609c050590%20fffff800%6044302e04%20%20%20%20%20USBPORT!MPx_OpenEndpoint%2B0xd4%0A1c%20ffff888a%609c0505d0%20fffff800%6044301af8%20%20%20%20%20USBPORT!USBPORT_OpenEndpoint%2B0x994%0A1d%20ffff888a%609c050650%20fffff800%60442dede0%20%20%20%20%20USBPORT!USBPORT_NeoCreateDevice%2B0x300%0A1e%20ffff888a%609c0506d0%20fffff800%60494f7f00%20%20%20%20%20USBPORT!USBPORTBUSIF_CreateUsbDeviceV7%2B0xa0%0A1f%20ffff888a%609c050750%20fffff800%6049519e18%20%20%20%20%20usbhub!UsbhCreateDevice%2B0x278%0A20%20ffff888a%609c050830%20fffff800%6049518278%20%20%20%20%20usbhub!UsbhReset1Complete%2B0x118%0A21%20ffff888a%609c0508a0%20fffff800%60494ef838%20%20%20%20%20usbhub!UsbhEnumerate1%2B0x218%0A22%20ffff888a%609c0508f0%20fffff800%60494effe8%20%20%20%20%20usbhub!UsbhHubDispatchPortEvent%2B0x6f0%0A23%20ffff888a%609c050960%20fffff800%60494f61b4%20%20%20%20%20usbhub!UsbhHubRunPortChangeQueue%2B0x288%0A24%20ffff888a%609c050a10%20fffff800%60494eeb54%20%20%20%20%20usbhub!Usbh_PCE_wRun_Action%2B0x194%0A25%20ffff888a%609c050a50%20fffff800%60494f1ce4%20%20%20%20%20usbhub!UsbhDispatch_PortChangeQueueEventEx%2B0x12c%0A26%20ffff888a%609c050aa0%20fffff800%60494efa88%20%20%20%20%20usbhub!UsbhPCE_wRun%2B0x8c%0A27%20ffff888a%609c050ad0%20fffff800%60459f2618%20%20%20%20%20usbhub!UsbhHubProcessChangeWorker%2B0x148%0A28%20ffff888a%609c050b20%20fffff800%6045b27818%20%20%20%20%20nt!IopProcessWorkItem%2B0x98%0A29%20ffff888a%609c050b80%20fffff800%6045a9ca80%20%20%20%20%20nt!ExpWorkerThread%2B0x148%0A2a%20ffff888a%609c050d50%20fffff800%604599be4c%20%20%20%20%20nt!PspSystemThreadStartup%2B0x50%0A2b%20ffff888a%609c050d90%2000000000%6000000000%20%20%20%20%20nt!KiStartSystemThread%2B0x24%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E3%80%8Cldsetal%E3%80%8D%E5%91%BD%E4%BB%A4%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%82%88%E3%82%8A%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%AF%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eusbehci!InterlockedOr%3A%0Afffff800%60442b10d0%20900000f0%20adrp%20%20%20%20xip0%2C%20usbehci!__security_cookie%20(fffff800442c4000)%0Afffff800%60442b10d4%20101240b9%20ldr%20%20%20%20%20wip0%2C%20%5Bxip0%2C%20usbehci!_AtomicsV81Support%20(x16%2B10h)%5D%0Afffff800%60442b10d8%2070000036%20tbz%20%20%20%20%20wip0%2C%20%230%2C%20usbehci!_InterlockedOr%2B0x14%20(fffff800442b10e4)%0Afffff800%60442b10dc%200030e1b8%20ldsetal%20w1%2C%20w0%2C%20%5Bx0%5D%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EBSP%20%E3%81%AE%20usbehci_fix.inf%20%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%83%88%E3%83%AA%20%E3%82%AD%E3%83%BC%20%22NoInterlockedOpOnCommonBuffers%22%20%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2012042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AEiMX93%20Windows%2011%20IoT%E3%83%96%E3%83%AB%E3%83%BC%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2012042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFen-us_windows_11_iot_enterprise_ltsc_2024_x64_dvd_f6b14814.iso%E3%81%AE%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Einstall.wim%3C%2FFONT%3E%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%E3%81%BE%E3%81%97%E3%81%9F%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%8D%E8%89%AF%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%90%86%E8%AB%96%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%2Fapply%20make-winpe-enterprise.cmd%3C%2FFONT%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Einstall.swm%3C%2FFONT%3E%20%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%26nbsp%3B%E9%81%A9%E5%88%87%E3%81%AB%E3%80%82%3C%2FP%3E%3CP%3EFastCopy%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81SD%E3%82%AB%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Eout%20%5C%20winpe-imx-sdcard-layout%20%3C%2FFONT%3E%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Einstall.swm%3C%2FFONT%3E%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E6%9D%A5%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%82%B3%E3%83%94%E3%83%BC%E3%81%95%E3%82%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E6%B8%88%E3%81%BF%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2010828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AEiMX93%20Windows%2011%20IoT%E3%83%96%E3%83%AB%E3%83%BC%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2010828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EISO%E3%81%AE%E6%AD%A3%E7%A2%BA%E3%81%AA%E5%90%8D%E5%89%8D%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
