We have an existing product that we're experimenting with various form factors and displays. We noticed a very big performance difference in Android when we moved to a bigger display.
First configuration: 720x1280 mipi dsi display on lcdif3 (similar to a phone form factor) Performance is as expected. Responsive UI, touch screen and graphics.
2nd configuration: 1920x1200 dual channel LVDS display on lcdif2 (similar to a tablet form factor). The software is the same as the first configuration except a different DTS file for the display config. In this configuration, the performance is pretty laggy. Camera captures lag many frames. The UI is very sluggish and jerky when dragging menus and navigating.
Our LVDS panel uses the spwg encoding and is full dual channel on all 8 data lines. Is there reason to suspect the imx8 plus can't drive this large of a display on LVDS or should we be looking for other reasons the performance is not as expected?
