I am trying to read the status of a GPIO in plugin.S in u-boot.
I have tried the following, but seemed not reading the correct values.
#define GPIO2_DR_ADDR 0x020A0000
#define GPIO2_DIR_ADDR 0x020A0004
#define GPIO2_DIR_CFG 0x00000000
#define IOMUXC_SW_PAD_CTL_PAD_NAND_DATA02_ADDR 0x020E06EC
#define BOARD_0_PAD_CFG 0x3000
#define IOMUXC_SW_MUX_CTL_PAD_NAND_DATA02_ADDR 0x020E0304
#define BOARD_0_ALT_CFG 0x5
ldr r0, =IOMUXC_SW_PAD_CTL_PAD_NAND_DATA02_ADDR
ldr r1, =BOARD_0_PAD_CFG
str r1, [r0]
ldr r0, =IOMUXC_SW_MUX_CTL_PAD_NAND_DATA02_ADDR
ldr r1, =BOARD_0_ALT_CFG
str r1, [r0]
ldr r0, =GPIO2_DIR_ADDR
ldr r1, =GPIO2_DIR_CFG
str r1, [r0]
ldr r0, =GPIO2_DR_ADDR
ldr r1, [r0]
The bit 3 of r1 is expected to have the status of GPIO 34, but it returns always 0.
I am wondering what are missing and not correct. Is there need any other resources should be configured ?
Thanks and Regards,
Taehyuk
