[i.MX93] temperature grade is wrong
3,500件の閲覧回数
yoooh8668
I found the imx93 (rev.beta) does not match the temperature grade as it should be.
Here is the picture and its uboot log:
REV.beta
U-Boot 2023.04-00263-g7c7dd0dc2b0 (Apr 19 2024 - 15:50:35 +0800)
CPU:   i.MX93(52) rev1.0 1700 MHz (running at 1692 MHz)
CPU:   Consumer temperature grade (0C to 95C) at 51C
REV.GA
CPU:   i.MX93(52) rev1.1 1700 MHz (running at 1692 MHz)
CPU:   Consumer temperature grade (0C to 95C) at 35C
and here is the reference picture:
I'm afraid that the detect code in uboot is not correct.
//arch/arm/mach-imx/imx9/soc.c
u32 get_cpu_temp_grade(int *minc, int *maxc)
        int ret;
        u32 val;
        ret = fuse_read(2, 3, &val);
        if (ret)
                val = 0; /* If read fuse failed, return as blank fuse */
        val >>= 4;
        val &= 0x3;
        if (minc && maxc) {
                if (val == TEMP_AUTOMOTIVE) {
                        *minc = -40;
                        *maxc = 125;
                } else if (val == TEMP_INDUSTRIAL) {
                        *minc = -40;
                        *maxc = 105;
                } else if (val == TEMP_EXTCOMMERCIAL) {
                        if (is_imx93()){
                                /* imx93 only has extended industrial*/
                                *minc = -40;
                                *maxc = 125;
                        } else {
                                *minc = -20;
                                *maxc = 105;
                } else {
                        *minc = 0;
                        *maxc = 95;
        return val;
 THANKS~~
タグ(2)
3,354件の閲覧回数
JorgeCas
The last release that is supported on A0 revision is Linux 6.1.22_2.0.0.
But I confirmed that behavior on our EVK. This could be caused by placeholder on the code, or this feature could not be implemented on the pre-production revision.
Best regards.
5 返答(返信)
3,461件の閲覧回数
opedis
In the picture, the Q(Qualification leve) is "P".
Maybe that is problem. It is just a samples. Not a mass production.
3,453件の閲覧回数
yoooh8668
I think so, but wait for official reply.
3,469件の閲覧回数
JorgeCas
That is strange since the part number indicates that correspond to an industrial part number.
Is this happening on other REV.beta devices?
Which are the software versions that you are using?
From what I have understood, the detect code in U-boot works as expected. It would be too strange if fuse values of device are wrong.
Best regards.
3,454件の閲覧回数
yoooh8668
There are 4 piece of this sample(rev.beta) , all of them show the same result.
The branch is v2023.04_6.1.55_2.2.0 with our commits on it.
And there is no modifies on `arch/arm/mach-imx/imx9/soc.c` .
Maybe only the mass production can support this function(reg)?
Thanks~~
3,355件の閲覧回数
JorgeCas
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-1850650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5Bi.MX93%5D%20%E6%B8%A9%E5%BA%A6%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1850650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3Eimx93(rev.beta)%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E6%9C%AC%E6%9D%A5%E3%81%82%E3%82%8B%E3%81%B9%E3%81%8D%E6%B8%A9%E5%BA%A6%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%94%BB%E5%83%8F%E3%81%A8%E3%81%9D%E3%81%AEuboot%E3%83%AD%E3%82%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AC%E3%83%B4%E3%83%99%E3%83%BC%E3%82%BF%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EU-Boot%202023.04-00263-g7c7dd0dc2b0%20(Apr%2019%202024%20-%2015%3A50%3A35%20%2B0800)%0A%0ACPU%3A%20%20%20i.MX93(52)%20rev1.0%201700%20MHz%20(running%20at%201692%20MHz)%0ACPU%3A%20%20%20Consumer%20temperature%20grade%20(0C%20to%2095C)%20at%2051C%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.jpeg%22%20style%3D%22width%3A%20854px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.jpeg%22%20style%3D%22width%3A%20854px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F274713i9AA5073EE3F166CE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.jpeg%22%20alt%3D%221.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EREV.GA%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EU-Boot%202023.04-00263-g7c7dd0dc2b0%20(Apr%2019%202024%20-%2015%3A50%3A35%20%2B0800)%0A%0ACPU%3A%20%20%20i.MX93(52)%20rev1.1%201700%20MHz%20(running%20at%201692%20MHz)%0ACPU%3A%20%20%20Consumer%20temperature%20grade%20(0C%20to%2095C)%20at%2035C%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.jpeg%22%20style%3D%22width%3A%20842px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.jpeg%22%20style%3D%22width%3A%20842px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F274714i52EDEB28EB7F7BC4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.jpeg%22%20alt%3D%222.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E5%8F%82%E8%80%83%E5%9B%B3%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222023-11-08_13-58-59_%E7%9A%84%E8%9E%A2%E5%B9%95%E6%93%B7%E5%9C%96.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222023-11-08_13-58-59_%E7%9A%84%E8%9E%A2%E5%B9%95%E6%93%B7%E5%9C%96.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F274704iDD772A264F167497%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222023-11-08_13-58-59_%E7%9A%84%E8%9E%A2%E5%B9%95%E6%93%B7%E5%9C%96.png%22%20alt%3D%222023-11-08_13-58-59_%E7%9A%84%E8%9E%A2%E5%B9%95%E6%93%B7%E5%9C%96.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3Euboot%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%2Farch%2Farm%2Fmach-imx%2Fimx9%2Fsoc.c%0Au32%20get_cpu_temp_grade(int%20*minc%2C%20int%20*maxc)%0A%7B%0A%20%20%20%20%20%20%20%20int%20ret%3B%0A%20%20%20%20%20%20%20%20u32%20val%3B%0A%20%20%20%20%20%20%20%20ret%20%3D%20fuse_read(2%2C%203%2C%20%26amp%3Bval)%3B%0A%20%20%20%20%20%20%20%20if%20(ret)%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20val%20%3D%200%3B%20%2F*%20If%20read%20fuse%20failed%2C%20return%20as%20blank%20fuse%20*%2F%0A%0A%20%20%20%20%20%20%20%20val%20%26gt%3B%26gt%3B%3D%204%3B%0A%20%20%20%20%20%20%20%20val%20%26amp%3B%3D%200x3%3B%0A%0A%20%20%20%20%20%20%20%20if%20(minc%20%26amp%3B%26amp%3B%20maxc)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20if%20(val%20%3D%3D%20TEMP_AUTOMOTIVE)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*minc%20%3D%20-40%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*maxc%20%3D%20125%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%20else%20if%20(val%20%3D%3D%20TEMP_INDUSTRIAL)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*minc%20%3D%20-40%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*maxc%20%3D%20105%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%20else%20if%20(val%20%3D%3D%20TEMP_EXTCOMMERCIAL)%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20if%20(is_imx93())%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20imx93%20only%20has%20extended%20industrial*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*minc%20%3D%20-40%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*maxc%20%3D%20125%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%20else%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*minc%20%3D%20-20%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*maxc%20%3D%20105%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%20else%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*minc%20%3D%200%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*maxc%20%3D%2095%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%20%20%20%20return%20val%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%AC%9D~~%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1851789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%5Bi.MX93%5D%E6%B8%A9%E5%BA%A6%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1851789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EA0%20%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%9C%80%E5%BE%8C%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%E3%80%81Linux%206.1.22_2.0.0%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AEEVK%E3%81%A7%E3%81%9D%E3%81%AE%E5%8B%95%E4%BD%9C%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%97%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%9B%E3%83%AB%E3%83%80%E3%83%BC%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%80%81%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E5%AE%9F%E7%A8%BC%E5%83%8D%E5%89%8D%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1850976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%5Bi.MX93%5D%E6%B8%A9%E5%BA%A6%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1850976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%9D%E3%81%86%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%AD%A3%E5%BC%8F%E3%81%AA%E8%BF%94%E4%BA%8B%E3%82%92%E5%BE%85%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1850975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%5Bi.MX93%5D%E6%B8%A9%E5%BA%A6%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1850975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AF4%E5%80%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99(rev.beta)%E3%81%A7%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E5%90%8C%E3%81%98%E7%B5%90%E6%9E%9C%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AF%20v2023.04_6.1.55_2.2.0%20%E3%81%A7%E3%80%81%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81%20'arch%2Farm%2Fmach-imx%2Fimx9%2Fsoc.c'%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9F%E3%81%B6%E3%82%93%E3%80%81%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD(reg)%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%AF%E5%A4%A7%E9%87%8F%E7%94%9F%E7%94%A3%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E6%84%9F%E8%AC%9D~~%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1850968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%5Bi.MX93%5D%E6%B8%A9%E5%BA%A6%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1850968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%86%99%E7%9C%9F%E3%81%A7%E3%81%AF%E3%80%81Q(Qualification%20leve)%E3%81%AF%E3%80%8CP%E3%80%8D%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%82%E3%81%97%E3%81%8B%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%82%E3%81%8F%E3%81%BE%E3%81%A7%E3%82%82%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%E5%A4%A7%E9%87%8F%E7%94%9F%E7%94%A3%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1850851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%5Bi.MX93%5D%E6%B8%A9%E5%BA%A6%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1850851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3E%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%E3%81%8C%E5%B7%A5%E6%A5%AD%E7%94%A8%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%A5%87%E5%A6%99%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E4%BB%96%E3%81%AEREV.beta%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%82%82%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%8C%E7%90%86%E8%A7%A3%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8B%E3%82%89%E3%80%81U-boot%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E5%80%A4%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8A%E3%81%8B%E3%81%97%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
