i want to use csi2-mipi interface in imx8mplus lpddr4 evk
2,998 次查看
srinivas_123
i am using imx8mplus lpddr4 evk, i build the IMXLXYOCTOUG v.LF6.1.55_2.2.0  bsp version.
how to use the CSI2-MIPI interface.it is not detecting. what are the configurations I have to do?
I am using the ov5640 camera, when I connect this camera to the CSI1-MIPI interface, the camera works.
suppose I connect to the CSI2-MIPI  interface, it is not working. what is the reason? if anyone knows please help me out.
Thanks &Regards
Srinivas
2,917 次查看
Chavira
Hi @srinivas_123!
Yes, that is correct.
You can check the device trees saved on the memory using the next commands:
"fatls mmc 1:1" for SD card boot
"fatls mmc 2:1" for MMC boot
Best Regards!
Chavira
7 回复数
2,974 次查看
KimberlyCarvajal
Hi Srinivas,
You could first check the CSI2-MIPI node in the device-tree. Check if there is a node for the ov5640 camera for the CSI2-MIPI and the state is set to "okay".
If the ov5640 camera does not have a node in the CSI2-MIPI you can try create it based on the node for the CSI1-MIPI.
Kimberly Carvajal
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
2,935 次查看
Chavira
Hi @srinivas_123!
Thank you for contacting NXP Support!
For iMX8MP you should set the device tree called "imx8mp-evk-basler-ov5640.dtb" or "imx8mp-evk-os08a20-ov5640.dtb"
https://www.nxp.com/docs/en/release-note/IMX_LINUX_RELEASE_NOTES.pdf
Best Regards!
Chavira
2,921 次查看
srinivas_123
set the dtb file means , change  variable fdtfile with file name  you given   fdtfile=imx8mp-evk.dtb .is it correct ?. i attached the uboot file .
thanks and Regards
srinivas
2,918 次查看
Chavira
Hi @srinivas_123!
Best Regards!
Chavira
2,874 次查看
srinivas_123
my fdtfile =imx8mp-evk.dtb
after running "fatls mmc 1:1"
it gives lots of dtb files . can you explain whether "imx8mp-evk-basler-ov5640.dtb" or "imx8mp-evk-os08a20-ov5640.dtb" files are read or not . is it required to change fdtfile=imx8mp-evk-basler-ov5640.dtb in uboot file .
2,873 次查看
srinivas_123
Hit any key to stop autoboot: 0
u-boot=>
u-boot=> fatls mmc 1:1
32856576 Image
58151 imx8mp-ab2.dtb
87685 imx8mp-evk-8mic-swpdm.dtb
87100 imx8mp-evk-basler-ov2775.dtb
86771 imx8mp-evk-basler-ov5640.dtb
85910 imx8mp-evk-basler.dtb
86823 imx8mp-evk-dpdk.dtb
66170 imx8mp-evk-dsp.dtb
86745 imx8mp-evk-dual-basler.dtb
86682 imx8mp-evk-dual-os08a20.dtb
86858 imx8mp-evk-dual-ov2775.dtb
86748 imx8mp-evk-ecspi-slave.dtb
86911 imx8mp-evk-flexcan2.dtb
88590 imx8mp-evk-hifiberry-dacplus.dtb
3059 imx8mp-evk-inmate.dtb
88089 imx8mp-evk-iqaudio-dacplus.dtb
88089 imx8mp-evk-iqaudio-dacpro.dtb
86963 imx8mp-evk-it6263-lvds-dual-channel.dtb
86786 imx8mp-evk-jdi-wuxga-lvds-panel.dtb
86991 imx8mp-evk-ndm.dtb
87119 imx8mp-evk-os08a20-ov5640.dtb
85973 imx8mp-evk-os08a20.dtb
87265 imx8mp-evk-ov2775-ov5640.dtb
87380 imx8mp-evk-ov2775.dtb
86911 imx8mp-evk-pcie-ep.dtb
89118 imx8mp-evk-revA3-8mic-revE.dtb
87446 imx8mp-evk-rm67191.dtb
87419 imx8mp-evk-rm67199.dtb
87895 imx8mp-evk-root.dtb
66874 imx8mp-evk-rpmsg-lpv.dtb
66898 imx8mp-evk-rpmsg.dtb
66247 imx8mp-evk-sof-pdm.dtb
66580 imx8mp-evk-sof-wm8960.dtb
86163 imx8mp-evk-spdif-lb.dtb
88743 imx8mp-evk-usdhc1-m2.dtb
86805 imx8mp-evk.dtb
8528 imx8mp_m7_TCM_hello_world.bin
139272 imx8mp_m7_TCM_low_power_wakeword.bin
20704 imx8mp_m7_TCM_rpmsg_lite_pingpong_rtos_linux_remote.bin
20096 imx8mp_m7_TCM_rpmsg_lite_str_echo_rtos.bin
56556 imx8mp_m7_TCM_sai_low_power_audio.bin
574328 tee.bin
System Volume Information/
56 .dropbox.device
43 file(s), 1 dir(s)
2,868 次查看
srinivas_123
i am connecting 0v5640 camera sensor to CSI2-MIPI interface
%3CLINGO-SUB%20id%3D%22lingo-sub-1868229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E6%83%B3%E5%9C%A8%20imx8mplus%20lpddr4%20evk%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20csi2-mipi%20%E6%8E%A5%E5%8F%A3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20imx8mplus%20lpddr4%20evk%EF%BC%8C%E6%88%91%E6%9E%84%E5%BB%BA%E4%BA%86%20IMXLXYOCTOUG%20v.LF6.1.55_2.2.0%20bsp%20%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8CSI2-MIPI%E6%8E%A5%E5%8F%A3%E3%80%82%E5%AE%83%E6%B2%A1%E6%9C%89%E6%A3%80%E6%B5%8B%E3%80%82%E6%88%91%E5%BF%85%E9%A1%BB%E5%81%9A%E5%93%AA%E4%BA%9B%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8ov5640%E7%9B%B8%E6%9C%BA%EF%BC%8C%E5%BD%93%E6%88%91%E5%B0%86%E6%AD%A4%E7%9B%B8%E6%9C%BA%E8%BF%9E%E6%8E%A5%E5%88%B0CSI1-MIPI%E6%8E%A5%E5%8F%A3%E6%97%B6%EF%BC%8C%E7%9B%B8%E6%9C%BA%E5%B0%B1%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E5%81%87%E8%AE%BE%E6%88%91%E8%BF%9E%E6%8E%A5%E5%88%B0CSI2-MIPI%E6%8E%A5%E5%8F%A3%EF%BC%8C%E5%AE%83%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E5%8E%9F%E5%9B%A0%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%EF%BC%8C%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%B8%8E%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3E%E6%96%AF%E9%87%8C%E5%B0%BC%E7%93%A6%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1869366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%88%91%E6%83%B3%E5%9C%A8%20imx8mplus%20lpddr4%20evk%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20csi2-mipi%20%E6%8E%A5%E5%8F%A3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1869366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%86%200v5640%20%E6%91%84%E5%83%8F%E5%A4%B4%E4%BC%A0%E6%84%9F%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%20CSI2-MIPI%20%E6%8E%A5%E5%8F%A3%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1869337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%88%91%E6%83%B3%E5%9C%A8%20imx8mplus%20lpddr4%20evk%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20csi2-mipi%20%E6%8E%A5%E5%8F%A3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1869337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E7%9A%84%20fdtfile%20%3Dimx8mp-evk.dtb%3CBR%20%2F%3E%E8%BF%90%E8%A1%8C%E2%80%9Cfatls%20mmc%201%3A1%E2%80%9D%E5%90%8E%3CBR%20%2F%3E%E5%AE%83%E6%8F%90%E4%BE%9B%E4%BA%86%E8%AE%B8%E5%A4%9A%20dtb%20%E6%96%87%E4%BB%B6%E3%80%82%E4%BD%A0%E8%83%BD%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E2%80%9Cimx8mp-evk-basler-ov5640.dtb%E2%80%9D%E8%BF%98%E6%98%AF%E2%80%9Cimx8mp-evk-os08a20-ov5640.dtb%E2%80%9D%E5%90%97%EF%BC%9F%E6%96%87%E4%BB%B6%E6%98%AF%E5%90%A6%E8%A2%AB%E8%AF%BB%E5%8F%96%E3%80%82%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%9C%A8%20uboot%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%9B%B4%E6%94%B9%20fdtfile%3Dimx8mp-evk-basler-ov5640.dtb%20%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1869076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%88%91%E6%83%B3%E5%9C%A8%20imx8mplus%20lpddr4%20evk%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20csi2-mipi%20%E6%8E%A5%E5%8F%A3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1869076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AE%BE%E7%BD%AE%20dtb%20%E6%96%87%E4%BB%B6%E6%84%8F%E5%91%B3%E7%9D%80%EF%BC%8C%E7%94%A8%E7%BB%99%E5%AE%9A%E7%9A%84%E6%96%87%E4%BB%B6%E5%90%8D%3CSTRONG%3Efdtfile%3Dimx8mp-evk.dtb%3C%2FSTRONG%3E%E6%9B%B4%E6%94%B9%E5%8F%98%E9%87%8F%3CSTRONG%3Efdtfile%3C%2FSTRONG%3E%20%E3%80%82%E5%AF%B9%E5%90%97%EF%BC%9F%E6%88%91%E9%99%84%E5%8A%A0%E4%BA%86%20uboot%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%B9%B6%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3E%E6%96%AF%E9%87%8C%E5%B0%BC%E7%93%A6%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%88%91%E6%83%B3%E5%9C%A8%20imx8mplus%20lpddr4%20evk%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20csi2-mipi%20%E6%8E%A5%E5%8F%A3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CSPAN%3ESrinivas%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%85%88%E6%A3%80%E6%9F%A5%3CSPAN%3E%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%E7%9A%84%20CSI2-MIPI%20%E8%8A%82%E7%82%B9%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%E6%A3%80%E6%9F%A5%20CSI2-MIPI%20%E5%AF%B9%E5%BA%94%E7%9A%84%20ov5640%20%E6%91%84%E5%83%8F%E5%A4%B4%E8%8A%82%E7%82%B9%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%EF%BC%8C%E5%B9%B6%E4%B8%94%E7%8A%B6%E6%80%81%E6%98%AF%E5%90%A6%E8%AE%BE%E7%BD%AE%E4%B8%BA%E2%80%9Cokay%E2%80%9D%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%20ov5640%20%E6%91%84%E5%83%8F%E5%A4%B4%E5%9C%A8%20CSI2-MIPI%20%E4%B8%AD%E6%B2%A1%E6%9C%89%E8%8A%82%E7%82%B9%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%9F%BA%E4%BA%8E%20CSI1-MIPI%20%E7%9A%84%E8%8A%82%E7%82%B9%E5%88%9B%E5%BB%BA%E5%AE%83%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%87%91%E4%BC%AF%E5%88%A9%C2%B7%E5%8D%A1%E7%93%A6%E5%93%88%E5%B0%94%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ERidgeRun%20%E5%B5%8C%E5%85%A5%E5%BC%8F%E8%BD%AF%E4%BB%B6%E5%B7%A5%E7%A8%8B%E5%B8%88%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E8%81%94%E7%B3%BB%E6%88%91%E4%BB%AC%EF%BC%9Asupport%40ridgerun.com%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%BC%80%E5%8F%91%E8%80%85%E7%BB%B4%E5%9F%BA%EF%BC%9A%3C%2FSPAN%3E%20%3CA%20href%3D%22https%3A%2F%2Fdeveloper.ridgerun.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdeveloper.ridgerun.com%3C%2FA%3E%3CBR%20%2F%3E%3CSPAN%3E%E7%BD%91%E7%AB%99%3A%3C%2FSPAN%3E%20%3CA%20href%3D%22http%3A%2F%2Fwww.ridgerun.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ewww.ridgerun.com%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
