[iMX8M Plus][ISP] Flicker Advoidance
1,875 次查看
khang_letruong
Senior Contributor III
Dear Community,
From the guidance for the VVEXT tool made by one of NXP's partners, it says :
Flicker Avoidance Period
The ISP offers the feature of flicker suppression. The flicker suppression aims at the suppression of brightness fluctuations of the image, which are caused by differences in the frequencies of the light source (e.g. fluorescent lamps, LEDs) and the image acquisition frequency (beatings).
This feature has not yet been put into operation by PHYTEC and is therefore not supported for the time being.
We are experiencing the same issue. Therefore, I would like to know if this feature would generically be NXP's ISP feature or specifically to PHYTEC's implementation, please ?
Thanks in advance and best regards,
Khang
1,847 次查看
joanxie
I have confirmed that ISP doesn't support this currently, if customer needs it,  need consult ISP vendor for more detailed information, maybe it's not free, if you need it, pls consult local DFAE to get further help
1,848 次查看
joanxie
1,859 次查看
joanxie
let me double check it and tell you later
