iMX8QM Android Automotive OS 12 XEN Usage Problem
2,254件の閲覧回数
cbl
Contributor V
I want to use XEN hypervisisor on Android Autmotive OS 12.0.0_2.1.0.
However, I could not find an up-to-date XEN document for Android Automotive OS 12 to follow.
For this reason, I followed the XEN procedure in the Quick Start Guide for Android Automotive OS 10.
First I formatted my SD card to FAT16 with "boot" label.
Then I wrote my Android image and Yocto image with the uuu script.
But in Android Automotive 12, when I entered the "run xenmmcboot" command in the U-Boot, I got the unknown command error.
Which document can I reference to use XEN in Android Automotive OS 12.
Efecan
2 返答(返信)
2,226件の閲覧回数
jimmychan
You could take the u-boot bootargs setting in the imx8qm_mek.h for reference.
https://source.codeaurora.org/external/imx/uboot-imx/tree/include/configs/imx8qm_mek.h?h=imx_v2020.0...
2,217件の閲覧回数
cbl
Contributor V
Hello @jimmychan,
I transferred the header file you sent to my system.
But I encountered errors while compiling.
I am attaching the "imx8qm_mek.h" file, which is included in my own source packages and I use.
What should I do to activate XEN?
Could you please help me with this?
Efecan
