iMX6 HDMI volume control on R13.4.1
2,251 次查看
omar_ccc
We are using iMX6 running with SDK R13.4.1.
When we adjust the audio volume of HDMI output from Android Setting,  audio volume does not change.
标签 (2)
1,662 次查看
jamesbone
Unfortunately this release has several erratas or bugs with the HDMI port
ENGR00178468. HDMI Audio sometimes underrun! and then TV no music output mode 720P after switch different sample rate. 50%
ENGR00178531. HDMI audio played format is too few
ENGR00179425. Sometime HDMI mode is wrong and audio device gottend is wrong
1,662 次查看
weikeng-jimmy
Hi James,
Have you the fix patches for the three bugs ?  Thanks!
