i.mx6 eval board for hypervisor
3,750件の閲覧回数
mshanka1
I am planning to find a evalulation board which can support embedded hypervisor functionality.
Dose i.mx6 evaluation board work for me. I also need one TFT carrier board which supports this evaluation board.
Can you suggest me the board (evaluation board with TFT) and the estimated price.
3,585件の閲覧回数
Chavira
Hi @mshanka1!
We don´t have an LVDS panel for our board probably you can buy one outside of NXP.
We only have this panel available for the iMX8QM MEK board
https://www.nxp.com/part/MX8-DSI-OLED1A#/
https://www.nxp.com/design/development-boards/i-mx-evaluation-and-development-boards/i-mx-8quadmax-m...
Best Regards!
Chavira
6 返答(返信)
3,693件の閲覧回数
Chavira
Hi @mshanka1!
No you can't port the Xen hypervisor since it requires an ARM processor with Virtualization instructions like the Cortex-A15 or Cortex-A7. The Cortex-A9 of the i.MX6 doesn't have those instructions.
https://wiki.xenproject.org/wiki/Xen_ARM_with_Virtualization_Extensions
I recommend to check our iMX8 evaluation kits for this job.
Best regards!
Chavira
3,691件の閲覧回数
mshanka1
@Chavira Thank you for the response. I have identified i.MX8QuadMax EVK which supports xen hypersivor.
Is this correct? Is this the only board or any i.MX8 eval kits support xen hypervisor?
3,649件の閲覧回数
Chavira
Hi @mshanka1!
Yes, the board supports Xen hypervisor, but I have to mention that Xen hypervisor is not provided by NXP and we don't support that software if you need help implementing this software to the board we can’t help you.
Best Regards!
Chavira
3,647件の閲覧回数
mshanka1
@Chavira thank you for your response. Is there a LVDS Display i can add with the i.MX8QuadMax Eval kit?
3,586件の閲覧回数
Chavira
Hi @mshanka1!
Best Regards!
Chavira
3,544件の閲覧回数
mshanka1
Hi @Chavira ,
I have few quiries regarding the work station requirements to build the iMX8QuadMax software?
is there any specific ubuntu version is required for the cross compilation and application development on the iMX8QuadMax MEK board? what are the other software tools required? is there any How to guide available on the development f applications?
