iMX8QM RPA DDR Tool - previous versions?
fmonte
I have noticed that previous RPA tool versions are removed from the i.MX 8/8X Family DDR Tools Release  page.
Is it possible to download the previous versions since the latest cfg files look incompatible with previous SCU versions (es. 1.2.0 GA).
Thank you,
Francesco
Tags (2)
Rita_Wang
Sorry, I do not found the earlier version, now all available are here https://community.nxp.com/docs/DOC-346060
fmonte
Hello Rita,
that's a problem, because current MX8QM GA BSP is 4.14.98, which is only compatible with SCU FW 1.2.x, which in turn is only compatible with DDR configuration file v18.
Using v19 or v20 (the two available RPA tools) won't work.
By removing the v18 version, it is not possible to generate a DDR configuration file compatible with the current GA BSP.
Thank you!
Francesco
Rita_Wang
Hi Francesco,
I email to you, please have a check.
Have a nice day
Best Regards
Rita
danielgloeckner
Hello Rita,
we are also in need of v18 of that Excel sheet. Can you send it to me as well?
Rita_Wang
Dear Daniel,
I already email to you, please have a check.
Wish you have a nice day
Best Regards
Rita
vinothkumars
Senior Contributor IV
Hi @Rita_Wang , @Rita_Wang ,
I am also need old RPA tool (v17) for L4.14.98 with SCFW 2.1.1 firmware for IMX8QM_MEK. Will you please send to me.
Vinothkumar Sekar
Rita_Wang
So sorry for late reply, I do not have the v17 version, only have this version MX8QM_B0_LPDDR4_RPA_1.6GHz_v18
vinothkumars
Thank you for the reply
Got it from NXP.
Vinothkumar Sekar
fmonte
Thank you very much, Rita!
Have a nice day,
Francesco
Rita_Wang
Hi Francesco,
Now in our website the newest Linux BSP version is Linux 5.4.24_2.1.0 for i.MX8QM. But for the v18 version tool I will go further confirming with our expert team and then give you update.
Have a nice day
Best Regards
Rita
