iMX8M Plus PCIe TX/RX Impedance
danny_ayers
I am interfacing the iMX8Mplus directly (via pcb trace and AC coupling capacitors, no connectors) to a gen 2 PCIe device which specifies 100 ohm differential impedance for its TX and RX pairs.  The connection path is < 2 inches.
Can the iMX8 tolerate 100 ohms routing in these conditions, or if not, how to handle this situation?
Thank You,
Danny
joanxie
confirmed that it's fine as I mentioned before
joanxie
based on IMX8MP HDG, we suggest customer to use 85ohm, 85ohm has more reliable than 100ohm when use the larger inches in length, since customer only 2inches, 100ohm can be acceptable, if customer doesn't have any compliance issue, they can use this, but I will double confirm this from HW team again, if get further information, I will let you know it
danny_ayers
Thank You very much for that reply. Please advise with your hardware team's agreement.
joanxie
%3CLINGO-SUB%20id%3D%22lingo-sub-2151835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX8M%20Plus%20PCIe%20TX%2FRX%20Impedance%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20interfacing%20the%20iMX8Mplus%20directly%20(via%20pcb%20trace%20and%20AC%20coupling%20capacitors%2C%20no%20connectors)%20to%20a%20gen%202%20PCIe%20device%20which%20specifies%20100%20ohm%20differential%20impedance%20for%20its%20TX%20and%20RX%20pairs.%26nbsp%3B%20The%20connection%20path%20is%20%26lt%3B%202%20inches.%3C%2FP%3E%3CP%3ECan%20the%20iMX8%20tolerate%20100%20ohms%20routing%20in%20these%20conditions%2C%20or%20if%20not%2C%20how%20to%20handle%20this%20situation%3F%3C%2FP%3E%3CP%3EThank%20You%2C%3C%2FP%3E%3CP%3EDanny%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8M%20Plus%20PCIe%20TX%2FRX%20Impedance%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Econfirmed%20that%20it's%20fine%20as%20I%20mentioned%20before%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8M%20Plus%20PCIe%20TX%2FRX%20Impedance%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20You%20very%20much%20for%20that%20reply.%20Please%20advise%20with%20your%20hardware%20team's%20agreement.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX8M%20Plus%20PCIe%20TX%2FRX%20Impedance%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ebased%20on%20IMX8MP%20HDG%2C%20we%20suggest%20customer%20to%20use%2085ohm%2C%2085ohm%20has%20more%20reliable%20than%20100ohm%20when%20use%20the%20larger%26nbsp%3B%3CSPAN%3Einches%20in%20length%2C%20since%20customer%20only%202inches%2C%20100ohm%20can%20be%20acceptable%2C%20if%20customer%20doesn't%20have%20any%20compliance%20issue%2C%20they%20can%20use%20this%2C%20but%20I%20will%20double%20confirm%20this%20from%20HW%20team%20again%2C%20if%20get%20further%20information%2C%20I%20will%20let%20you%20know%20it%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22joanxie_0-1755132949542.png%22%20style%3D%22width%3A%20551px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22joanxie_0-1755132949542.png%22%20style%3D%22width%3A%20551px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F352298i4DFC0AE436241A33%2Fimage-dimensions%2F551x142%3Fv%3Dv2%22%20width%3D%22551%22%20height%3D%22142%22%20role%3D%22button%22%20title%3D%22joanxie_0-1755132949542.png%22%20alt%3D%22joanxie_0-1755132949542.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
