iMX6DQ MMDC Initialization
1,633件の閲覧回数
ogj
If I have the parameters generated by the MMDC calibration tool, what is the proper sequence of loading the MMDC registers and what registers are needed to get the DDR memory running? We'll assume that the IOMUXC pins have already been set up and the MMDC_ CH0 clock is already at 528 MHz.
1,543件の閲覧回数
Yuri
   Use "i.MX_Porting_Guide.pdf" in Linux documentation; in particular section
"Changing the DCD table for i.MX DDR initialization".
i.MX Software and Development Tools | NXP
Yuri.
