iMX8QM Kernel Boot Issue
1,447 次查看
Babu
Hello All,
I am trying to bring up i.MX8QM custom board bring and i am using yocto SDK 5.4.70. RAM is 3 GB. While booting i'm getting following logs and not completing kernel boot.
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.4.70-2.3.2+g8c73bc625c4d (oe-user@oe-host) (gcc version 9.2.0 (GCC)) #1 SMP PREEMPT Sat Jul 17 16:20:22 UTC 2021
[ 0.000000] Machine model: Freescale i.MX8QM MEK
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000096000000, size 960 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0vring0@90000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090008000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0vring1@90008000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090010000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev1vring0@90010000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090018000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev1vring1@90018000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090100000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0vring0@90100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090108000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0vring1@90108000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090110000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev1vring0@90110000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090118000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev1vring1@90118000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090400000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vdevbuffer, compatible id shared-dma-pool
[ 0.000000] earlycon: lpuart32 at MMIO 0x000000005a060000 (options '')
[ 0.000000] printk: bootconsole [lpuart32] enabled
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080200000-0x000000097fffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x97f461500-0x97f462fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000080200000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000097fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080200000-0x0000000083ffffff]
[ 0.000000] node 0: [mem 0x0000000086400000-0x0000000087ffffff]
[ 0.000000] node 0: [mem 0x0000000090020000-0x00000000900fefff]
[ 0.000000] node 0: [mem 0x0000000090120000-0x00000000901fefff]
[ 0.000000] node 0: [mem 0x0000000090500000-0x0000000091ffffff]
[ 0.000000] node 0: [mem 0x0000000094c00000-0x0000000094ffffff]
[ 0.000000] node 0: [mem 0x0000000095400000-0x00000000fdffffff]
[ 0.000000] node 0: [mem 0x0000000890000000-0x000000097fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x000000097fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s58904 r8192 d31208 u98304
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1420963
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: console=ttyLP0,115200 earlycon root=/dev/mmcblk0p2 rootwait rw
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0xfa000000-0xfe000000] (64MB)
[ 0.000000] BUG: Bad page state in process swapper pfn:d2001
[ 0.000000] page:fffffe0001280040 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] flags: 0x0()
[ 0.000000] raw: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 0.000000] page dumped because: nonzero mapcount
[ 0.000000] Modules linked in:
[ 0.000000] CPU: 0 PID: 0 Comm: swapper Not tainted 5.4.70-2.3.2+g8c73bc625c4d #1
[ 0.000000] Hardware name: Freescale i.MX8QM MEK (DT)
[ 0.000000] Call trace:
[ 0.000000] dump_backtrace+0x0/0x140
[ 0.000000] show_stack+0x14/0x20
[ 0.000000] dump_stack+0xb4/0x114
[ 0.000000] bad_page+0xec/0x118
[ 0.000000] free_pages_check_bad+0x70/0xa8
[ 0.000000] __free_pages_ok+0x34c/0x370
[ 0.000000] __free_pages+0x30/0x58
[ 0.000000] __free_pages_core+0xc0/0xd0
[ 0.000000] memblock_free_pages+0x10/0x18
[ 0.000000] memblock_free_all+0x188/0x210
[ 0.000000] mem_init+0x48/0x58
[ 0.000000] start_kernel+0x220/0x44c
[ 0.000000] Disabling lock debugging due to kernel taint
[ 0.000000] BUG: Bad page state in process swapper pfn:d2002
[ 0.000000] page:fffffe0001280080 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] CPU: 0 PID: 0 Comm: swapper Tainted: G B 5.4.70-2.3.2+g8c73bc625c4d #1
[ 0.000000] BUG: Bad page state in process swapper pfn:d2003
[ 0.000000] page:fffffe00012800c0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2004
[ 0.000000] page:fffffe0001280100 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2005
[ 0.000000] page:fffffe0001280140 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2006
[ 0.000000] page:fffffe0001280180 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2007
[ 0.000000] page:fffffe00012801c0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2008
[ 0.000000] page:fffffe0001280200 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2009
[ 0.000000] page:fffffe0001280240 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d200a
[ 0.000000] page:fffffe0001280280 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d200b
[ 0.000000] page:fffffe00012802c0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d200c
[ 0.000000] page:fffffe0001280300 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d200d
[ 0.000000] page:fffffe0001280340 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d200e
[ 0.000000] page:fffffe0001280380 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d200f
[ 0.000000] page:fffffe00012803c0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2010
[ 0.000000] page:fffffe0001280400 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2011
[ 0.000000] page:fffffe0001280440 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2012
[ 0.000000] page:fffffe0001280480 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2013
[ 0.000000] page:fffffe00012804c0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2014
[ 0.000000] page:fffffe0001280500 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2015
[ 0.000000] page:fffffe0001280540 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2016
[ 0.000000] page:fffffe0001280580 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2017
[ 0.000000] page:fffffe00012805c0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2018
[ 0.000000] page:fffffe0001280600 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2019
[ 0.000000] page:fffffe0001280640 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d201a
[ 0.000000] page:fffffe0001280680 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d201b
[ 0.000000] page:fffffe00012806c0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d201c
[ 0.000000] page:fffffe0001280700 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d201d
[ 0.000000] page:fffffe0001280740 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d201e
[ 0.000000] page:fffffe0001280780 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d201f
[ 0.000000] page:fffffe00012807c0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2020
[ 0.000000] page:fffffe0001280800 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2021
[ 0.000000] page:fffffe0001280840 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2022
[ 0.000000] page:fffffe0001280880 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2023
[ 0.000000] page:fffffe00012808c0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2024
[ 0.000000] page:fffffe0001280900 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2025
[ 0.000000] page:fffffe0001280940 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2026
[ 0.000000] page:fffffe0001280980 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2027
[ 0.000000] page:fffffe00012809c0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2028
[ 0.000000] page:fffffe0001280a00 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2029
[ 0.000000] page:fffffe0001280a40 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d202a
[ 0.000000] page:fffffe0001280a80 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d202b
[ 0.000000] page:fffffe0001280ac0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d202c
[ 0.000000] page:fffffe0001280b00 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d202d
[ 0.000000] page:fffffe0001280b40 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d202e
[ 0.000000] page:fffffe0001280b80 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d202f
[ 0.000000] page:fffffe0001280bc0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2030
[ 0.000000] page:fffffe0001280c00 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2031
[ 0.000000] page:fffffe0001280c40 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2032
[ 0.000000] page:fffffe0001280c80 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2033
[ 0.000000] page:fffffe0001280cc0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2034
[ 0.000000] page:fffffe0001280d00 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2035
[ 0.000000] page:fffffe0001280d40 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2036
[ 0.000000] page:fffffe0001280d80 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2037
[ 0.000000] page:fffffe0001280dc0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2038
[ 0.000000] page:fffffe0001280e00 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d2039
[ 0.000000] page:fffffe0001280e40 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d203a
[ 0.000000] page:fffffe0001280e80 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d203b
[ 0.000000] page:fffffe0001280ec0 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.000000] BUG: Bad page state in process swapper pfn:d203c
[ 0.000000] page:fffffe0001280f00 refcount:0 mapcount:1 mapping:0000000000000000 index:0x0
[ 0.
[ 15.372663] CPU3: failed to come online
[ 15.376150] CPU3: failed in unknown state : 0x0
[ 20.500138] CPU4: failed to come online
[ 20.503626] CPU4: failed in unknown state : 0x0
[ 25.627608] CPU5: failed to come online
[ 25.631101] CPU5: failed in unknown state : 0x0
[ 25.635676] smp: Brought up 1 node, 1 CPU
[ 25.639614] SMP: Total of 1 processors activated.
[ 25.644329] CPU features: detected: 32-bit EL0 Support
[ 25.649449] CPU features: detected: CRC32 instructions
[ 25.665576] CPU: All CPU(s) started at EL2
[ 25.669342] alternatives: patching kernel code
[ 25.674663] devtmpfs: initialized
[ 25.693867] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 25.703305] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 25.748097] pinctrl core: initialized pinctrl subsystem
[ 25.754268] DMI not present or invalid.
[ 25.758051] NET: Registered protocol family 16
[ 25.768392] DMA: preallocated 256 KiB pool for atomic allocations
[ 25.774158] audit: initializing netlink subsys (disabled)
[ 25.780908] cpuidle: using governor menu
[ 25.784511] audit: type=2000 audit(25.684:1): state=initialized audit_enabled=0 res=1
[ 25.793258] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 25.801362] Serial: AMBA PL011 UART driver
[ 25.805168] imx mu driver is registered.
[ 25.809036] imx rpmsg driver is registered.
[ 25.871316] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 25.877745] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 25.884394] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 25.891064] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 25.898784] cryptd: max_cpu_qlen set to 1000
[ 25.907645] ACPI: Interpreter disabled.
[ 25.913592] iommu: Default domain type: Translated
[ 25.918277] vgaarb: loaded
[ 25.921114] SCSI subsystem initialized
[ 25.924920] usbcore: registered new interface driver usbfs
[ 25.930102] usbcore: registered new interface driver hub
[ 25.935439] usbcore: registered new device driver usb
[ 25.942540] mc: Linux media interface: v0.10
[ 25.946497] videodev: Linux video capture interface: v2.00
[ 25.952005] pps_core: LinuxPPS API ver. 1 registered
[ 25.956898] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 25.966030] PTP clock support registered
[ 25.970289] EDAC MC: Ver: 3.0.0
[ 25.974651] No BMan portals available!
[ 25.978451] QMan: Allocated lookup table at (____ptrval____), entry count 65537
[ 25.986165] No QMan portals available!
[ 25.990687] No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
[ 25.997156] FPGA manager framework
[ 26.000289] Advanced Linux Sound Architecture Driver Initialized.
[ 26.006700] Bluetooth: Core ver 2.22
[ 26.009949] NET: Registered protocol family 31
[ 26.014366] Bluetooth: HCI device and connection manager initialized
[ 26.020711] Bluetooth: HCI socket layer initialized
[ 26.025572] Bluetooth: L2CAP socket layer initialized
[ 26.030619] Bluetooth: SCO socket layer initialized
[ 26.036554] imx-scu scu: NXP i.MX SCU Initialized
[ 26.047192] random: fast init done
[ 26.089106] imx8qm-pinctrl scu:pinctrl: Invalid fsl,pins or pins property in node /scu/pinctrl/wifi_initgrp
[ 26.098535] imx8qm-pinctrl scu:pinctrl: initialized IMX pinctrl driver
[ 26.106995] clocksource: Switched to clocksource arch_sys_counter
[ 26.113029] VFS: Disk quotas dquot_6.6.0
[ 26.116721] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 26.123964] pnp: PnP ACPI: disabled
[ 26.168082] thermal_sys: Registered thermal governor 'step_wise'
[ 26.168088] thermal_sys: Registered thermal governor 'power_allocator'
[ 26.174562] NET: Registered protocol family 2
[ 26.185512] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 26.193847] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 26.202028] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 26.210051] TCP: Hash tables configured (established 65536 bind 65536)
[ 26.216352] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 26.223154] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 26.230477] NET: Registered protocol family 1
[ 26.234926] RPC: Registered named UNIX socket transport module.
[ 26.240522] RPC: Registered udp transport module.
[ 26.245193] RPC: Registered tcp transport module.
[ 26.249885] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 26.256676] PCI: CLS 0 bytes, default 64
[ 26.260881] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 26.269844] kvm [1]: IPA Size Limit: 40bits
[ 26.274356] kvm [1]: vgic-v2@52020000
[ 26.277708] kvm [1]: GIC system register CPU interface enabled
[ 26.283517] kvm [1]: vgic interrupt IRQ1
[ 26.287467] kvm [1]: Hyp mode initialized successfully
[ 26.296249] Initialise system trusted keyrings
[ 26.300460] workingset: timestamp_bits=44 max_order=21 bucket_order=0
[ 26.312300] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 26.318416] NFS: Registering the id_resolver key type
[ 26.323155] Key type id_resolver registered
[ 26.327297] Key type id_legacy registered
[ 26.331300] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 26.338002] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 26.344395] 9p: Installing v9fs 9p2000 file system support
[ 26.362448] Key type asymmetric registered
[ 26.366216] Asymmetric key parser 'x509' registered
[ 26.371109] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 26.378462] io scheduler mq-deadline registered
[ 26.382976] io scheduler kyber registered
[ 26.404352] imx6q-pcie 5f010000.pcie: 5f010000.pcie supply epdev_on not found, using dummy regulator
[ 26.418139] pwm-backlight lvds_backlight@0: lvds_backlight@0 supply power not found, using dummy regulator
[ 26.427989] pwm-backlight lvds_backlight@1: lvds_backlight@1 supply power not found, using dummy regulator
[ 26.438463] EINJ: ACPI disabled.
[ 26.552201] mxs-dma 5b810000.dma-apbh: initialized
[ 26.560126] Bus freq driver module loaded
[ 26.571807] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 26.582324] 5a060000.serial: ttyLP0 at MMIO 0x5a060010 (irq = 53, base_baud = 5000000) is a FSL_LPUAR[ 26.591487] printk: console [ttyLP0] enabled
[ 26.599921] printk: bootconsole [lpuart32] disabled
[ 26.609893] fsl-lpuart 5a060000.serial: DMA tx channel request failed, operating without tx DMA
[ 26.618631] fsl-lpuart 5a060000.serial: DMA rx channel request failed, operating without rx DMA
[ 26.627734] 5a070000.serial: ttyLP1 at MMIO 0x5a070010 (irq = 54, base_baud = 5000000) is a FSL_LPUART
[ 26.639713] arm-smmu 51400000.iommu: probing hardware configuration...
[ 26.646254] arm-smmu 51400000.iommu: SMMUv2 with:
[ 26.650968] arm-smmu 51400000.iommu: stage 1 translation
[ 26.656378] arm-smmu 51400000.iommu: stage 2 translation
[ 26.661781] arm-smmu 51400000.iommu: nested translation
[ 26.667103] arm-smmu 51400000.iommu: stream matching with 32 register groups
[ 26.674253] arm-smmu 51400000.iommu: 32 context banks (0 stage-2 only)
[ 26.680882] arm-smmu 51400000.iommu: Supported page sizes: 0x61311000
[ 26.687421] arm-smmu 51400000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 26.693954] arm-smmu 51400000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 26.793151] loop: module loaded
[ 26.801627] ahci-imx 5f020000.sata: Adding to iommu group 0
[ 26.807384] ahci-imx 5f020000.sata: phy impedance ratio is not specified.
[ 26.814226] ahci-imx 5f020000.sata: No cache used with register defaults set!
[ 26.822043] imx ahci driver is registered.
[ 26.835734] spi-nor spi0.0: unrecognized JEDEC id bytes: 34 5b 1a 0f 03 90
[ 26.842634] spi-nor: probe of spi0.0 failed with error -2
[ 26.850737] libphy: Fixed MDIO Bus: probed
[ 26.855532] tun: Universal TUN/TAP device driver, 1.6
[ 26.862637] thunder_xcv, ver 1.0
[ 26.865922] thunder_bgx, ver 1.0
[ 26.869196] nicpf, ver 1.0
[ 26.873032] fec 5b040000.ethernet: Adding to iommu group 1
[ 26.879242] pps pps0: new PPS source ptp0
[ 26.884725] fec 5b050000.ethernet: Adding to iommu group 1
[ 26.892817] Freescale FM module, FMD API version 21.1.0
[ 26.898954] Freescale FM Ports module
[ 26.902639] fsl_mac: fsl_mac: FSL FMan MAC API based driver
[ 26.908827] fsl_dpa: FSL DPAA Ethernet driver
[ 26.913533] fsl_advanced: FSL DPAA Advanced drivers:
[ 26.918511] fsl_proxy: FSL DPAA Proxy initialization driver
[ 26.924426] fsl_oh: FSL FMan Offline Parsing port driver
[ 26.932218] hclge is initializing
[ 26.935550] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 26.942798] hns3: Copyright (c) 2017 Huawei Corporation.
[ 26.948157] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[ 26.955226] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 26.961009] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 26.966852] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 26.972811] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[ 26.979778] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 26.985381] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 26.993219] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 26.999590] sky2: driver version 1.30
[ 27.005683] VFIO - User Level meta-driver version: 0.3
[ 27.015779] cdns-usb3 5b110000.usb3: Adding to iommu group 2
[ 27.022542] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 27.029115] ehci-pci: EHCI PCI platform driver
[ 27.033609] ehci-platform: EHCI generic platform driver
[ 27.039493] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 27.045704] ohci-pci: OHCI PCI platform driver
[ 27.050194] ohci-platform: OHCI generic platform driver
[ 27.057380] usbcore: registered new interface driver uas
[ 27.062750] usbcore: registered new interface driver usb-storage
[ 27.068831] usbcore: registered new interface driver usbserial_generic
[ 27.075653] usbserial: USB Serial support registered for generic
[ 27.081916] usbcore: registered new interface driver ftdi_sio
[ 27.087955] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 27.095817] usbcore: registered new interface driver usb_serial_simple
[ 27.102708] usbserial: USB Serial support registered for carelink
[ 27.109137] usbserial: USB Serial support registered for zio
[ 27.115131] usbserial: USB Serial support registered for funsoft
[ 27.121400] usbserial: USB Serial support registered for flashloader
[ 27.128054] usbserial: USB Serial support registered for google
[ 27.134158] usbserial: USB Serial support registered for libtransistor
[ 27.140938] usbserial: USB Serial support registered for vivopay
[ 27.147165] usbserial: USB Serial support registered for moto_modem
[ 27.153497] usbserial: USB Serial support registered for motorola_tetra
[ 27.160300] usbserial: USB Serial support registered for novatel_gps
[ 27.166847] usbserial: USB Serial support registered for hp4x
[ 27.172829] usbserial: USB Serial support registered for suunto
[ 27.178772] usbserial: USB Serial support registered for siemens_mpi
[ 27.185167] usbcore: registered new interface driver usb_ehset_test
[ 27.199991] input: sc-powerkey as /devices/platform/sc-powerkey/input/input0
[ 27.211089] imx-sc-rtc scu:rtc: registered as rtc0
[ 27.216852] i2c /dev entries driver
[ 27.229295] Bluetooth: HCI UART driver ver 2.3
[ 27.233759] Bluetooth: HCI UART protocol H4 registered
[ 27.238903] Bluetooth: HCI UART protocol BCSP registered
[ 27.244238] Bluetooth: HCI UART protocol LL registered
[ 27.249386] Bluetooth: HCI UART protocol ATH3K registered
[ 27.254805] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 27.261312] Bluetooth: HCI UART protocol Broadcom registered
[ 27.267005] Bluetooth: HCI UART protocol QCA registered
[ 27.278066] sdhci: Secure Digital Host Controller Interface driver
[ 27.284265] sdhci: Copyright(c) Pierre Ossman
[ 27.289190] Synopsys Designware Multimedia Card Interface Driver
[ 27.297182] sdhci-pltfm: SDHCI platform and OF driver helper
[ 27.304719] sdhci-esdhc-imx 5b010000.mmc: Adding to iommu group 3
[ 27.311272] mmc0: CQHCI version 5.10
[ 27.346440] mmc0: SDHCI controller on 5b010000.mmc [5b010000.mmc] using ADMA
[ 27.355363] sdhci-esdhc-imx 5b020000.mmc: Adding to iommu group 3
[ 27.362076] mmc1: CQHCI version 5.10
[ 27.370585] ledtrig-cpu: registered to indicate activity on CPUs
[ 27.379366] caam 31400000.crypto: device ID = 0x0a16040000000100 (Era 9)
[ 27.386081] caam 31400000.crypto: job rings = 1, qi = 0
[ 27.405420] caam algorithms registered in /proc/crypto
[ 27.412096] caam 31400000.crypto: caam pkc algorithms registered in /proc/crypto
[ 27.419586] caam 31400000.crypto: registering rng-caam
[ 27.425112] Device caam-keygen registered
[ 27.431865] usbcore: registered new interface driver usbhid
[ 27.437517] random: crng init done
[ 27.440989] usbhid: USB HID core driver
[ 27.450597] mxc-isi 58100000.isi: mxc_isi.0 registered successfully
[ 27.459083] mxc-isi 58110000.isi: mxc_isi.1 registered successfully
[ 27.468646] mxc-isi 58120000.isi: mxc_isi.2 registered successfully
[ 27.479982] mxc-isi 58130000.isi: mxc_isi.3 registered successfully
[ 27.486366] mmc0: Command Queue Engine enabled
[ 27.490847] mmc0: new HS400 MMC card at address 0001
[ 27.496457] mxc-isi 58140000.isi: mxc_isi.4 registered successfully
[ 27.503322] mmcblk0: mmc0:0001 S0J57X 29.6 GiB
[ 27.508166] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB
[ 27.514586] mxc-isi 58150000.isi: mxc_isi.5 registered successfully
[ 27.521143] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB
[ 27.527542] mxc-isi 58160000.isi: mxc_isi.6 registered successfully
[ 27.533956] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (237:0)
[ 27.541838] mxc-isi 58170000.isi: mxc_isi.7 registered successfully
[ 27.551212] mmcblk0: p1 p2
[ 27.575009] mxc-mipi-csi2 58227000.csi: lanes: 4, name: mxc-mipi-csi2.0
[ 27.599237] mxc-mipi-csi2 58247000.csi: lanes: 4, name: mxc-mipi-csi2.1
[ 27.611805] No fsl,qman node
[ 27.614693] Freescale USDPAA process driver
[ 27.618925] fsl-usdpaa: no region found
[ 27.622795] Freescale USDPAA process IRQ driver
[ 27.630090] imx-rproc imx8qm_cm4@0: failed to find syscon
[ 27.635555] remoteproc remoteproc0: releasing imx-rproc
[ 27.640830] imx-rproc imx8x_cm4@1: failed to find syscon
[ 27.646213] remoteproc remoteproc0: releasing imx-rproc
[ 27.658862] optee: probing for conduit method from DT.
0 回复数
