iMX6DL LPDDR2 Routing Rules
tom_perman
We are working on a design which uses the iMX6DL with LPDDR2 memory. The Hardware Development Guide (IMX6DQ6SDLHDG) rev 4 gives DDR routing rules in section 3.5. However these appear to be for DDR3. Are there LPDDR2 specific rules?
Tom
tom_perman
Thank you for all your help so far - the information provided has been useful.
I have a final question regarding the length matching. Are there package lengths available for the iMX6DL? This is so that length matching can incorporate both delays due to the PCB and internally within the iMX6DL package. This information has been provided for more modern iMX processors e.g the iMX8MM for matching the LPDDR4 interface.
Tom
Yuri
@tom_perman
  I've sent You some comments.
Yuri.
tom_perman
Hi Yuri,
Thanks for your comments. Is there a reference design available which uses the iMX6DL with LPDDR2? The majority of designs I have come across use DDR3.
Tom
Yuri
@tom_perman
  I used request  #00331684 to forward some files. Hope it helps.
Yuri.
Yuri
@tom_perman
  I've sent You some comments directly.
Yuri.
