iMX6_Platform_SDK fatal error: reent.h
3,754 次查看
anilkumar
I am trying to compile "iMX6_Platform_SDK" but getting error as
# make target=mx6dq board=evb boardrev=a test=caam
---------8--------------------------
/data/anil/Anil/imx/iMX6_Platform_SDK/sdk/utility/src/runtime_support.c:38:19: fatal error: reent.h: No such file or directory
compilation terminated.
make[2]: *** [/data/anil/Anil/imx/iMX6_Platform_SDK/output/mx6dq/lib/obj/sdk/sdk/utility/src/runtime_support.o] Error 1
make[1]: *** [utility] Error 2
make: *** [sdk] Error 2
Am i missing something ?
Anil
标签 (3)
2,586 次查看
RodBorras
Hi Anil,
I just tried it with:
  • latest version of the SDK: imx6_platform_sdk_v1.1.0.tgz
  • compiler CodeSourcery arm-2012.03
I ran:
./tools/build_sdk -target=mx6dq -board=evb -test=caam
and the build was successful.
Rod.
4 回复数
2,587 次查看
RodBorras
Hi Anil,
I ran:
Rod.
2,586 次查看
guowangli
I can't download the compiler!!!
can you give me the  compiler URL of CodeSourcery arm-2012.03!
thank you very much.
2,586 次查看
LeonardoSandova
Specialist I
2,586 次查看
anilkumar
thanks
