iMX8M series Power sequence
4,123 次查看
sahilnayak
Hi Team,
We are going to use iMX8M series processor in our application. As per power sequence mentioned in the IMX8MDQLQCEC document, we will power VDD_SOC with external regulator and to power VDD_ARM voltage we will use SW1A/B output of PMIC PF4210. We don't have requirement of GPU/VPU, so to power VDD_GPU/VPU, we will use SW1C output of PMIC. Please confirm if the power sequence is okay.
Sahil Nayak
7 回复数
3,995 次查看
sahilnayak
Any update on this??
3,994 次查看
Rita_Wang
I will confirm it for you.
3,995 次查看
sahilnayak
Hi Rita,
Please confirm the power sequence.
Attached is the image of power topology for more clarification.
3,995 次查看
sahilnayak
Hi Rita,
As we have critical timeline for the design phase, please confirm on the above asap, so we can move forward on it.
Thanks & Regards,
Sahil Nayak
3,995 次查看
Rita_Wang
OK, I will give you reply as soon as possible.
3,995 次查看
sahilnayak
Hi Rita,
Awaiting for your quick response.
3,995 次查看
Rita_Wang
Hi Sahil Nayak ,
Sequence is OK, power topology is important,so if possible, please do not remove the circuit of external regulator for VDD_ARM,just DNP. when the power is OK after validation then remove.
Have a nice day
Best Regards
Rita
