i.mx93. Parallel display maximum resolution.
1,327 次查看
Serg_mx6
What is the maximum resolution of the i.mx93 for the parallel display interface? The document says 1366*768p60 or 1280*800p60. Is it possible to achieve higher resolution by reducing the frame rate?
1,279 次查看
riteshmpatel
Hi @Serg_mx6,
I hope you are doing well.
Please accept my apologies for the delay in response.
i.MX93 can support only the resolutions mentioned in the datasheet.
Thanks & Regards,
Ritesh M Patel
