i.mx6sl kernel and mmc boot issue
jayakumar2
Contributor V
Hi, I'm bringing up a board that uses the i.mx6sl. It is based closely on the i.mx6sl evk. I'm currently having a problem where the kernel fails to mount the rootfs. In u-boot, I'm able to read from the MMC device fine which suggests a possible mistake in my configuration of iomux or something else in the board file in the kernel. The board uses SDHC2 (2nd SDHC interface) as the boot MMC interface, just like i.mx6slevk. I've turned on MMC_DEBUG in the kernel and here's what I see when comparing the boot log between the EVK and my board.
In the failing case, I'm seeing:
mmc0: starting CMD52 arg 00000c00 flags 00000195
mmc0: req done (CMD52): -123: 00000000 00000000 00000000 00000000
sdhci: ===========================================
mmc0: starting CMD52 arg 80000c08 flags 00000195
mmc1: clock 0Hz busmode 1 powermode 0 cs 0 Vdd 0 width 0 timing 0
whereas on the mx6slevk, I'm seeing:
sdhci [sdhci_irq()]: *** mmc0 got interrupt: 0x00010000
mmc0: req done (CMD52): -110: 00000000 00000000 00000000 00000000
In the failing case, there does not appear to be any sdhci_irq's being
fired. I'm not sure why that's the case. mmc0 req done -123 is -ENOMEDIUM whereas in the working case, I see req done -110 which is ETIMEDOUT. It works fine in the -110 log.
In the board file code, I had done:
        platform_device_register(&evk_vmmc_reg_devices);
#if 0 /* xxxjaya original code */
        imx6q_add_sdhci_usdhc_imx(0, &mx6_evk_sd1_data);
        imx6q_add_sdhci_usdhc_imx(1, &mx6_evk_sd2_data);
        imx6q_add_sdhci_usdhc_imx(2, &mx6_evk_sd3_data);
#endif
        imx6q_add_sdhci_usdhc_imx(0, &mx6_evk_sd2_data);
        imx6q_add_sdhci_usdhc_imx(1, &mx6_evk_sd3_data);
I wonder if perhaps this is a mistake and is the root cause of the problem. The other area that I'm suspicious about is whether the problem could be due to a core clock rate difference because the EVK is run at 396MHz whereas my board is running at 792MHz.
My board:
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Thermal sensor with ratio = 176
Temperature:   41 C, calibration data 0x55b4e45f
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 198000000Hz
emi_slow clock: 99000000Hz
ddr clock     : 396000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
6SLEVK board:
CPU: Freescale i.MX6 family TO1.2 at 396 MHz
Thermal sensor with ratio = 182
Temperature:   33 C, calibration data 0x57f5115f
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 49500000Hz
ipg per clock : 49500000Hz
ahb clock     : 99000000Hz
Thanks.
Detailed kernel bootlog for faliing case on my board:
In:    serial
Out:   serial
Err:   serial
Found PFUZE100! deviceid=10,revid=21
Net:   No ethernet found.
Hit any key to stop autoboot:  0
mmc0 is current device
MMC read: dev # 0, block # 2048, count 8192 ... 8192 blocks read: OK
## Booting kernel from Legacy Image at 80800000 ...
   Image Name:   Linux-3.0.35-2666-gbdde708-gf574
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3152556 Bytes =  3 MB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.35-2666-gbdde708-gf574c61-dirty (lucid@ubuntu) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #22 PREEMPT Fri Mar 7 22:47:59 PST 2014
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6SoloLite EVK Board
Memory policy: ECC disabled, Data cache writeback
CPU identified as i.MX6SoloLite, silicon rev 1.2
On node 0 totalpages: 131072
free_area_init_node: node 0, pgdat 80608af8, node_mem_map 8b800000
  DMA zone: 368 pages used for memmap
  DMA zone: 0 pages reserved
  DMA zone: 46736 pages, LIFO batch:15
  Normal zone: 656 pages used for memmap
  Normal zone: 83312 pages, LIFO batch:15
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Kernel command line: console=ttymxc0,115200 loglevel=8 root=/dev/mmcblk0p1 rootwait video=mxcepdcfb:E060SCM,bpp=16
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 512MB = 512MB total
Memory: 513436k/513436k available, 10852k reserved, 0K highmem
XC GPIO hardware
sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
arm_max_freq=1GHz
MXC_Early serial console at MMIO 0x2020000 (options '115200')
bootconsole [ttymxc0] enabled
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
Mount-cache hash table entries: 512
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
print_constraints: dummy:
print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
print_constraints: vddcore: 725 <--> 1300 mV at 1100 mV fast normal
print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x02030000, Cache size: 262144 B
bio: create slab <bio-0> at 0
print_constraints: vmmc: 3300 mV
print_constraints: SPKVDD: 4325 mV
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
mc_pfuze 0-0008: ID: 0,Full lay: 2 ,Metal lay: 1
mc_pfuze 0-0008: FAB: 0 ,FIN: 0
print_constraints: PFUZE100_SW1A: 300 <--> 1875 mV at 1300 mV
print_constraints: PFUZE100_SW1B: 300 <--> 1875 mV at 300 mV
print_constraints: PFUZE100_SW1C: 300 <--> 1875 mV at 1300 mV
print_constraints: PFUZE100_SW2: 800 <--> 3950 mV at 3150 mV
print_constraints: PFUZE100_SW3A: 400 <--> 1975 mV at 1200 mV
print_constraints: PFUZE100_SW3B: 400 <--> 1975 mV at 1200 mV
print_constraints: PFUZE100_SW4: 800 <--> 3950 mV at 3300 mV
print_constraints: PFUZE100_SWBST: 5000 <--> 5150 mV at 5000 mV
print_constraints: PFUZE100_VSNVS: 1200 <--> 3000 mV at 1800 mV
print_constraints: PFUZE100_VREFDDR: at 750 mV
print_constraints: PFUZE100_VGEN1: 800 <--> 1550 mV at 1200 mV
print_constraints: PFUZE100_VGEN2: 800 <--> 1550 mV at 800 mV
print_constraints: PFUZE100_VGEN3: 1800 <--> 3300 mV at 1800 mV
print_constraints: PFUZE100_VGEN4: 1800 <--> 3300 mV at 1800 mV
print_constraints: PFUZE100_VGEN5: 1800 <--> 3300 mV at 2500 mV
print_constraints: PFUZE100_VGEN6: 1800 <--> 3300 mV at 1800 mV
i2c i2c-1: Invalid 7-bit I2C address 0x00
i2c i2c-1: Can't create device at 0x00
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
max17135 0-0048: Max17135 PMIC not found!
max17135 regulator init failed: -6
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
Switching to clocksource mxc_timer1
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
fsl-usb2-udc: bind to driver g_ether
mousedev: PS/2 mouse device common for all mice
input: imx-keypad as /devices/platform/imx-keypad/input/input0
snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
i2c /dev entries driver
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci sdhci-esdhc-imx.1: no write-protect pin available!
sdhci [sdhci_add_host()]: Disabling ADMA as it is marked broken
sdhci [sdhci_add_host()]: mmc0: Auto-CMD23 unavailable
sdhci: =========== REGISTER DUMP (mmc0)===========
sdhci: Sys addr: 0x00000000 | Version:  0x00000202
sdhci: Blk size: 0x00000200 | Blk cnt:  0x00000001
sdhci: Argument: 0x00020000 | Trn mode: 0x00000000
sdhci: Present:  0xfff88088 | Host ctl: 0x00000002
sdhci: Power:    0x0000000d | Blk gap:  0x00000000
sdhci: Wake-up:  0x00000000 | Clock:    0x00000118
sdhci: Timeout:  0x00000000 | Int stat: 0x00000000
sdhci: Int enab: 0x007f0003 | Sig enab: 0x007f0003
sdhci: AC12 err: 0x00000000 | Slot int: 0x00000202
sdhci: Caps:     0x07ebb407 | Caps_1:   0x0000b407
sdhci: Cmd:      0x00000d1a | Max curr: 0x00ffffff
sdhci: Host ctl2: 0x00000000
mmc0: clock 0Hz busmode 1 powermode 0 cs 0 Vdd 0 width 0 timing 0
mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz
mmc0: SDHCI controller on platform [sdhci-esdhc-imx.1] using DMA
sdhci sdhci-esdhc-imx.2: no write-protect pin available!
mmc0: clock 0Hz busmode 1 powermode 1 cs 0 Vdd 21 width 0 timing 0
sdhci [sdhci_add_host()]: mmc1: Auto-CMD23 unavailable
mmc0: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.1: desired SD clock: 400000, actual: 375000
sdhci: =========== REGISTER DUMP (mmc1)===========
sdhci: Blk size: 0x00000000 | Blk cnt:  0x00000001
sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
sdhci: Present:  0xfff88088 | Host ctl: 0x00000000
sdhci: Wake-up:  0x00000000 | Clock:    0x0000800f
sdhci: Cmd:      0x00000000 | Max curr: 0x00ffffff
mmc0: clock 400000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
Cirrus Logic CS42888 ALSA SoC Codec Driver
mmc0: starting CMD0 arg 00000000 flags 000000c0
mmc0: req done (CMD0): -123: 00000000 00000000 00000000 00000000
i2c-core: driver [cs42888] using legacy suspend method
i2c-core: driver [cs42888] using legacy resume method
imx_3stack asoc driver
ALSA device list:
  No soundcards found.
TCP cubic registered
can: controller area network core (rev 20090105 abi 8)
mmc0: starting CMD8 arg 000001aa flags 000002f5
mmc0: req done (CMD8): -123: 00000000 00000000 00000000 00000000
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
mmc0: starting CMD5 arg 00000000 flags 000002e1
can: broadcast manager protocol (rev 20090105 t)
mmc0: req failed (CMD5): -123, retrying...
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
mmc0: req done (CMD5): -123: 00000000 00000000 00000000 00000000
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
lib80211: common routines for IEEE802.11 drivers
mmc0: starting CMD55 arg 00000000 flags 000000f5
mmc0: req done (CMD55): -123: 00000000 00000000 00000000 00000000
lib80211_crypt: registered algorithm 'NULL'
VFP support v0.3:
mmc0: starting CMD1 arg 00000000 flags 000000e1
implementor 41 architecture 3 part 30 variant 9 rev 4
mmc0: req done (CMD1): -123: 00000000 00000000 00000000 00000000
mmc0: mmc_rescan_try_freq: trying to init card at 300000 Hz
Bus freq driver module loaded
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
regulator_init_complete: PFUZE100_VGEN5: incomplete constraints, leaving on
regulator_init_complete: SPKVDD: incomplete constraints, leaving on
mmc0: clock 300000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
Waiting for root device /dev/mmcblk0p1...
mmc0: clock 300000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.1: desired SD clock: 300000, actual: 281250
Labels (2)
Tags (3)
jayakumar2
Contributor V
Ok, solved. It turned out SD2_RST was left as gpio input and that seems to cause it to fail. Setting it to output instead makes everything work.
jayakumar2
Contributor V
Just to add, if I try instead:
//      imx6q_add_sdhci_usdhc_imx(0, &mx6_evk_sd1_data);
ie: leave the index values the same, because it is used in plt_sd_pad_change then I still get a similar failure:
ALSA device list:
VFP support v0.3:
mxc_dvfs_core_probe
mmc0: mmc_rescan_try_freq: trying to init card at 200000 Hz
mmc0: clock 200000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.1: desired SD clock: 200000, actual: 187500
mmc0: clock 200000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc0: mmc_rescan_try_freq: trying to init card at 100000 Hz
mmc0: clock 100000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.1: desired SD clock: 100000, actual: 93750
mmc0: clock 100000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: mmc_rescan_try_freq: trying to init card at 400000 Hz
mmc1: clock 0Hz busmode 1 powermode 1 cs 0 Vdd 21 width 0 timing 0
mmc1: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.2: desired SD clock: 400000, actual: 375000
mmc1: starting CMD52 arg 00000c00 flags 00000195
mmc1: req done (CMD52): -123: 00000000 00000000 00000000 00000000
mmc1: starting CMD52 arg 80000c08 flags 00000195
mmc1: clock 400000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: starting CMD0 arg 00000000 flags 000000c0
mmc1: req done (CMD0): -123: 00000000 00000000 00000000 00000000
mmc1: starting CMD8 arg 000001aa flags 000002f5
mmc1: req done (CMD8): -123: 00000000 00000000 00000000 00000000
mmc1: starting CMD5 arg 00000000 flags 000002e1
mmc1: req failed (CMD5): -123, retrying...
mmc1: req done (CMD5): -123: 00000000 00000000 00000000 00000000
mmc1: starting CMD55 arg 00000000 flags 000000f5
mmc1: req done (CMD55): -123: 00000000 00000000 00000000 00000000
mmc1: starting CMD1 arg 00000000 flags 000000e1
mmc1: req done (CMD1): -123: 00000000 00000000 00000000 00000000
mmc1: mmc_rescan_try_freq: trying to init card at 300000 Hz
mmc1: clock 300000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.2: desired SD clock: 300000, actual: 281250
mmc1: clock 300000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: mmc_rescan_try_freq: trying to init card at 200000 Hz
mmc1: clock 200000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.2: desired SD clock: 200000, actual: 187500
mmc1: clock 200000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: mmc_rescan_try_freq: trying to init card at 100000 Hz
mmc1: clock 100000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.2: desired SD clock: 100000, actual: 93750
mmc1: clock 100000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
<7>mmc1: req done (CMD55): -123: 00000000 00000000 00000000 00000000
jayakumar2
Contributor V
I'm starting to suspect that the clock speed is involved. In the working case on 6slevk, I see:
mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 17 width 0 timing 2
mmc0: clock 50000000Hz busmode 2 powermode 2 cs 0 Vdd 17 width 0 timing 2
sdhci sdhci-esdhc-imx.1: desired SD clock: 50000000, actual: 45000000
mmc0: starting CMD55 arg 00020000 flags 00000095
sdhci [sdhci_irq()]: *** mmc0 got interrupt: 0x00000001
mmc0: req done (CMD55): 0: 00000920 00000000 00000000 00000000
mmc0: starting CMD6 arg 00000002 flags 00000015
mmc0: req done (CMD6): 0: 00000920 00000000 00000000 00000000
mmc0: clock 50000000Hz busmode 2 powermode 2 cs 0 Vdd 17 width 2 timing 2
mmc0: new high speed SD card at address 0002
mmc0: starting CMD16 arg 00000200 flags 00000095
Isolating those messages in the working case, shows:
In the failing case, it shows:
so it seems like it did not get to the 50MHz clock that in the working case is MMC0 (imx.1).
jayakumar2
Contributor V
