iMX8QM and LPDDR4 memory errors
7,014 次查看
emanuele79
We are introducing the Nanya NT6AN512T32AV-J1I (https://www.nanya.com/en/Product/4404/NT6AN512T32AV-J1I) memory on our Apalis iMX8 (i.MX8QM) module as a replacement for the Micron MT53D512M32D2DS-046 IT:D (mt53d512m32d2ds-046-ait-d )
We have reviewed the timing specifications, and the Nanya part appears to be a drop-in replacement for the Micron one, as both seem to have the same timing requirements.
We tested several modules equipped with the Nanya memory using the same test setup as for the Micron version (Linux BSP + Memtester [memtester-4.6.0.tar.gz To be sure we have also re-run the test on the Micron modules.
The Nanya memory performs well at different temperature ranges, but in the higher range (~50°C to ~80°C), during the Bit Spread (but not only) test in Memtester, we observed the following failures (these are a subset of the total failures we had):
FAILURE: 0xffffffffffffffff != 0xfffffffffbffffff at offset 0x00000000031a9a80.
FAILURE: 0xffffffffffffffff != 0xfffffffffbffffff at offset 0x0000000009eb5440.
FAILURE: 0xffffffffffffffff != 0xfffffffffbffffff at offset 0x000000000172b040.
FAILURE: 0xfffffffffbffffff != 0xffffffffffffffff at offset 0x000000000792e570.
FAILURE: 0xffffffffffffffff != 0xfffffffffbffffff at offset 0x000000000a13fb00.
It is important to note that these errors appear only when we start testing at -40°C and ramp up to 85°C without rebooting. If we start the test at 85°C and ramp down to -40°C, we do not observe any errors. Due to this, we suspect that LPDDR4 training at -40 is affecting the reliability of the memory (maybe there are signal integrity issues when training is done at -40 degrees).
We also dumped some DDR controller registers related to memory training, and we noticed significant differences between the two memory types (see attachments). We suspect that some termination or drive strength parameters may need to be tuned for the Nanya memory, but we are not sure which ones.
We have also attached the RPA (Register Programming Aid) Excel sheet containing the DDR controller configuration currently used for both memory types.
Any advice or suggestions are welcome, but specifically, we have the following questions:
  • Can the comparison of the training result registers help identify the root cause or highlight key differences between the two memory types?
  • Have you any suggestion around memory configuration to improve training and signal integrity?
Thank you in advance for your support.
标记 (1)
31 回复数
3,713 次查看
emanuele79
on the memory there is written:
Nanya2447
NT6AN512T32AV-J1I
9423W1EF 3 TW
Let me know if this is the information you need.
Thanks!
Emanuele
2,854 次查看
pengyong_zhang
Hi @emanuele79
Actually, i am not make sure which DS value or ODT value will resolve this problem.
But there is another method you can try:
Modify the MR12 value through SCFW imx8qm_dcd_1.6GHz.cfg file, refer the below code.
DATA 4  DDR_PHY_MR12_0  0x48
Adjust the test from 25.2% down. Test in sequence.
B.R
2,752 次查看
pengyong_zhang
Hi @emanuele79
Yes,  I mean 24.8, 24.4, 24 and so on.
B.R
2,780 次查看
emanuele79
Hi @pengyong_zhang ,
You proposed to change MR12, do I also have to change MR14?
Sorry, I have another doubt. When you say "test from 25.2% down", do you mean 24.8, 24.4, 24 and so on, or the other way around (25.6, 26, 26.6 and so on)?
Thank you,
kind regards.
Emanuele
2,583 次查看
pengyong_zhang
Hi @emanuele79
Got your information, You can use our MX8QM_B0_LPDDR4_RPA_1.6GHz_v23.xlsx file choose different DS value then re-run the test see if this error can be solved. Because your error was occurred when the environment temperature from low to high. i suggest you can try the DS from 40->48. And see the test result.
B.R
2,363 次查看
emanuele79
Hello @pengyong_zhang,
tested your proposal and also 40 -> 60.
Both tests failed on 7 boards without any significant change (improvement or worsening).
2,491 次查看
emanuele79
Hi @pengyong_zhang,
thank you for the hint.
We have already done a test by setting both  ZPROG_DRAM_ODT and ZPROG_ASYM_PD_DRV in RPA from 40 to 48 - Register DDR_PHY_ZQ1PR0 (DQ bus impedance Control) (and also from 40 to 34) without any difference.
Let me know your opinion about testing only ZPROG_ASYM_PD_DRV to 48 (or maybe a higher value).
Emanuele
2,503 次查看
pengyong_zhang
Hi @emanuele79
Then, i think you should ask the Nanya's vendor talk about this error. Ask if their DDR can pass this test at your test Scenario. It has nothing to do with DDR training.
B.R
2,497 次查看
emanuele79
already done. They expect the memory to work in these conditions.
I'm asking here to understand if we can tune the configuration to be able to fix these errors: termination, drive strength, latencies, and, in general, timings.
Emanuele
2,410 次查看
pengyong_zhang
Hi @emanuele79
Did you try use the Micron DRAM run the same test see if this error log will occurred too?
B.R
2,372 次查看
emanuele79
Hi @pengyong_zhang,
Yes, we did. It works without any error.
Emanuele
%3CLINGO-SUB%20id%3D%22lingo-sub-2118640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX8QM%20%E5%92%8C%20LPDDR4%20%E5%86%85%E5%AD%98%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2118640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E4%B8%BA%E6%82%A8%E4%BB%8B%E7%BB%8D%E5%8D%97%E4%BA%9A%20NT6AN512T32AV-J1I%3CA%20href%3D%22https%3A%2F%2Fwww.nanya.com%2Fen%2FProduct%2F4404%2FNT6AN512T32AV-J1I%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E(https%3A%2F%2Fwww.nanya.com%2Fen%2FProduct%2F4404%2FNT6AN512T32AV-J1I)%3C%2FA%3E%E6%88%91%E4%BB%AC%E7%9A%84%20Apalis%20iMX8%20(i.MX8QM)%20%E6%A8%A1%E5%9D%97%E4%B8%8A%E7%9A%84%E5%86%85%E5%AD%98%E5%8F%AF%E6%9B%BF%E4%BB%A3%20Micron%20MT53D512M32D2DS-046%20IT%3AD%20(%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.micron.com%2Fproducts%2Fmemory%2Fdram-components%2Flpddr4%2Fpart-catalog%2Fpart-detail%2Fmt53d512m32d2ds-046-ait-d%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3EMT53D512M32D2DS-046-AIT-D%20)%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%9F%A5%E7%9C%8B%E4%BA%86%E6%97%B6%E5%BA%8F%E8%A7%84%E6%A0%BC%EF%BC%8CNanya%20%E9%83%A8%E4%BB%B6%E4%BC%BC%E4%B9%8E%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E6%9B%BF%E6%8D%A2%20Micron%20%E9%83%A8%E4%BB%B6%EF%BC%8C%E5%9B%A0%E4%B8%BA%E4%B8%A4%E8%80%85%E7%9A%84%E6%97%B6%E5%BA%8F%E8%A6%81%E6%B1%82%E4%BC%BC%E4%B9%8E%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E4%B8%8E%E7%BE%8E%E5%85%89%E7%89%88%E6%9C%AC%EF%BC%88Linux%20%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%20%2B%20Memtester%20%5Bmem%20%3CA%20href%3D%22https%3A%2F%2Fpyropus.ca.%2Fsoftware%2Fmemtester%2Fold-versions%2Fmemtester-4.6.0.tar.gz%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Etester-4.6.0.tar.gz%3C%2FA%3E%5D%20%E7%9B%B8%E5%90%8C%E7%9A%84%E6%B5%8B%E8%AF%95%E8%AE%BE%E7%BD%AE%EF%BC%89%E6%B5%8B%E8%AF%95%E4%BA%86%E5%87%A0%E4%B8%AA%E9%85%8D%E5%A4%87%20Nanya%20%E5%86%85%E5%AD%98%E7%9A%84%E6%A8%A1%E5%9D%97%E3%80%82%E5%BD%93%E7%84%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E8%BF%98%E5%9C%A8%E7%BE%8E%E5%85%89%E6%A8%A1%E5%9D%97%E4%B8%8A%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3ENanya%20%E5%86%85%E5%AD%98%E5%9C%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%E5%86%85%E8%A1%A8%E7%8E%B0%E8%89%AF%E5%A5%BD%EF%BC%8C%E4%BD%86%E5%9C%A8%E8%BE%83%E9%AB%98%E7%9A%84%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%E5%86%85%EF%BC%88%E7%BA%A6%2050%C2%B0C%20%E8%87%B3%E7%BA%A6%2080%C2%B0C%EF%BC%89%EF%BC%8C%E6%88%91%E4%BB%AC%E5%9C%A8%20Memtester%20%E7%9A%84%20Bit%20Spread%EF%BC%88%E4%BD%86%E4%B8%8D%E6%98%AF%E5%94%AF%E4%B8%80%E7%9A%84%EF%BC%89%E6%B5%8B%E8%AF%95%E4%B8%AD%E8%A7%82%E5%AF%9F%E5%88%B0%E4%BB%A5%E4%B8%8B%E6%95%85%E9%9A%9C%EF%BC%88%E8%BF%99%E4%BA%9B%E6%95%85%E9%9A%9C%E6%98%AF%E6%88%91%E4%BB%AC%E9%81%87%E5%88%B0%E7%9A%84%E6%95%85%E9%9A%9C%E6%80%BB%E6%95%B0%E7%9A%84%E4%B8%80%E9%83%A8%E5%88%86%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%A4%B1%E8%B4%A5%EF%BC%9A%E5%81%8F%E7%A7%BB%E9%87%8F%200x00000000031a9a80%20%E4%B8%AD%E7%9A%84%200xffffffffffffffffffff%20!%3D%200xfffffffffffbffffffffff.%3CBR%20%2F%3E%E5%A4%B1%E8%B4%A5%EF%BC%9A%E5%81%8F%E7%A7%BB%E9%87%8F%200x0000000009eb5440%20%E4%B8%AD%E7%9A%84%200xffffffffffffffffffff%20!%3D%200xfffffffffffbffffffffff.%3CBR%20%2F%3E%E6%95%85%E9%9A%9C%EF%BC%9A%E5%81%8F%E7%A7%BB%E9%87%8F%200x000000000172b040%20%E4%B8%AD%E7%9A%84%200xffffffffffffffffffff%20!%3D%200xfffffffffffbffffffff%E3%80%82%3CBR%20%2F%3E%E6%95%85%E9%9A%9C%EF%BC%9A%E5%81%8F%E7%A7%BB%E9%87%8F%200x000000000792e570%20%E4%B8%AD%E7%9A%84%200xfffffffffbffffffff%20!%3D%200xffffffffffffffffffffff%E3%80%82%3CBR%20%2F%3EFAILURE%3A%200xffffffffffffffff%20!%3D%200xfffffffffbffffff%20at%20offset%200x000000000a13fb00.%3C%2FP%3E%3CP%3E%E5%80%BC%E5%BE%97%E6%B3%A8%E6%84%8F%E7%9A%84%E6%98%AF%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%BD%93%E6%88%91%E4%BB%AC%E5%9C%A8%20-40%C2%B0C%20%E5%BC%80%E5%A7%8B%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%B9%B6%E5%9C%A8%E4%B8%8D%E9%87%8D%E5%90%AF%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%8D%87%E8%87%B3%2085%C2%B0C%20%E6%97%B6%EF%BC%8C%E6%89%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E4%BA%9B%E9%94%99%E8%AF%AF%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%AC%E4%BB%8E%2085%C2%B0C%20%E5%BC%80%E5%A7%8B%E6%B5%8B%E8%AF%95%EF%BC%8C%E7%84%B6%E5%90%8E%E9%99%8D%E6%B8%A9%E8%87%B3%20-40%C2%B0C%EF%BC%8C%E5%88%99%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%BB%BB%E4%BD%95%E8%AF%AF%E5%B7%AE%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BB%AC%E6%80%80%E7%96%91%20LPDDR4%20%E5%9C%A8%E9%9B%B6%E4%B8%8B%2040%20%E5%BA%A6%E8%BF%9B%E8%A1%8C%E8%AE%AD%E7%BB%83%E4%BC%9A%E5%BD%B1%E5%93%8D%E5%86%85%E5%AD%98%E7%9A%84%E5%8F%AF%E9%9D%A0%E6%80%A7%EF%BC%88%E5%9C%A8%E9%9B%B6%E4%B8%8B%2040%20%E5%BA%A6%E8%BF%9B%E8%A1%8C%E8%AE%AD%E7%BB%83%E6%97%B6%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%BF%A1%E5%8F%B7%E5%AE%8C%E6%95%B4%E6%80%A7%E9%97%AE%E9%A2%98%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%BF%98%E8%BD%AC%E5%82%A8%E4%BA%86%E4%B8%80%E4%BA%9B%E4%B8%8E%E5%86%85%E5%AD%98%E8%AE%AD%E7%BB%83%E6%9C%89%E5%85%B3%E7%9A%84%20DDR%20%E6%8E%A7%E5%88%B6%E5%99%A8%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B3%A8%E6%84%8F%E5%88%B0%E4%B8%A4%E7%A7%8D%E5%86%85%E5%AD%98%E7%B1%BB%E5%9E%8B%E4%B9%8B%E9%97%B4%E5%AD%98%E5%9C%A8%E6%98%BE%E8%91%97%E5%B7%AE%E5%BC%82%EF%BC%88%E8%A7%81%E9%99%84%E4%BB%B6%EF%BC%89%E3%80%82%E6%88%91%E4%BB%AC%E6%80%80%E7%96%91%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E4%B8%BA%E5%8D%97%E4%BA%9A%E5%86%85%E5%AD%98%E8%B0%83%E6%95%B4%E6%9F%90%E4%BA%9B%E7%BB%88%E6%AD%A2%E6%88%96%E9%A9%B1%E5%8A%A8%E5%BC%BA%E5%BA%A6%E5%8F%82%E6%95%B0%EF%BC%8C%E4%BD%86%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%98%AF%E5%93%AA%E4%BA%9B%E5%8F%82%E6%95%B0%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%BF%98%E9%99%84%E4%B8%8A%E4%BA%86%20RPA%EF%BC%88%E5%AF%84%E5%AD%98%E5%99%A8%E7%BC%96%E7%A8%8B%E8%BE%85%E5%8A%A9%E5%B7%A5%E5%85%B7%EF%BC%89Excel%20%E8%A1%A8%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E7%9B%AE%E5%89%8D%E7%94%A8%E4%BA%8E%E4%B8%A4%E7%A7%8D%E5%86%85%E5%AD%98%E7%B1%BB%E5%9E%8B%E7%9A%84%20DDR%20%E6%8E%A7%E5%88%B6%E5%99%A8%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A2%E8%BF%8E%E6%8F%90%E5%87%BA%E4%BB%BB%E4%BD%95%E6%84%8F%E8%A7%81%E6%88%96%E5%BB%BA%E8%AE%AE%EF%BC%8C%E4%BD%86%E5%85%B7%E4%BD%93%E6%9D%A5%E8%AF%B4%EF%BC%8C%E6%88%91%E4%BB%AC%E6%9C%89%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E5%AF%B9%E8%AE%AD%E7%BB%83%E7%BB%93%E6%9E%9C%E5%AF%84%E5%AD%98%E5%99%A8%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%E6%98%AF%E5%90%A6%E6%9C%89%E5%8A%A9%E4%BA%8E%E6%89%BE%E5%87%BA%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E6%88%96%E7%AA%81%E5%87%BA%E4%B8%A4%E7%A7%8D%E5%AD%98%E5%82%A8%E5%99%A8%E7%B1%BB%E5%9E%8B%E4%B9%8B%E9%97%B4%E7%9A%84%E5%85%B3%E9%94%AE%E5%B7%AE%E5%BC%82%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E4%BD%A0%E5%AF%B9%E5%86%85%E5%AD%98%E9%85%8D%E7%BD%AE%E6%9C%89%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%E4%BB%A5%E6%94%B9%E5%96%84%E8%AE%AD%E7%BB%83%E5%92%8C%E4%BF%A1%E5%8F%B7%E5%AE%8C%E6%95%B4%E6%80%A7%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2118640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F88010%22%20target%3D%22_blank%22%3E%40hongting_dong%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%B8%A4%E7%A7%8D%E4%B8%8D%E5%90%8C%E7%9A%84%E5%A4%96%E9%83%A8%E6%B8%A9%E5%BA%A6%E4%B8%8B%E8%BF%9B%E8%A1%8C%E9%87%87%E9%9B%86%EF%BC%9A-20%EF%BC%88%E5%9B%BA%E5%AE%9A%E6%B8%A9%E5%BA%A6%E4%B8%8B%202%20%E5%B0%8F%E6%97%B6%E5%90%8E%EF%BC%89%E5%92%8C%20%2B25%EF%BC%88%E5%BC%80%E5%90%AF%2030%20%E5%88%86%E9%92%9F%E5%90%8E%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3EDDR0%20%E5%AD%97%E8%8A%82%202%20%E5%BE%88%E5%A5%87%E6%80%AA%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E4%BD%A0%E7%9A%84%E7%9C%8B%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%9F%83%E9%A9%AC%E5%8A%AA%E5%9F%83%E8%8E%B1%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CUL%20style%3D%22font-weight%3A%20400%3B%22%3E%0A%3CLI%3E%3CSPAN%20data-olk-copy-source%3D%22MessageBody%22%3E%E5%88%9B%E5%BB%BA%E5%9F%BA%E7%BA%BF%E5%B9%B6%E7%86%9F%E6%82%89%E5%86%99%E5%85%A5%E7%9C%BC%E7%94%9F%E6%88%90%E7%A8%8B%E5%BA%8F%E5%90%8E%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BB%BA%E8%AE%AE%E9%87%87%E5%8F%96%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E8%BF%9B%E8%A1%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E8%AF%95%EF%BC%9A%3C%2FSPAN%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3E%E5%B0%86%E6%89%80%E9%9C%80%E7%9A%84%20LP4%20%E8%AE%BE%E5%A4%87%E9%99%8D%E8%87%B3%20-40C%EF%BC%88%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E5%AE%9E%E9%AA%8C%E5%AE%A4%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%83%AD%E6%B5%81%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E8%BE%BE%E5%88%B0-40%E6%91%84%E6%B0%8F%E5%BA%A6%E5%90%8E%EF%BC%8C%E5%90%AF%E5%8A%A8%E6%9D%BF%E5%B9%B6%E5%90%AF%E5%8A%A8VTSA%E5%B7%A5%E5%85%B7%EF%BC%88%E6%AD%A4%E6%97%B6%EF%BC%8C%E6%83%B3%E6%B3%95%E6%98%AF%E5%B0%86DDR%E5%9C%A8-40%E6%91%84%E6%B0%8F%E5%BA%A6%E4%B8%8B%E5%88%9D%E5%A7%8B%E5%8C%96%2F%E8%AE%AD%E7%BB%83%EF%BC%89%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E5%9C%A8%E6%AF%8F%E4%B8%AA%E5%AD%97%E8%8A%82%E9%80%9A%E9%81%93%E4%B8%8A%E6%89%A7%E8%A1%8C%20Write%20Eye%20%E6%B5%8B%E8%AF%95%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E5%B0%86%E6%B8%A9%E5%BA%A6%E6%8F%90%E9%AB%98%E5%88%B0%2025C%EF%BC%8C%E6%97%A0%E9%9C%80%E9%80%9A%E7%94%B5%E3%80%81%E5%BE%AA%E7%8E%AF%2F%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E6%9D%BF%E6%88%96%E5%B7%A5%E5%85%B7%EF%BC%8C%E5%8D%B3%E5%8F%AF%E5%B0%86%E7%BB%8F%E8%BF%87%E8%AE%AD%E7%BB%83%E7%9A%84%E5%80%BC%E4%BF%9D%E6%8C%81%E5%9C%A8%20-40C%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E5%9C%A8%2025C%20%E6%B8%A9%E5%BA%A6%E4%B8%8B%EF%BC%8C%E5%AF%B9%E6%AF%8F%E4%B8%AA%E6%97%81%E8%B7%AF%E9%87%8D%E6%96%B0%E8%BF%9B%E8%A1%8C%20%22%E5%86%99%E7%9C%BC%20%22%E6%93%8D%E4%BD%9C%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E5%AE%8C%E6%88%90%E5%90%8E%EF%BC%8C%E5%B0%86%E6%B8%A9%E5%BA%A6%E6%8F%90%E9%AB%98%E5%88%B085%E6%91%84%E6%B0%8F%E5%BA%A6%EF%BC%8C%E6%97%A0%E9%9C%80%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E6%9D%BF%E6%88%96%E5%B7%A5%E5%85%B7%EF%BC%8C%E5%8D%B3%E5%8F%AF%E5%B0%86%E7%BB%8F%E8%BF%87%E8%AE%AD%E7%BB%83%E7%9A%84%E5%80%BC%E4%BF%9D%E6%8C%81%E5%9C%A8-40%E6%91%84%E6%B0%8F%E5%BA%A6%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%E5%9C%A8%2085C%20%E6%B8%A9%E5%BA%A6%E4%B8%8B%EF%BC%8C%E5%AF%B9%E6%AF%8F%E4%B8%AA%E6%97%81%E8%B7%AF%E9%87%8D%E6%96%B0%E8%BF%9B%E8%A1%8C%20%22%E5%86%99%E7%9C%BC%20%22%E6%93%8D%E4%BD%9C%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FiMX-and-Vybrid-Support%2Fi-MX8QM-i-MX8QXP-i-MX8DXL-DRAM-Virtual-Timing-and-Signal%2Fta-p%2F1321350%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FiMX-and-Vybrid-Support%2Fi-MX8QM-i-MX8QXP-i-MX8DXL-DRAM-Virtual-Timing-and-Signal%2Fta-p%2F1321350%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%EF%BC%8C%E8%AF%B7%E6%8F%90%E4%BE%9B%20iMX8QM%20%E7%9A%84%20VTSA%E3%80%82%3CBR%20%2F%3E%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E8%BF%99%E7%A7%8D%20SoC%20%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E5%B7%A5%E5%85%B7%E3%80%82%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3E%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%83%B3%E5%8A%A0%E5%80%8D%E4%BA%86%E8%A7%A3%E4%B8%80%E4%BA%9B%E7%BB%86%E8%8A%82%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-olk-copy-source%3D%22MessageBody%22%3E1.%20%E4%BD%A0%E8%83%BD%E7%94%A8%E6%9B%B4%E9%AB%98%E7%9A%84%E7%94%B5%E5%8E%8B%E6%B5%8B%E8%AF%95%E5%90%AF%E5%8A%A8%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-olk-copy-source%3D%22MessageBody%22%3E2.%20%E6%82%A8%E8%83%BD%E5%90%A6%E8%8E%B7%E5%BE%97%20VTSA%20%E7%BB%93%E6%9E%9C%EF%BC%8C%E4%BB%A5%E4%BA%86%E8%A7%A3%20NANYA%20%E4%BD%99%E9%87%8F%E5%9C%A8%E4%BD%8E%E6%B8%A9%E6%88%96%E8%B7%A8%E6%B8%A9%E6%9D%A1%E4%BB%B6%E4%B8%8B%E6%98%AF%E5%90%A6%E4%B8%8D%E4%BD%B3%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-olk-copy-source%3D%22MessageBody%22%3E3.%20%E5%9C%A8%E5%8E%86%E5%8F%B2%E8%AE%B0%E5%BD%95%E4%B8%AD%EF%BC%8C%E6%9B%B4%E6%94%B9%20ODT%20%2F%20%E7%A1%AC%E7%9B%98%E5%BC%BA%E5%BA%A6%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-olk-copy-source%3D%22MessageBody%22%3E4.%20%E5%A6%82%E6%9E%9C%E5%B0%86%20CA%20Vref%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%200%EF%BC%8C%E6%9C%89%E4%BB%80%E4%B9%88%E5%B8%AE%E5%8A%A9%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-olk-copy-source%3D%22MessageBody%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-olk-copy-source%3D%22MessageBody%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E8%AF%B4%E5%BE%97%E5%AF%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%22DQS%20%E9%97%B4%E9%9A%94%E6%8C%AF%E8%8D%A1%E5%99%A8%22%20%E6%95%B0%E6%8D%AE%E8%A1%A8%E7%AB%A0%E8%8A%82%E7%9A%84%E8%A1%A5%E5%85%85%E8%AF%B4%E6%98%8E%E4%B9%9F%E5%9C%A8%20JEDEC%20%E7%AC%AC%20209-4%20%E5%8F%B7%E6%A0%87%E5%87%86%EF%BC%9A%22%E4%BD%8E%E5%8A%9F%E8%80%97%E5%8F%8C%E5%80%8D%E6%95%B0%E6%8D%AE%E9%80%9F%E7%8E%87%204%20(LPDDR4)%22%20%E4%B8%AD%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%8A%A5%E5%91%8A%E3%80%82%3CBR%20%2F%3EBR%2C%3CBR%20%2F%3EEmanuele%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%20%E4%BD%A0%E5%A5%BD%E3%80%81%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%E6%95%B0%E6%8D%AE%E8%A1%A8%E6%8A%A5%E5%91%8A%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3EDQS%20%E9%97%B4%E9%9A%94%E6%8C%AF%E8%8D%A1%E5%99%A8%E9%9A%8F%3CBR%20%2F%3E%E7%9D%80%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(SDRAM)%E8%8A%AF%E7%89%87%E4%B8%8A%E7%94%B5%E5%8E%8B%E5%92%8C%E6%B8%A9%E5%BA%A6%E7%9A%84%E5%8F%98%E5%8C%96%EF%BC%8CDQS%20%E6%97%B6%E9%92%9F%E6%A0%91%E5%BB%B6%E8%BF%9F%E5%B0%86%E5%8F%91%E7%94%9F%E5%8F%98%E5%8C%96%EF%BC%8C%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E9%87%8D%E6%96%B0%E8%AE%AD%E7%BB%83%E3%80%82%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E8%BF%99%E8%A1%A8%E6%98%8E%EF%BC%8CDQS2DQ%20%E5%9F%B9%E8%AE%AD%E5%BA%94%E5%BE%97%E5%88%B0%E6%94%AF%E6%8C%81%EF%BC%8C%E8%80%8C%E4%B8%94%E5%9C%A8%E6%9F%90%E4%BA%9B%E6%83%85%E5%86%B5%E4%B8%8B%E5%8F%AF%E8%83%BD%E6%98%AF%E5%BF%85%E8%A6%81%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E6%98%AF%E5%90%A6%E8%80%83%E8%99%91%E8%BF%87%E7%A6%81%E7%94%A8%20DQS2DQ%20%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%9F%90%E4%BA%9B%E4%BE%9D%E8%B5%96%E8%AF%A5%E8%AE%AD%E7%BB%83%E7%9A%84%E5%86%85%E5%AD%98%E8%8A%AF%E7%89%87%E5%87%BA%E7%8E%B0%E6%95%85%E9%9A%9C%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E8%83%BD%E5%90%A6%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E7%A1%AE%E5%AE%9A%E4%B8%80%E7%A7%8D%E5%8F%98%E9%80%9A%E5%8A%9E%E6%B3%95%E6%88%96%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E5%B9%B6%E8%AF%84%E4%BC%B0%E5%BD%93%E5%89%8D%E7%9A%84%E5%8B%98%E8%AF%AF%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%A7%82%E5%AF%9F%E5%88%B0%E4%BB%A5%E4%B8%8B%E8%A1%8C%E4%B8%BA%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%AC%E4%BB%8E%2085%20%C2%B0C%20%E5%BC%80%E5%A7%8B%E6%B5%8B%E8%AF%95%EF%BC%8C%E7%84%B6%E5%90%8E%E8%AE%A9%E6%B8%A9%E5%BA%A6%E9%99%8D%E8%87%B3%20-40%20%C2%B0C%EF%BC%8C%E5%88%99%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%3C%2FLI%3E%3CLI%3E%E7%9B%B8%E5%8F%8D%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%AC%E4%BB%8E%E8%BE%83%E4%BD%8E%E7%9A%84%E6%B8%A9%E5%BA%A6%EF%BC%88%E5%A6%82-10%20%C2%B0C%EF%BC%89%E5%BC%80%E5%A7%8B%E5%8D%87%E6%B8%A9%EF%BC%88%E5%A6%82%E5%8D%87%E8%87%B3%2060%20%C2%B0C%EF%BC%89%EF%BC%8C%E5%8D%B3%E4%BD%BF%E5%9C%A8%E8%BF%99%E4%B8%AA%E8%BE%83%E4%BD%8E%E7%9A%84%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%E5%86%85%EF%BC%8C%E6%88%91%E4%BB%AC%E4%B9%9F%E8%83%BD%E8%A7%82%E5%AF%9F%E5%88%B0%E5%86%85%E5%AD%98%E6%95%85%E9%9A%9C%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%88%91%E4%BB%AC%E8%BF%98%E6%B3%A8%E6%84%8F%E5%88%B0%EF%BC%8C%E5%AE%9A%E6%9C%9F%E6%9A%82%E5%81%9C%E5%88%B0%20RAM%20%E5%B9%B6%E6%81%A2%E5%A4%8D%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E6%98%AF%E5%9B%A0%E4%B8%BA%EF%BC%8C%E6%AD%A3%E5%A6%82%E6%82%A8%E6%89%80%E6%8F%90%E5%88%B0%E7%9A%84%EF%BC%8CDQS2DQ%20%E8%AE%AD%E7%BB%83%E6%98%AF%E5%9C%A8%E6%81%A2%E5%A4%8D%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%89%A7%E8%A1%8C%E7%9A%84%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%88%91%E4%BB%AC%E5%90%AF%E7%94%A8%E4%BA%86%20DQS2DQ%20%E8%AE%AD%E7%BB%83%EF%BC%8C%E4%BD%86%E9%81%97%E6%86%BE%E7%9A%84%E6%98%AF%EF%BC%8C%E7%BB%93%E6%9E%9C%E4%BB%8D%E7%84%B6%E6%98%AF%E8%B4%9F%E7%9A%84%EF%BC%88%E7%94%9A%E8%87%B3%E6%9B%B4%E7%B3%9F%EF%BC%89%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E5%AF%B9%E6%82%A8%E7%9A%84%E5%88%86%E6%9E%90%E6%9C%89%E7%94%A8%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EEmanuele%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%B5%8B%E8%AF%95%E4%BA%86%E6%89%80%E6%9C%89%E4%BB%8B%E4%BA%8E%200x40%20%E5%92%8C%200x47%20%E4%B9%8B%E9%97%B4%E7%9A%84%20MR12%20%E5%80%BC%E3%80%82%3C%2FP%3E%3CP%3E%E4%BA%B2%E5%88%87%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EEmanuele%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%EF%BC%8C%E9%99%A4%E4%BA%86%3CSPAN%3E%E5%9C%A8%E8%BF%90%E8%A1%8C%E8%BF%87%E7%A8%8B%E4%B8%AD%20%3C%2FSPAN%3E%E7%A6%81%E7%94%A8DQS2DQ%20%E8%AE%AD%E7%BB%83%20%E5%A4%96%EF%BC%8C%E5%88%AB%E6%97%A0%E4%BB%96%E6%B3%95%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E9%A1%BA%E4%BE%BF%E9%97%AE%E4%B8%80%E4%B8%8B%EF%BC%9A%E6%82%A8%E7%9A%84%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E5%A6%82%E4%BD%95%EF%BC%8C%E6%88%91%E4%B9%8B%E5%89%8D%E5%91%8A%E8%AF%89%E8%BF%87%E6%82%A8%E9%80%9A%E8%BF%87%E6%9B%B4%E6%94%B9%20MR12%20%E7%9A%84%E5%80%BC%E6%9D%A5%E6%9B%B4%E6%94%B9%20CA%20Vref%EF%BC%8C%E5%B9%B6%E4%B8%94%E9%99%A4%E4%BA%86%20MR12%20%E4%B9%8B%E5%A4%96%E4%B8%8D%E8%A6%81%E6%9B%B4%E6%94%B9%E4%BB%BB%E4%BD%95%E5%8F%82%E6%95%B0%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EB.R%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146173%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146173%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%20%E4%BD%A0%E5%A5%BD%E3%80%81%3C%2FP%3E%3CP%3E%E9%99%A4%E4%BA%86%E5%AE%8C%E5%85%A8%E7%A6%81%E7%94%A8%E4%B9%8B%E5%A4%96%EF%BC%8C%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E9%80%89%E6%8B%A9%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%BA%B2%E5%88%87%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EEmanuele%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2145701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2145701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E7%9A%84%E5%9C%A8%E5%8B%98%E8%AF%AF%E8%A1%A8%E4%B8%AD%EF%BC%8CERR050102%EF%BC%9A%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(DRAM)%EF%BC%9A%E4%B8%8D%E6%94%AF%E6%8C%81%E5%AE%9A%E6%9C%9F%E8%BF%9B%E8%A1%8C%E5%9F%BA%E4%BA%8E%E7%A1%AC%E4%BB%B6%E7%9A%84%20DQS2DQ%20%E6%A0%A1%E5%87%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B4%E6%98%8E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E5%90%AF%E7%94%A8%E5%9F%BA%E4%BA%8E%E7%A1%AC%E4%BB%B6%E7%9A%84%20DQS2DQ%20%E5%91%A8%E6%9C%9F%E6%80%A7%E6%A0%A1%E5%87%86%EF%BC%8C%E7%94%B1%E6%AD%A4%E4%BA%A7%E7%94%9F%E7%9A%84%E5%BB%B6%E8%BF%9F%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%9F%90%E4%BA%9B%E5%85%B3%E9%94%AE%E5%AD%90%E7%B3%BB%E7%BB%9F%EF%BC%88%E5%A6%82%E6%98%BE%E7%A4%BA%E5%92%8C%E6%88%90%E5%83%8F%E6%8E%A5%E5%8F%A3%EF%BC%89%E5%87%BA%E7%8E%B0%E8%BF%90%E8%A1%8C%E4%B8%8D%E8%B6%B3%E3%80%81%3CBR%20%2F%3E%E6%88%96%E6%9C%80%E5%9D%8F%E6%83%85%E5%86%B5%E4%B8%8B%E5%87%BA%E7%8E%B0%E9%94%81%E5%AE%9A%EF%BC%8C%E4%BB%8E%E8%80%8C%E5%BD%B1%E5%93%8D%E5%85%B6%3CBR%20%2F%3E%E6%80%A7%E8%83%BD%E3%80%82%3CBR%20%2F%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%3CBR%20%2F%3E%E5%BD%93%E5%89%8D%EF%BC%8CDQS2DQ%20%E6%A0%A1%E5%87%86%E4%BB%85%E5%9C%A8%E5%BC%80%E6%9C%BA%E6%97%B6%E4%BB%A5%E5%8F%8A%E4%BB%8E%E4%BD%8E%E5%8A%9F%E8%80%97%E7%94%B5%E6%BA%90%E6%A8%A1%E5%BC%8F%E6%81%A2%E5%A4%8D%E6%97%B6%E8%BF%9B%E8%A1%8C%E3%80%82%E8%BF%84%E4%BB%8A%E4%B8%BA%E6%AD%A2%EF%BC%8C%E5%9C%A8%E6%95%B4%E4%B8%AA%E5%B7%A5%E8%89%BA%E3%80%81%E7%94%B5%E5%8E%8B%E5%92%8C%E6%B8%A9%E5%BA%A6%E8%8C%83%E5%9B%B4%E5%86%85%E5%9D%87%E6%9C%AA%E5%8F%91%E7%8E%B0%E6%95%85%E9%9A%9C%E6%88%96%3CBR%20%2F%3E%E7%A8%B3%E5%AE%9A%E6%80%A7%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%3C%2FP%3E%3CP%3E%E5%9F%83%E9%A9%AC%E5%8A%AA%E5%9F%83%E8%8E%B1%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ENanya%20%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E6%98%AF%E7%94%B1%E4%BA%8E%E6%9D%BF%E5%9C%A8%E6%93%8D%E4%BD%9C%E6%9C%9F%E9%97%B4%E6%B2%A1%E6%9C%89%E5%AE%9A%E6%9C%9F%E8%BF%9B%E8%A1%8C%20DQS2DQ%20%E5%9F%B9%E8%AE%AD%E9%80%A0%E6%88%90%E7%9A%84%EF%BC%9F%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2142609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142609%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40%E5%BC%A0%E9%B9%8F%E5%8B%87%3C%2FA%3E%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F88010%22%20target%3D%22_blank%22%3E%40%E8%91%A3%E8%99%B9%E5%A9%B7%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E5%8D%97%E4%BA%9A%E5%85%AC%E5%8F%B8%E5%AF%B9%E8%BF%99%E4%BA%9B%E8%A1%8C%E4%B8%BA%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%88%86%E6%9E%90%EF%BC%8C%E5%BE%97%E5%87%BA%E4%BA%86%E4%BB%A5%E4%B8%8B%E7%BB%93%E8%AE%BA%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%3CBR%20%2F%3E%E6%A0%B9%E6%8D%AE%20LA%20MRS%20%E8%AE%BE%E7%BD%AE%E7%A1%AE%E8%AE%A4%EF%BC%8CMR18%2FMR19%20%E5%9C%A8%E8%AE%B0%E5%BF%86%E6%B5%8B%E8%AF%95%E6%9C%9F%E9%97%B4%E8%A2%AB%E7%A6%81%E7%94%A8%E3%80%82%3CBR%20%2F%3ENTC%20%E5%BB%BA%E8%AE%AE%E5%9C%A8%E5%B9%B3%E5%8F%B0%E4%B8%8A%E5%90%AF%E7%94%A8%20MR18%2FMR19%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%A6%82%E6%9E%9C%E5%B9%B3%E5%8F%B0%E4%B8%8D%E6%89%A7%E8%A1%8C%20Tdqs2dq%20%E5%81%8F%E7%A7%BB%EF%BC%8C%E5%88%99%E9%BB%98%E8%AE%A4%E8%AE%BE%E7%BD%AE%E5%8F%AF%E8%83%BD%E6%97%A0%E6%B3%95%E6%BB%A1%E8%B6%B3%20NTC%20%E8%AE%BE%E5%A4%87%E7%9A%84%E8%A6%81%E6%B1%82%E3%80%82%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E6%88%91%E5%9C%A8%20RPA%E3%80%81SCFW%20%E6%88%96%20i.MX8QM%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E4%BB%BB%E4%BD%95%E4%B8%8E%20MR18%2FMR19%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%9B%B8%E5%85%B3%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%88%96%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%E8%BF%99%E4%BA%9B%E6%98%AF%20RAM%20%E4%BE%A7%E7%9A%84%E5%8F%AA%E8%AF%BB%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%E6%98%AF%E5%86%85%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%E6%88%96%20SCFW%20%E5%BA%94%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%97%B6%E8%AF%BB%E5%8F%96%E5%B9%B6%E4%BD%BF%E7%94%A8%E5%AE%83%E4%BB%AC%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E7%A1%AE%E5%AE%9A%E6%88%91%E4%BB%AC%E8%AF%A5%E5%A6%82%E4%BD%95%E7%BB%A7%E7%BB%AD%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%9F%83%E9%A9%AC%E5%8A%AA%E5%9F%83%E8%8E%B1%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2125170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2125170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%BF%9D%E6%8C%81%3CSPAN%3EZPROG_ASYM_PD_DRV_DQ_48%20%E5%92%8C%20ZPROG_ASYM_PD_DRV_DQ_60%20%E4%B8%BA%E9%BB%98%E8%AE%A4%E5%80%BC%E3%80%82%E8%AF%B7%E5%8B%BF%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%84%B6%E5%90%8E%E9%80%90%E6%AD%A5%E6%B5%8B%E8%AF%95%E4%B8%8D%E5%90%8C%E7%9A%84%20MR12%20%E5%80%BC%E3%80%82%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E9%87%8D%E7%8E%B0%E4%BD%A0%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E6%B2%A1%E6%9C%89%E4%BD%A0%E7%9A%84%E6%B5%8B%E8%AF%95%E6%9D%BF%E5%92%8C%E7%8E%AF%E5%A2%83%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E8%87%AA%E5%B7%B1%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%8C%E6%89%BE%E5%88%B0%E5%90%88%E9%80%82%E7%9A%84%20Vref%20%E5%80%BC%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E6%9C%80%E5%A5%BD%E7%9A%84%E5%8A%9E%E6%B3%95%E8%BF%98%E6%98%AF%E8%AF%B7%20Nanya%20%E8%B0%88%E8%AE%BA%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E7%9C%8B%E7%9C%8B%E4%BB%96%E4%BB%AC%E8%83%BD%E5%90%A6%E9%87%8D%E7%8E%B0%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E5%B9%B6%E7%BB%99%E5%87%BA%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EB.R%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2124736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2124736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%20%E4%BD%A0%E5%A5%BD%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%B5%8B%E8%AF%95%E4%BA%86%20MR12%EF%BC%8C%E5%8F%AA%E6%98%AF%E5%B0%86%200x47%20%E6%9B%B4%E6%94%B9%E4%B8%BA%200x40%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E5%8F%8A%20ZPROG_ASYM_PD_DRV_DQ_48%20%E5%92%8C%20ZPROG_ASYM_PD_DRV_DQ_60%E3%80%82%3C%2FP%3E%3CP%3E%E6%AF%8F%E6%AC%A1%E9%85%8D%E7%BD%AE%E9%83%BD%E5%A4%B1%E8%B4%A5%E3%80%82%3CBR%20%2F%3E%E6%88%91%E7%9C%9F%E7%9A%84%E4%B8%8D%E7%9F%A5%E9%81%93%E8%BF%99%E4%BA%9B%E6%B5%8B%E8%AF%95%E6%98%AF%E5%A5%BD%E6%98%AF%E5%9D%8F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BA%B2%E5%88%87%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EEmanuele%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2123506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2123506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%BF%90%E8%A1%8C%E4%BA%86%E5%85%B3%E4%BA%8E%20MR12%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%9B%B4%E6%94%B9%E7%9A%84%E6%B5%8B%E8%AF%95%E5%90%97%EF%BC%9F%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E5%A6%82%E4%BD%95%EF%BC%9F%E8%BF%90%E8%A1%8C%E6%AD%A4%E6%B5%8B%E8%AF%95%E6%97%B6%EF%BC%8C%E9%99%A4%E4%BA%86%20MR12%20%E4%B9%8B%E5%A4%96%EF%BC%8C%E4%B8%8D%E8%A6%81%E6%9B%B4%E6%94%B9%E4%BB%BB%E4%BD%95%E5%8F%82%E6%95%B0%E3%80%82%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2123209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2123209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40%E5%BC%A0%E9%B9%8F%E5%8B%87%3C%2FA%3E%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F88010%22%20target%3D%22_blank%22%3E%40%E8%91%A3%E8%99%B9%E5%A9%B7%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%90%A6%E7%89%B9%E5%88%AB%E5%85%B3%E6%B3%A8%E8%BF%99%E4%B8%80%E4%BA%8B%E5%AE%9E%EF%BC%9A%3C%2FP%3E%3CP%3E%26gt%3B%20%E5%80%BC%E5%BE%97%E6%B3%A8%E6%84%8F%E7%9A%84%E6%98%AF%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%BD%93%E6%88%91%E4%BB%AC%E5%9C%A8%20-40%C2%B0C%20%E5%BC%80%E5%A7%8B%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%B9%B6%E5%9C%A8%E4%B8%8D%E9%87%8D%E5%90%AF%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%8D%87%E8%87%B3%2085%C2%B0C%20%E6%97%B6%EF%BC%8C%E6%89%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E4%BA%9B%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%9C%E4%B8%BA%E4%B8%80%E7%A7%8D%E5%8F%98%E9%80%9A%E6%96%B9%E6%B3%95%EF%BC%8C%E6%88%91%E4%BB%AC%E8%83%BD%E5%90%A6%E9%80%9A%E8%BF%87%E4%BF%AE%E8%A1%A5%20scfw%EF%BC%8C%E5%9C%A8%E5%B7%A5%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%E9%87%8D%E6%96%B0%E8%A7%A6%E5%8F%91%E5%86%85%E5%AD%98%E8%AE%AD%E7%BB%83%EF%BC%9F%3CBR%20%2F%3E%E9%89%B4%E4%BA%8E%E6%88%91%E4%BB%AC%E6%8A%A5%E5%91%8A%E7%9A%84%E9%94%99%E8%AF%AF%E7%B1%BB%E5%9E%8B%EF%BC%88%E6%AF%94%E7%89%B9%E7%BF%BB%E8%BD%AC%EF%BC%89%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E7%BB%8F%E8%BF%87%E5%9F%B9%E8%AE%AD%E7%9A%84%22%E5%8F%82%E6%95%B0%22%20%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E6%89%BE%E5%87%BA%E6%A0%B9%E6%9C%AC%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%A2%84%E5%85%88%E8%87%B4%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3E%E3%80%82%3C%2FP%3E%3CP%3E%E5%9F%83%E9%A9%AC%E5%8A%AA%E5%9F%83%E8%8E%B1%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2123205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2123205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%20%E4%BD%A0%E5%A5%BD%E3%80%81%3C%2FP%3E%3CP%3E%E6%B5%8B%E8%AF%95%E4%BA%86%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E8%BF%98%E6%B5%8B%E8%AF%95%E4%BA%86%2040%20-%26gt%3B%2060%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%A4%E9%A1%B9%E6%B5%8B%E8%AF%95%E5%9D%87%E5%9C%A87%E4%B8%AA%E6%9D%BF%E4%B8%8A%E5%9D%87%E5%A4%B1%E8%B4%A5%EF%BC%8C%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E9%87%8D%E5%A4%A7%E5%8F%98%E5%8C%96%EF%BC%88%E6%94%B9%E5%96%84%E6%88%96%E6%81%B6%E5%8C%96%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2122643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2122643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E6%98%AF%E8%AF%B4%2024.8%EF%BC%8C24.4%E3%80%8124%20%E7%AD%89%E7%AD%89%E3%80%82%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2122352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2122352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%EF%BC%8C%E5%86%85%E5%AD%98%E4%B8%8A%E6%9C%89%E8%AE%B0%E5%BD%95%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%3ENanya2447%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ENT6AN512T32AV-J1I%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E9423W1EF%203%20TW%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E8%BF%99%E6%98%AF%E6%82%A8%E9%9C%80%E8%A6%81%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EEmanuele%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2122138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2122138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E4%BD%A0%E5%BB%BA%E8%AE%AE%E4%BF%AE%E6%94%B9%20MR12%EF%BC%8C%E6%88%91%E6%98%AF%E5%90%A6%E4%B9%9F%E8%A6%81%E4%BF%AE%E6%94%B9%20MR14%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E6%88%91%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E7%96%91%E9%97%AE%E3%80%82%E5%BD%93%E6%82%A8%E8%AF%B4%22%E6%B5%8B%E8%AF%95%E4%BB%8E%2025.2%25%20%E5%90%91%E4%B8%8B%22%20%E6%97%B6%EF%BC%8C%E6%82%A8%E6%8C%87%E7%9A%84%E6%98%AF%2024.8%20%E8%BF%98%E6%98%AF%2024.4%E3%80%8124%EF%BC%8C%E4%BB%A5%E6%AD%A4%E7%B1%BB%E6%8E%A8%EF%BC%8C%E8%BF%98%E6%98%AF%E5%8F%8D%E8%BF%87%E6%9D%A5%EF%BC%8825.6%EF%BC%8C26%EF%BC%8C26.6%EF%BC%8C%E4%BB%A5%E6%AD%A4%E7%B1%BB%E6%8E%A8%EF%BC%89%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3E%E3%80%82%3C%2FP%3E%3CP%3E%E5%9F%83%E9%A9%AC%E5%8A%AA%E5%9F%83%E8%8E%B1%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2121724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2121724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%98%E8%AF%B7%E6%9B%B4%E6%96%B0%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%0A%3CP%20class%3D%22x_MsoNormal%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22marko4lrvcpzz%22%20data-markjs%3D%22true%22%20data-ogac%3D%22%22%20data-ogab%3D%22%22%20data-ogsc%3D%22%22%20data-ogsb%3D%22%22%20data-olk-copy-source%3D%22MessageBody%22%3ENanya%3C%2FSPAN%3E%20%E6%95%85%E9%9A%9C%E8%AE%BE%E5%A4%87%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20class%3D%22x_MsoNormal%22%3E%3CSPAN%3EMFD%20%E6%97%A5%E6%9C%9F%E4%BB%A3%E7%A0%81%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20class%3D%22x_MsoNormal%22%3E%3CSPAN%3E%E6%89%B9%E5%8F%B7%E6%98%AF%20%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20class%3D%22x_MsoNormal%22%3E%3CSPAN%3E%E6%88%91%E8%AE%B0%E5%BE%97%E4%BD%A0%E8%AF%95%E8%BF%87%20Nanya%20%E7%9A%84%E6%9C%80%E6%96%B0%E8%AE%BE%E5%A4%87%E9%83%A8%E5%88%86%E4%BA%86%E5%90%97%EF%BC%8C%E4%BB%96%E4%BB%AC%E7%9A%84%E8%AE%BE%E5%A4%87%E9%83%A8%E4%BB%B6%E5%9C%A8%20ZQ%20cal%20%E4%B8%AD%E6%9C%89%E4%B8%80%E4%BA%9B%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20class%3D%22x_MsoNormal%22%3E%3CSPAN%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2121273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2121273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%BA%8B%E5%AE%9E%E4%B8%8A%EF%BC%8C%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E5%93%AA%E4%B8%AA%20DS%20%E5%80%BC%E6%88%96%20ODT%20%E5%80%BC%E8%83%BD%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%8F%A6%E4%B8%80%E7%A7%8D%E6%96%B9%E6%B3%95%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E9%80%9A%E8%BF%87%20SCFW%20imx8qm_dcd_1.6GHz.cfg%20%E6%96%87%E4%BB%B6%E4%BF%AE%E6%94%B9%20MR12%20%E5%80%BC%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%80%83%E4%BB%A5%E4%B8%8B%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%3CEM%3E%3CSTRONG%3EDATA%204%20DDR_PHY_MR12_0%200x48%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E5%B0%86%E6%B5%8B%E8%AF%95%E4%BB%8E%2025.2%25%20%E8%B0%83%E4%BD%8E%E3%80%82%20%E4%BE%9D%E6%AC%A1%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%20id%3D%22tinyMceEditor_643462c59b80a2pengyong_zhang_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pengyong_zhang_1-1750667443314.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_1-1750667443314.png%22%20style%3D%22width%3A%20366px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F344159i6748AF950A996F1E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pengyong_zhang_1-1750667443314.png%22%20alt%3D%22pengyong_zhang_1-1750667443314.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CP%3EB.R%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2120158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2120158%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang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id%3D%22lingo-sub-2119888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2119888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%94%B6%E5%88%B0%E6%82%A8%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%88%91%E4%BB%AC%E7%9A%84%20MX8QM_B0_LPDDR4_RPA_1.6GHz_v23.xlsx%20%E6%96%87%E4%BB%B6%EF%BC%8C%E9%80%89%E6%8B%A9%E4%B8%8D%E5%90%8C%E7%9A%84%20DS%20%E5%80%BC%EF%BC%8C%E7%84%B6%E5%90%8E%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%8C%E7%9C%8B%E7%9C%8B%E8%83%BD%E5%90%A6%E8%A7%A3%E5%86%B3%E6%AD%A4%E9%94%99%E8%AF%AF%E3%80%82%E5%9B%A0%E4%B8%BA%E6%82%A8%E7%9A%84%E9%94%99%E8%AF%AF%E6%98%AF%E5%9C%A8%E7%8E%AF%E5%A2%83%E6%B8%A9%E5%BA%A6%E4%BB%8E%E4%BD%8E%E5%88%B0%E9%AB%98%E6%97%B6%E5%8F%91%E7%94%9F%E7%9A%84%E3%80%82%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E5%8F%AF%E4%BB%A5%E8%AF%95%E8%AF%95%2040-%26gt%3B48%20%E7%9A%84%20DS%E3%80%82%E5%B9%B6%E6%9F%A5%E7%9C%8B%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pengyong_zhang_0-1750397500154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pengyong_zhang_0-1750397500154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F343863iF3363210DE890B0D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22pengyong_zhang_0-1750397500154.png%22%20alt%3D%22pengyong_zhang_0-1750397500154.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2119121%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2119121%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%E5%B7%B2%E7%BB%8F%E5%AE%8C%E6%88%90%E3%80%82%E4%BB%96%E4%BB%AC%E5%B8%8C%E6%9C%9B%E5%AD%98%E5%82%A8%E5%99%A8%E8%83%BD%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%9D%A1%E4%BB%B6%E4%B8%8B%E5%B7%A5%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E8%B0%83%E6%95%B4%E9%85%8D%E7%BD%AE%E6%9D%A5%E4%BF%AE%E5%A4%8D%E8%BF%99%E4%BA%9B%E9%94%99%E8%AF%AF%EF%BC%9A%E7%BB%88%E6%AD%A2%E3%80%81%E9%A9%B1%E5%8A%A8%E5%BC%BA%E5%BA%A6%E3%80%81%E5%BB%B6%E8%BF%9F%E4%BB%A5%E5%8F%8A%E4%B8%80%E8%88%AC%E7%9A%84%E5%AE%9A%E6%97%B6%E3%80%82%3CBR%20%2F%3E%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EEmanuele%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2119115%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2119115%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E9%82%A3%E4%B9%88%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E5%BA%94%E8%AF%A5%E8%AF%B7%20Nanya%20%E7%9A%84%E4%BE%9B%E5%BA%94%E5%95%86%E8%B0%88%E8%B0%88%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E3%80%82%E8%AF%A2%E9%97%AE%E4%BB%96%E4%BB%AC%E7%9A%84%20DDR%20%E8%83%BD%E5%90%A6%E5%9C%A8%E6%B5%8B%E8%AF%95%E5%9C%BA%E6%99%AF%E4%B8%8B%E9%80%9A%E8%BF%87%E8%AF%A5%E6%B5%8B%E8%AF%95%E3%80%82%20%E8%BF%99%E4%B8%8E%E5%A4%8D%E5%91%98%E6%96%B9%E6%A1%88%E5%9F%B9%E8%AE%AD%E6%97%A0%E5%85%B3%E3%80%82%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2119068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2119068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%20%E4%BD%A0%E5%A5%BD%E3%80%81%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E4%BB%AC%E5%81%9A%E5%88%B0%E4%BA%86%E3%80%82%E5%AE%83%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E5%9F%83%E9%A9%AC%E5%8A%AA%E5%9F%83%E8%8E%B1%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2119009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8QM%20and%20LPDDR4%20memory%20errors%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2119009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F217981%22%20target%3D%22_blank%22%3E%40emanuele79%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E6%9C%89%E6%B2%A1%E6%9C%89%E8%AF%95%E8%BF%87%E4%BD%BF%E7%94%A8%E7%BE%8E%E5%85%89%20%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(DRAM)%20%E8%BF%90%E8%A1%8C%E5%90%8C%E6%A0%B7%E7%9A%84%E6%B5%8B%E8%AF%95%E7%9C%8B%E7%9C%8B%E6%98%AF%E5%90%A6%E4%B9%9F%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E6%97%A5%E5%BF%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E
