i.mx93 LPSPI + eDMA problem on Cortex-M33
albi84
I’m using a Tria i.MX9332 (B1 silicon) SMARC module and trying to use LPSPI6 with eDMA on the Cortex-M33, but I can’t get it working.
Development environment
  • VS Code 1.109.0
  • MCUXpresso for VS Code extension 26.1.56
  • SDK 25.09.00
Hardware
  • Tria SM2S-IMX93 on a custom carrier board
  • LCD with ILI9341 controller connected via SPI (LPSPI6)
Current status
  • The display works correctly when using LPSPI6 without DMA.
  • I’m trying to switch to LPSPI6 + eDMA to improve throughput, but I cannot get completion notification.
Issue
The DMA-based transfer appears to start, but I never receive the LPSPI DMA completion callback at the end of the transfer.
Details and relevant code/config are in the attached file.
Could someone point out what I might be missing, or why the callback is not triggered?
pengyong_zhang
Hi @albi84
Please refer the attachment patch file configuration the LPDPI with EDMA
B.R
pengyong_zhang
Hi @albi84
B.R
albi84
Thank you for the sample code. Reviewing the example helped me to make it work.
rti
Can you please share the skeleton for the LPSPI with eDMA?
Thanks.
albi84
It is not a skeleton but the actual code I use. Does this help?
%3CLINGO-SUB%20id%3D%22lingo-sub-2314206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.mx93%20LPSPI%20%2B%20eDMA%20problem%20on%20Cortex-M33%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%E2%80%99m%20using%20a%20%3CSTRONG%3ETria%20i.MX9332%20(B1%20silicon)%20SMARC%20module%3C%2FSTRONG%3E%20and%20trying%20to%20use%20%3CSTRONG%3ELPSPI6%20with%20eDMA%20on%20the%20Cortex-M33%3C%2FSTRONG%3E%2C%20but%20I%20can%E2%80%99t%20get%20it%20working.%3C%2FP%3E%3CP%3E%3CSTRONG%3EDevelopment%20environment%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EVS%20Code%201.109.0%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EMCUXpresso%20for%20VS%20Code%20extension%2026.1.56%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ESDK%2025.09.00%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3EHardware%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3ETria%20SM2S-IMX93%20on%20a%20custom%20carrier%20board%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ELCD%20with%20%3CSTRONG%3EILI9341%3C%2FSTRONG%3E%20controller%20connected%20via%20SPI%20(LPSPI6)%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3ECurrent%20status%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EThe%20display%20works%20correctly%20when%20using%20%3CSTRONG%3ELPSPI6%20without%20DMA%3C%2FSTRONG%3E.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EI%E2%80%99m%20trying%20to%20switch%20to%20%3CSTRONG%3ELPSPI6%20%2B%20eDMA%3C%2FSTRONG%3E%20to%20improve%20throughput%2C%20but%20I%20cannot%20get%20completion%20notification.%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3EIssue%3C%2FSTRONG%3E%3CBR%20%2F%3EThe%20DMA-based%20transfer%20appears%20to%20start%2C%20but%20I%20%3CSTRONG%3Enever%20receive%20the%20LPSPI%20DMA%20completion%20callback%3C%2FSTRONG%3E%20at%20the%20end%20of%20the%20transfer.%3C%2FP%3E%3CP%3EDetails%20and%20relevant%20code%2Fconfig%20are%20in%20the%20attached%20file.%3CBR%20%2F%3ECould%20someone%20point%20out%20what%20I%20might%20be%20missing%2C%20or%20why%20the%20callback%20is%20not%20triggered%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2315795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.mx93%20LPSPI%20%2B%20eDMA%20problem%20on%20Cortex-M33%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2315795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20the%20sample%20code.%20Reviewing%20the%20example%20helped%20me%20to%20make%20it%20work.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2315262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.mx93%20LPSPI%20%2B%20eDMA%20problem%20on%20Cortex-M33%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2315262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259680%22%20target%3D%22_blank%22%3E%40albi84%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20refer%20the%20attachment%20patch%20file%20configuration%20the%20LPDPI%20with%20EDMA%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2327224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.mx93%20LPSPI%20%2B%20eDMA%20problem%20on%20Cortex-M33%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECan%20you%20please%20share%20the%20skeleton%20for%20the%20LPSPI%20with%20eDMA%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.mx93%20LPSPI%20%2B%20eDMA%20problem%20on%20Cortex-M33%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt%20is%20not%20a%20skeleton%20but%20the%20actual%20code%20I%20use.%20Does%20this%20help%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
