iMX6UL Fuses default value
2,963 次查看
steveglover
I used the uboot commad fuse read to read the OCOTP_LOCK word at bank 0 word 0.  I expected to find 0000_0000 but instead found  0032_0002. Fuse sense returns the same value. What is the default value of this fuse? If it should be 0000_0000 why do I have a different value, since I have not purposely programmed it.
Steve
标签 (2)
2,342 次查看
Hi Steve
OCOTP_LOCK is decribed in sect.36.5.11 Value of OTP Bank0 Word0 (Lock controls)
(OCOTP_LOCK) i.MX6UL and some bits are programmed on factory, like
OTPMK, ROM_PATCH, TESTER, as they are not intended for customer purposes.
2,343 次查看
Hi Steve
2,342 次查看
steveglover
Thanks Igor
