iMX8MQ-EVK: flashing eMMC problem
Julie3
After bitbaking my imx-image-core for iMX8MQ-EVK, I tried to find how to flash an eMMC image.
I found some tutorials which use UUU tool:
- 'uuu -v -b emmc_all ' + .sdcard file (rootfs) + .bin-flash_evk file (bootloader)
- 'uuu_flash -b' + board_name + '-i ' .sdcard.bz2 file
The problem is that I don't have .sdcard file or .sdcard.bz2 file. So, I cannot use these methods.
Do you know how I could flash my eMMC image with an other command, or maybe help me to get .sdcard file or .sdcard.bz2 file?
You can see below the files that I have in my deploy/images/imx8mq-evk folder:
~/imx-yocto-bsp/build/tmp/deploy/images/imx8mq-evk$ ls
Image imx8mq-evk-rpmsg.dtb
Image--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.bin imx8mq-evk-rpmsg-imx8mq-evk.dtb
Image-imx8mq-evk.bin imx8mq-evk-usdhc2-m2--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb
imx8mq-evk--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb imx8mq-evk-usdhc2-m2.dtb
imx8mq-evk-ak4497--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb imx8mq-evk-usdhc2-m2-imx8mq-evk.dtb
imx8mq-evk-ak4497.dtb imx8mq-evk-usd-wifi--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb
imx8mq-evk-ak4497-imx8mq-evk.dtb imx8mq-evk-usd-wifi.dtb
imx8mq-evk-audio-tdm--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb imx8mq-evk-usd-wifi-imx8mq-evk.dtb
imx8mq-evk-audio-tdm.dtb imx8mq_m4_TCM_hello_world.bin
imx8mq-evk-audio-tdm-imx8mq-evk.dtb imx8mq_m4_TCM_rpmsg_lite_pingpong_rtos_linux_remote.bin
imx8mq-evk-dcss-adv7535--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb imx8mq_m4_TCM_rpmsg_lite_str_echo_rtos.bin
imx8mq-evk-dcss-adv7535.dtb imx-boot
imx8mq-evk-dcss-adv7535-imx8mq-evk.dtb imx-boot-imx8mq-evk-emmc.bin-flash_dp_evk
imx8mq-evk-dcss-rm67191--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb imx-boot-imx8mq-evk-emmc.bin-flash_evk
imx8mq-evk-dcss-rm67191.dtb imx-boot-imx8mq-evk-emmc.bin-flash_evk_no_hdmi
imx8mq-evk-dcss-rm67191-imx8mq-evk.dtb imx-boot-tagged
imx8mq-evk-dcss-rm67199--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb imx-boot-tools
imx8mq-evk-dcss-rm67199.dtb imx-image-core.env
imx8mq-evk-dcss-rm67199-imx8mq-evk.dtb imx-image-core-imx8mq-evk-20220325164117.rootfs.manifest
imx8mq-evk-dp--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb imx-image-core-imx8mq-evk-20220325164117.rootfs.tar.bz2
imx8mq-evk-dp.dtb imx-image-core-imx8mq-evk-20220325164117.rootfs.wic.bmap
imx8mq-evk-dp-imx8mq-evk.dtb imx-image-core-imx8mq-evk-20220325164117.rootfs.wic.bz2
imx8mq-evk.dtb imx-image-core-imx8mq-evk-20220325164117.testdata.json
imx8mq-evk-dual-display--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb imx-image-core-imx8mq-evk.manifest
imx8mq-evk-dual-display.dtb imx-image-core-imx8mq-evk.tar.bz2
imx8mq-evk-dual-display-imx8mq-evk.dtb imx-image-core-imx8mq-evk.testdata.json
imx8mq-evk-imx8mq-evk.dtb imx-image-core-imx8mq-evk.wic.bmap
imx8mq-evk-inmate--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb imx-image-core-imx8mq-evk.wic.bz2
imx8mq-evk-inmate.dtb imx-image-core-imx-imx-boot-bootpart.wks
imx8mq-evk-inmate-imx8mq-evk.dtb lpddr4_pmu_train_1d_dmem.bin
imx8mq-evk-lcdif-adv7535--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb lpddr4_pmu_train_1d_imem.bin
imx8mq-evk-lcdif-adv7535.dtb lpddr4_pmu_train_2d_dmem.bin
imx8mq-evk-lcdif-adv7535-imx8mq-evk.dtb lpddr4_pmu_train_2d_imem.bin
imx8mq-evk-lcdif-rm67191--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb modules--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.tgz
imx8mq-evk-lcdif-rm67191.dtb modules-imx8mq-evk.tgz
imx8mq-evk-lcdif-rm67191-imx8mq-evk.dtb signed_dp_imx8m.bin
imx8mq-evk-lcdif-rm67199--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb signed_hdmi_imx8m.bin
imx8mq-evk-lcdif-rm67199.dtb tee.bin
imx8mq-evk-lcdif-rm67199-imx8mq-evk.dtb tee.mx8mqevk.bin
imx8mq-evk-pcie1-m2--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb u-boot.bin
imx8mq-evk-pcie1-m2.dtb u-boot.bin-emmc
imx8mq-evk-pcie1-m2-imx8mq-evk.dtb u-boot-emmc-2021.04-r0.bin
imx8mq-evk-pcie-ep--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb u-boot-imx8mq-evk.bin
imx8mq-evk-pcie-ep.dtb u-boot-imx8mq-evk.bin-emmc
imx8mq-evk-pcie-ep-imx8mq-evk.dtb u-boot-imx-initial-env-emmc
imx8mq-evk-pdm--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb u-boot-imx-initial-env-imx8mq-evk-emmc
imx8mq-evk-pdm.dtb u-boot-imx-initial-env-imx8mq-evk-emmc-2021.04-r0
imx8mq-evk-pdm-imx8mq-evk.dtb u-boot-spl.bin
imx8mq-evk-root--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb u-boot-spl.bin-emmc
imx8mq-evk-root.dtb u-boot-spl.bin-imx8mq-evk
imx8mq-evk-root-imx8mq-evk.dtb u-boot-spl.bin-imx8mq-evk-2021.04-r0-emmc-2021.04-r0
imx8mq-evk-rpmsg--5.10.72+git0+a68e31b63f-r0-imx8mq-evk-20220325090052.dtb u-boot-spl.bin-imx8mq-evk-emmc
khang_letruong
Senior Contributor III
$ bzip2 -dkf imx-image-core-imx8mq-evk-20220325164117.rootfs.wic.bz2
$ sudo uuu -v -b emmc_all imx-boot-imx8mq-evk-emmc.bin-flash_evk imx-image-core-imx8mq-evk-20220325164117.rootfs.wic
BR,
Khang
Harvey021
Hello Julie,
The reply from Khang is correct. and you also can refer to Linux user guide for more details.  the link to download as:
https://www.nxp.com/docs/en/user-guide/IMX_LINUX_USERS_GUIDE.pdf
Harvey
khang_letruong
BR,
Khang
