i.mx6 board stack up
14,830 次查看
douglasbolton
My PCB fabricator is having trouble achieving the same impedance control used for the i.mx6 SD reference design stackup -
Layer1 = 1/2 oz to 1 oz
Layer2 = 1 oz
Layer3 = 1/2 oz
Layer4 = 1 oz
Layer5 = 1 oz
Layer6 = 1/2 oz
Layer7 = 1 oz
Layer8 = 1/2 oz to 1 oz
Impedance control Single
50R Layer1/Layer8 = 4.7 mil
50R Layer3/Layer6 = 4.5 mil
Impedance Control Differential
90R Layer1/Layer2/Layer3/Layer4 = 5.3/3.7 mil
100R Layer1/Layer8 = 3.7/5.3 mil
100R Layer3/Layer6 = 3.8/5.2 mil
Does anyone have PCB fabrication details (dielectric thickness etc) using the parameters above.
Doug.
标记 (3)
12 回复数
13,370 次查看
JorgeRama_rezRi
Hi Doug,
Please find attached the actual numbers with wich the board was manufactured.
Best regards.
Jorge.
13,370 次查看
marksiggins
Hi Jorge.
Did this ever come to a conclusion? I need the same information, as I am about to start layout of an iMX6 design, and the gerber notes, the word document, and that spreadsheet, all conflict with each other.
Can you tell us please, which is correct?
Mark.
13,370 次查看
noeliascotti
I'm defining the stackup for my iMX6 board and I'm confused because the Freescale info is a mess.
Does anyone have the correct info?
Noelia
13,370 次查看
douglasbolton
Hi Jorge,
Thank you for the information.
I still have some doubts.
In the gerber files the differential track width/spacing/width's are -
90R = 5.3/3.7/5.3
100R = 3.7/5.3/3.7 & 3.8/5.2/3.8
In the spreadsheet you sent the differential track width/spacing/width's are -
90R = 5.3/9/5.3
100R = 3.7/9/3.7 & 3.8/9/3.8
Also in the spreadsheet the internal layer copper thicknesses are all the same (1.3mils). The gerber file fabrication notes have different copper thicknesses for the internal layers.
I may be reading this wrongly but I still don't think this spreadsheet matches the gerber fabrication notes or differential tracks.
Thanks again for your help.
Doug.
13,370 次查看
Richard1z
Hi Doug,
did you ever get a successful conclusion on this ?
I'm facing the same problems with the the Freescale documentation inconsistencies while designing an iMX6D/Q board.
Richard.
13,370 次查看
douglasbolton
Sorry, slight correction to the impedance layers-
Layer2 = 1 oz
Layer3 = 1/2 oz
Layer4 = 1 oz
Layer5 = 1 oz
Layer6 = 1/2 oz
Layer7 = 1 oz
90R Layer1/Layer8 = 5.3/3.7 mil
13,370 次查看
JorgeRama_rezRi
Hi Douglas,
Please find attached the dielectric thickness data of our SDP, which uses the same characteristics you mentioned. Please let me know if you need any other data.
Best regards.
Jorge.
13,370 次查看
douglasbolton
Thank you Jorge.
I am just concerned that the stack up table (dielectric etc) uses different copper weights than those in the first part of the document and also on the gerbers -
Your attached table =
3/8 oz copper
1/2 oz copper
1/2 oz copper
1/2 oz copper
1/2 oz copper
1/2 oz copper
1/2 oz copper
3/8 oz copper
Gerbers =
Layer2 = 1 oz
Layer3 = 1/2 oz
Layer4 = 1 oz
Layer5 = 1 oz
Layer6 = 1/2 oz
Layer7 = 1 oz
Which copper weights are correct for the Freescale SD board ?
Doug.
13,370 次查看
YixingKong
Senior Contributor IV
Hi Dong,
Has JorgeRama_rezRivero answered you?
13,370 次查看
douglasbolton
No I haven't had an answer yet.
Doug.
13,370 次查看
JorgeRama_rezRi
Hi Doug,
I've sent an e-mail to the guys in charge of the manufacture to check the actual numbers. I'll let you know the answer asap.
Best regards.
Jorge.
13,370 次查看
JorgeRama_rezRi
Hi Doug,
Didn't notice that. Let me confirm and I'll get back to you asap.
Best regards.
Jorge.
