i.MX93/PCA9451 Power Control Using Slide Switch
tkato
I am designing a custom board using i.MX93 and PCA9451. On the EVK, I noticed that the ONOFF pin is connected to a push button for power control.
In my design, I would like to use a slide switch instead of a push button for power control. Could you provide any design examples for this approach, or explain how it should be implemented?
Here is my current idea:
  • Pull up the ONOFF pin of i.MX93 to the power rail.
  • Leave the PMIC_ON_REQ output of i.MX93 floating, and connect the slide switch to the PMIC_ON_REQ input of PCA9451.
  • Connect the PMIC_STBY_REQ output of i.MX93 to PCA9451.
Any guidance or recommendations would be greatly appreciated.
Thank you for your support.
tkato
Rita_Wang
This is not recommended, ONOFF pin has many function which is not on PMIC_ON_REQ pin, for example, 5s mandatory power-off, power-off interruption and so on.
anyway you can use PMIC_ON_REQ pin to implement simple power-up and power-down as you design.
Any questions contact us freely.
Rita_Wang
Sorry for miss your thread, I will confirm it for you and will give you reply tomorrow.
%3CLINGO-SUB%20id%3D%22lingo-sub-2255035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX93%2FPCA9451%20Power%20Control%20Using%20Slide%20Switch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20am%20designing%20a%20custom%20board%20using%20%3CSTRONG%3Ei.MX93%3C%2FSTRONG%3E%20and%20%3CSTRONG%3EPCA9451%3C%2FSTRONG%3E.%20On%20the%20EVK%2C%20I%20noticed%20that%20the%20ONOFF%20pin%20is%20connected%20to%20a%20push%20button%20for%20power%20control.%3CBR%20%2F%3EIn%20my%20design%2C%20I%20would%20like%20to%20use%20a%20%3CSTRONG%3Eslide%20switch%3C%2FSTRONG%3E%20instead%20of%20a%20push%20button%20for%20power%20control.%20Could%20you%20provide%20any%20design%20examples%20for%20this%20approach%2C%20or%20explain%20how%20it%20should%20be%20implemented%3F%3C%2FP%3E%3CP%3EHere%20is%20my%20current%20idea%3A%3C%2FP%3E%3CUL%3E%3CLI%3EPull%20up%20the%20%3CSTRONG%3EONOFF%3C%2FSTRONG%3E%20pin%20of%20i.MX93%20to%20the%20power%20rail.%3C%2FLI%3E%3CLI%3ELeave%20the%20%3CSTRONG%3EPMIC_ON_REQ%3C%2FSTRONG%3E%20output%20of%20i.MX93%20floating%2C%20and%20connect%20the%20slide%20switch%20to%20the%20%3CSTRONG%3EPMIC_ON_REQ%3C%2FSTRONG%3E%20input%20of%20PCA9451.%3C%2FLI%3E%3CLI%3EConnect%20the%20%3CSTRONG%3EPMIC_STBY_REQ%3C%2FSTRONG%3E%20output%20of%20i.MX93%20to%20PCA9451.%3C%2FLI%3E%3C%2FUL%3E%3CP%3EAny%20guidance%20or%20recommendations%20would%20be%20greatly%20appreciated.%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20support.%3C%2FP%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3Etkato%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%2FPCA9451%20Power%20Control%20Using%20Slide%20Switch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESorry%20for%20miss%20your%20thread%2C%20I%20will%20confirm%20it%20for%20you%20and%20will%20give%20you%20reply%20tomorrow.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%2FPCA9451%20Power%20Control%20Using%20Slide%20Switch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20is%20not%20recommended%2C%20ONOFF%20pin%20has%20many%20function%20which%20is%20not%20on%20PMIC_ON_REQ%20pin%2C%20for%20example%2C%205s%20mandatory%20power-off%2C%20power-off%20interruption%20and%20so%20on.%3C%2FP%3E%0A%3CP%3Eanyway%20you%20can%20use%26nbsp%3BPMIC_ON_REQ%20pin%20to%20implement%20simple%20power-up%20and%20power-down%20as%20you%20design.%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EAny%20questions%20contact%20us%20freely.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
