iMX8 Plus Android Image Keystore for signing APK
soumyakk
I have downloaded the Android image for the iMX 8 Plus. Is there any way I can get the keystore files (the platform certificate files pk8 and pem) so that I can use them to sign the APKs and install them as a system application in Android ?
soumyakk
Hi @Harvey021
Thank you for the information. We are using the pre-built image downloaded from NXP. We were wondering if NXP also releases the certificates for those builds. This would enable us not to do an AOSP build.
Harvey021
Yes, you can refer to the ANDROID_SECURITY_USERS_GUIDE . By default, certificate will be at /device/nxp/common/security.
Harvey
