iMX8QM Android Automotive OS Prepare SD Card Image
2,323 次查看
cbl
I built Android Automotive OS 12.0.0_2.1.0 for my iMX8QM EVK board.
I want to boot the board using SD card.
I couldn't find a way to do this.
Could you please help me with this issue?
Efecan
4 回复数
2,213 次查看
Rof
I flashed it with : sudo ./uuu_imx_android_flash.sh -f imx8qm -t sd -e command.
I have set switch to boot from sd card. Yet i am getting below error at boot :
U-Boot SPL 2022.04 (Nov 09 2022 - 20:09:52 +0100)
Normal Boot
Trying to boot from MMC2_2
GPT is invalid, please flash correct GPT!
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
2,297 次查看
Rita_Wang
2,292 次查看
cbl
I couldn't see a topic about preparing SD card in the Ouick User Guide of Android Automotive OS 12.0.0_2.1.0.
Isn't there a way to do this?
Could you please help with this?
Efecan
2,277 次查看
Rita_Wang
Following the document:
https://www.nxp.com.cn/docs/en/user-guide/Android_Auto_Quick_Start_Guide.pdf
The example is for downloading images use the uuu tool to the emmc, for the SD card command you can refer to the Table 4. Options for uuu_imx_android_flash tool.
