Just to add, if I try instead:
// imx6q_add_sdhci_usdhc_imx(0, &mx6_evk_sd1_data);
imx6q_add_sdhci_usdhc_imx(1, &mx6_evk_sd2_data);
imx6q_add_sdhci_usdhc_imx(2, &mx6_evk_sd3_data);
ie: leave the index values the same, because it is used in plt_sd_pad_change then I still get a similar failure:
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci sdhci-esdhc-imx.1: no write-protect pin available!
sdhci [sdhci_add_host()]: Disabling ADMA as it is marked broken
sdhci [sdhci_add_host()]: mmc0: Auto-CMD23 unavailable
sdhci: =========== REGISTER DUMP (mmc0)===========
sdhci: Sys addr: 0x00000000 | Version: 0x00000202
sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000001
sdhci: Argument: 0x00020000 | Trn mode: 0x00000000
sdhci: Present: 0xfff88088 | Host ctl: 0x00000002
sdhci: Power: 0x0000000d | Blk gap: 0x00000000
sdhci: Wake-up: 0x00000000 | Clock: 0x00000118
sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
sdhci: Int enab: 0x007f0003 | Sig enab: 0x007f0003
sdhci: AC12 err: 0x00000000 | Slot int: 0x00000202
sdhci: Caps: 0x07ebb407 | Caps_1: 0x0000b407
sdhci: Cmd: 0x00000d1a | Max curr: 0x00ffffff
sdhci: Host ctl2: 0x00000000
sdhci: ===========================================
mmc0: clock 0Hz busmode 1 powermode 0 cs 0 Vdd 0 width 0 timing 0
mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz
mmc0: SDHCI controller on platform [sdhci-esdhc-imx.1] using DMA
sdhci sdhci-esdhc-imx.2: no write-protect pin available!
mmc0: clock 0Hz busmode 1 powermode 1 cs 0 Vdd 21 width 0 timing 0
sdhci [sdhci_add_host()]: mmc1: Auto-CMD23 unavailable
mmc0: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.1: desired SD clock: 400000, actual: 375000
sdhci: =========== REGISTER DUMP (mmc1)===========
sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000001
sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
sdhci: Present: 0xfff88088 | Host ctl: 0x00000000
sdhci: Wake-up: 0x00000000 | Clock: 0x0000800f
sdhci: Cmd: 0x00000000 | Max curr: 0x00ffffff
mmc0: starting CMD52 arg 00000c00 flags 00000195
mmc0: req done (CMD52): -123: 00000000 00000000 00000000 00000000
mmc0: starting CMD52 arg 80000c08 flags 00000195
mmc1: clock 0Hz busmode 1 powermode 0 cs 0 Vdd 0 width 0 timing 0
mmc0: clock 400000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
usbhid: USB HID core driver
Cirrus Logic CS42888 ALSA SoC Codec Driver
mmc0: starting CMD0 arg 00000000 flags 000000c0
mmc0: req done (CMD0): -123: 00000000 00000000 00000000 00000000
i2c-core: driver [cs42888] using legacy suspend method
i2c-core: driver [cs42888] using legacy resume method
imx_3stack asoc driver
ALSA device list:
No soundcards found.
TCP cubic registered
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
mmc0: starting CMD8 arg 000001aa flags 000002f5
mmc0: req done (CMD8): -123: 00000000 00000000 00000000 00000000
mmc0: starting CMD5 arg 00000000 flags 000002e1
mmc0: req failed (CMD5): -123, retrying...
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
mmc0: req done (CMD5): -123: 00000000 00000000 00000000 00000000
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
lib80211: common routines for IEEE802.11 drivers
mmc0: starting CMD55 arg 00000000 flags 000000f5
mmc0: req done (CMD55): -123: 00000000 00000000 00000000 00000000
lib80211_crypt: registered algorithm 'NULL'
VFP support v0.3:
mmc0: starting CMD1 arg 00000000 flags 000000e1
implementor 41 architecture 3 part 30 variant 9 rev 4
mmc0: req done (CMD1): -123: 00000000 00000000 00000000 00000000
mmc0: mmc_rescan_try_freq: trying to init card at 300000 Hz
Bus freq driver module loaded
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
regulator_init_complete: PFUZE100_VGEN5: incomplete constraints, leaving on
regulator_init_complete: SPKVDD: incomplete constraints, leaving on
mmc0: clock 300000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
Waiting for root device /dev/mmcblk0p1...
mmc0: clock 300000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.1: desired SD clock: 300000, actual: 281250
mmc0: mmc_rescan_try_freq: trying to init card at 200000 Hz
mmc0: clock 200000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.1: desired SD clock: 200000, actual: 187500
mmc0: clock 200000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc0: mmc_rescan_try_freq: trying to init card at 100000 Hz
mmc0: clock 100000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.1: desired SD clock: 100000, actual: 93750
mmc0: clock 100000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: mmc_rescan_try_freq: trying to init card at 400000 Hz
mmc1: clock 0Hz busmode 1 powermode 1 cs 0 Vdd 21 width 0 timing 0
mmc1: clock 400000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.2: desired SD clock: 400000, actual: 375000
mmc1: starting CMD52 arg 00000c00 flags 00000195
mmc1: req done (CMD52): -123: 00000000 00000000 00000000 00000000
mmc1: starting CMD52 arg 80000c08 flags 00000195
mmc1: clock 400000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: starting CMD0 arg 00000000 flags 000000c0
mmc1: req done (CMD0): -123: 00000000 00000000 00000000 00000000
mmc1: starting CMD8 arg 000001aa flags 000002f5
mmc1: req done (CMD8): -123: 00000000 00000000 00000000 00000000
mmc1: starting CMD5 arg 00000000 flags 000002e1
mmc1: req failed (CMD5): -123, retrying...
mmc1: req done (CMD5): -123: 00000000 00000000 00000000 00000000
mmc1: starting CMD55 arg 00000000 flags 000000f5
mmc1: req done (CMD55): -123: 00000000 00000000 00000000 00000000
mmc1: starting CMD1 arg 00000000 flags 000000e1
mmc1: req done (CMD1): -123: 00000000 00000000 00000000 00000000
mmc1: mmc_rescan_try_freq: trying to init card at 300000 Hz
mmc1: clock 300000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.2: desired SD clock: 300000, actual: 281250
mmc1: clock 300000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: mmc_rescan_try_freq: trying to init card at 200000 Hz
mmc1: clock 200000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.2: desired SD clock: 200000, actual: 187500
mmc1: clock 200000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
mmc1: mmc_rescan_try_freq: trying to init card at 100000 Hz
mmc1: clock 100000Hz busmode 1 powermode 2 cs 0 Vdd 21 width 0 timing 0
sdhci sdhci-esdhc-imx.2: desired SD clock: 100000, actual: 93750
mmc1: clock 100000Hz busmode 1 powermode 2 cs 1 Vdd 21 width 0 timing 0
<7>mmc1: req done (CMD55): -123: 00000000 00000000 00000000 00000000
