iMX DDR Config Tool Code Generation Error || iMX95
1,000件の閲覧回数
Sudharsun
Hi Team,
We are currently working with the NXP Config Tools for i.MX95 DDR configuration and are facing an issue while generating the DDR initialization/timing code.
We created/opened the DDR configuration for the following target:
  • Processor: MIMX9596xxxxN
  • Core: Cortex-M33
  • Memory Type: LPDDR5 - Ryzen RS2G32LO5D4FDB-23BT
  • DDR Data Rate: 6400 MT/s
  • Number of Ranks: 2
  • Number of 16-bit Channels: 2
  • DRAM Configuration: 16Gb:2Gb x8
  • Total DRAM Density shown by the tool: 16384 MB
Initially, we are trying to validate the DDR configuration using the NXP i.MX95 19x19 EVK default LPDDR5 configuration before applying our custom board DDR settings.
However, when we try to generate/update the DDR code, the Config Tools reports an error in the Problems window:
“Failed to generate code…”
and the Code Preview window shows:
“Code generation failed.”
The screenshot of the issue is attached for reference:
8 返答(返信)
973件の閲覧回数
yipingwang
1. I downloaded and installed Config_Tools_for_i.MX_26.06_x64.
2. I created a new configuration, select "IMX95LPD5EVK-19" under "Boards". Enable DDR tool and select it.
3. Click "File->Save" to save this project to the disk. Then "Update Code" is avaiable.
4. Click "Update Code" button, there is no error on my side.
944件の閲覧回数
Sudharsun
The issue still persists. Even after saving the .mex file to the local disk, the code is not being generated. When I click Update Code, the tool throws the error “Code generation failed.”
Screenshot from 2026-09-15 15-31-15.pngScreenshot from 2026-09-15 15-36-58.png
938件の閲覧回数
yipingwang
Did you install Config_Tools_for_i.MX_26.06_x64? The latest version 26.06?
Did you using the Linux version? I am using the Windows version.
Would you please send your IMX95LPD5EVK-19.mex to me to do verification?
932件の閲覧回数
Sudharsun
Yes, we have downloaded and installed the same version that you mentioned. We are currently using the Linux version of the tool. I have attached a screenshot for your reference.
929件の閲覧回数
yipingwang
923件の閲覧回数
Sudharsun
I have attached the .mex file for your reference but we are going to use 8GB LPDDR5 Rayson RS2G32LO5D4FDB-23BT.
888件の閲覧回数
Sudharsun
Could you please check and provide an update on this issue at the earliest? We are currently running short on the project timeline, so your prompt support would be greatly appreciated.
874件の閲覧回数
yipingwang
It is mandatory to install this version configs tool on Ubuntu 24.04.
I can reproduce your problem on Ubuntu 22.04.
Then I install configs tool 26.06 on Ubuntu 24.04 OS, it worked normally.
%3CLINGO-SUB%20id%3D%22lingo-sub-2413574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX%20DDR%E8%A8%AD%E5%AE%9A%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E7%94%9F%E6%88%90%E3%82%A8%E3%83%A9%E3%83%BC%20%7C%7C%20iMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3CBR%20%2F%3E%E7%8F%BE%E5%9C%A8%E3%80%81%20%3CSTRONG%3Ei.MX95%20DDR%E6%A7%8B%E6%88%90%E3%81%AE%E3%81%9F%E3%82%81%E3%81%ABNXP%20Config%20Tools%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81DDR%E5%88%9D%E6%9C%9F%E5%8C%96%2F%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E7%94%9F%E6%88%90%E6%99%82%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6DDR%E6%A7%8B%E6%88%90%E3%82%92%E4%BD%9C%E6%88%90%2F%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3A%3C%2FSTRONG%3E%20MIMX9596xxxxN%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E3%82%B3%E3%82%A2%3A%3C%2FSTRONG%3E%20Cortex-M33%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%BF%E3%82%A4%E3%83%97%EF%BC%9A%3C%2FSTRONG%3E%20LPDDR5%20-%20Ryzen%20RS2G32LO5D4FDB-23BT%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EDDR%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%88%EF%BC%9A%3C%2FSTRONG%3E%206400%20MT%2Fs%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E3%83%A9%E3%83%B3%E3%82%AF%E6%95%B0%EF%BC%9A%3C%2FSTRONG%3E%202%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E16%E3%83%93%E3%83%83%E3%83%88%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E6%95%B0%3A%3C%2FSTRONG%3E%202%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EDRAM%E6%A7%8B%E6%88%90%EF%BC%9A%3C%2FSTRONG%3E%2016Gb%EF%BC%9A2Gb%20x8%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8BDRAM%E3%81%AE%E7%B7%8F%E5%AE%B9%E9%87%8F%EF%BC%9A%3C%2FSTRONG%3E%2016384MB%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9A%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89DDR%E8%A8%AD%E5%AE%9A%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%3CSTRONG%3E%E3%80%81NXP%20i.MX95%2019x19%20EVK%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AELPDDR5%E6%A7%8B%E6%88%90%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6DDR%E6%A7%8B%E6%88%90%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81DDR%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%2F%E6%9B%B4%E6%96%B0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Config%20Tools%E3%81%AE%3CSTRONG%3E%E3%80%8C%E5%95%8F%E9%A1%8C%E3%80%8D%3C%2FSTRONG%3E%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E7%94%9F%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E2%80%A6%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%83%97%E3%83%AC%E3%83%93%E3%83%A5%E3%83%BC%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AB%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%B3%E3%83%BC%E3%83%89%E7%94%9F%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%82%92%E5%8F%82%E8%80%83%E8%B3%87%E6%96%99%E3%81%A8%E3%81%97%E3%81%A6%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%20from%202026-09-15%2011-40-00.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-15%2011-40-00.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-15%2011-40-00.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396384i719F3A8C6B30E8AB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%20from%202026-09-15%2011-40-00.png%22%20alt%3D%22Screenshot%20from%202026-09-15%2011-40-00.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%20from%202026-09-15%2011-40-00.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2026-09-15%2011-40-00%20%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX%20DDR%20Config%20Tool%20Code%20Generation%20Error%20%7C%7C%20iMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E6%97%A9%E3%81%8F%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E8%BF%AB%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%BF%85%E9%80%9F%E3%81%AA%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%A4%A7%E5%A4%89%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX%20DDR%20Config%20Tool%20Code%20Generation%20Error%20%7C%7C%20iMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%20.mex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BB%8A%E5%9B%9E%E3%81%AF%208GB%20LPDDR5%20Rayson%26nbsp%3BRS2G32LO5D4FDB-23BT%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX%20DDR%20Config%20Tool%20Code%20Generation%20Error%20%7C%7C%20iMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%A4%9C%E8%A8%BC%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81IMX95LPD5EVK-19.mex%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%A7%81%E3%81%AB%E9%80%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX%20DDR%20Config%20Tool%20Code%20Generation%20Error%20%7C%7C%20iMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%8F%BE%E5%9C%A8%E3%81%AF%20%3CSTRONG%3ELinux%E7%89%88%3C%2FSTRONG%3E%20%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%20from%202026-09-15%2015-56-04.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-15%2015-56-04.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-15%2015-56-04.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396414i814EADC30A6E5A49%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%20from%202026-09-15%2015-56-04.png%22%20alt%3D%22Screenshot%20from%202026-09-15%2015-56-04.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%20from%202026-09-15%2015-56-04.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2026-09-15%2015-56-04%20%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX%20DDR%20Config%20Tool%20Code%20Generation%20Error%20%7C%7C%20iMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EConfig_Tools_for_i.MX_26.06_x64%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE26.06%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ELinux%E7%89%88%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E7%A7%81%E3%81%AFWindows%E7%89%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%A4%9C%E8%A8%BC%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81IMX95LPD5EVK-19.mex%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%A7%81%E3%81%AB%E9%80%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX%20DDR%20Config%20Tool%20Code%20Generation%20Error%20%7C%7C%20iMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%80%82.mex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%A7%E3%82%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CSTRONG%3E%E3%80%8C%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E6%9B%B4%E6%96%B0%E3%80%8D%E3%82%92%3C%2FSTRONG%3E%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%3CSTRONG%3E%E3%80%8C%E3%82%B3%E3%83%BC%E3%83%89%E7%94%9F%E6%88%90%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%20from%202026-09-15%2015-31-15.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-15%2015-31-15.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-15%2015-31-15.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396411i512613F41E9DC531%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%20from%202026-09-15%2015-31-15.png%22%20alt%3D%22Screenshot%20from%202026-09-15%2015-31-15.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%20from%202026-09-15%2015-31-15.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2026-09-15%2015-31-15%20%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88.png%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%20from%202026-09-15%2015-36-58.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-15%2015-36-58.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202026-09-15%2015-36-58.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396413i870D71731EE341E0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%20from%202026-09-15%2015-36-58.png%22%20alt%3D%22Screenshot%20from%202026-09-15%2015-36-58.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%20from%202026-09-15%2015-36-58.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2026-09-15%2015-36-58%20%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX%20DDR%20Config%20Tool%20Code%20Generation%20Error%20%7C%7C%20iMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1.Config_Tools_for_i.MX_26.06_x64%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E6%96%B0%E3%81%97%E3%81%84%E6%A7%8B%E6%88%90%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%80%8C%E3%83%9C%E3%83%BC%E3%83%89%E3%80%8D%E3%81%AE%E4%B8%8B%E3%81%AB%E3%81%82%E3%82%8B%E3%80%8CIMX95LPD5EVK-19%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82DDR%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E3.%20%E3%80%8C%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%8D%E2%86%92%E3%80%8C%E4%BF%9D%E5%AD%98%E3%80%8D%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%99%E3%82%8B%E3%81%A8%E3%80%8C%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E6%9B%B4%E6%96%B0%E3%80%8D%E3%81%8C%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E4.%20%E3%80%8C%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%AB%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22yipingwang_0-1789463155201.png%22%20style%3D%22width%3A%20880px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yipingwang_0-1789463155201.png%22%20style%3D%22width%3A%20880px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yipingwang_0-1789463155201.png%22%20style%3D%22width%3A%20880px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F396407iCBDACB557BB026E9%2Fimage-dimensions%2F880x462%3Fv%3Dv2%22%20width%3D%22880%22%20height%3D%22462%22%20role%3D%22button%22%20title%3D%22yipingwang_0-1789463155201.png%22%20alt%3D%22yipingwang_0-1789463155201.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eyipingwang_0-1789463155201.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eyipingwang_0-1789463155201.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2413963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20iMX%20DDR%20Config%20Tool%20Code%20Generation%20Error%20%7C%7C%20iMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2413963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EUbuntu%20%3CSTRONG%3E24.04%20%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E8%A8%AD%E5%AE%9A%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%BF%85%E9%A0%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EUbuntu%2022.04%E3%81%A7%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81Ubuntu%2024.04%20OS%E3%81%ABconfigs%20tool%2026.06%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
