iMX8MM CAAM errors when using 'tk(cbc(aes))' for filesystem encryption
156 次查看
djs2
I'm getting the following error when writing to a filesystem using the CAAM for filesystem encryption with `tk(cbc(aes))`.
caam_jr 30902000.jr: 4000141c: DECO: desc idx 20: DECO Watchdog timer timeout error
This only happens occasionally but seems to be more prevalent when running with all cores enabled.
104 次查看
Harvey021
Can you please share the version of BSP you're working and the Steps and logs when problems occur?
Harvey
