iMX7ULP RPMsg_lite Library
markus4work
Hello everyone,
I noticed that the RPMsg lite Library for the M4 core for my iMX7ULP MCU is available from 2 locations:
https://github.com/nxp-mcuxpresso/rpmsg-lite
or the downloadable NXP SDK from https://mcuxpresso.nxp.com:
../NXP-SDK/middleware/multicore/rpmsg_lite/lib/
Which version is recommended to use and why?
What are the differences between the two sources ?
Markus Horbach.
Chavira
HI @markus4work!
Thank you for contacting NXP Support!
I recommend using the version installed in the SDK because that version is tested for that specific device.
The difference is the version you can download a new version from GitHub but is not tested for all devices and the version inside the SDK is tested and optimized for each device.
Best Regards!
Chavira
