iMX6Q Pinning Parallel Camera 12-bit
2,111 次查看
michael_irsfeld
I'm trying to interface two cameras (Bayer12) via parallel sensor interface. In datasheet of iMX6Q on table 64 I can only find which IPU ports i should use for a 16-bit camera. Which IPU-Ports should I use for 12-bit camera?
Michael
标签 (3)
1,918 次查看
Bio_TICFSL
Hi michael,
For possible sensor connections, please look at the datasheet(s),
for example - Table (Camera Input Signal Cross Reference, Format, and Bits Per Cycle)
of IMX6DQCEC.
https://www.nxp.com/docs/en/data-sheet/IMX6DQCEC.pdf
IPU0-1 can be used for 12bit.
1,919 次查看
Bio_TICFSL
Hi michael,
of IMX6DQCEC.
