i.MX93 M33 lpi2c Master not function
ソリューションへジャンプ
3,127件の閲覧回数
nyc
I’m running the lpi2c_interrupt_b2b_transfer_master_cm33 example on the MCIMX93-EVK.
After calling LPI2C_MasterTransferNonBlocking(), the SDA line stays low, and the SCL line keeps clocking continuously.
The clock only stops after I externally pull the SCL pin low, and then SDA goes high again.
Has anyone seen this behavior before or know what might cause it? Any suggestions would be greatly appreciated. Thank you!
タグ(2)
2,556件の閲覧回数
Manuel_Salas
Hello @nyc
I hope you are doing very well.
I could not replicate the issue.
The only difference that I did in my environment is putting the SION bit to 1U for SDA and SCL:
IOMUXC_SetPinMux(IOMUXC_PAD_I2C1_SCL__LPI2C1_SCL, 1U);
IOMUXC_SetPinMux(IOMUXC_PAD_I2C1_SDA__LPI2C1_SDA, 1U);
Salas.
11 返答(返信)
3,051件の閲覧回数
Manuel_Salas
Hello @nyc
Could you please share the SDK version that you are using?
I want to replicate by my side.
Salas.
2,971件の閲覧回数
nyc
Hi@Manuel_Salas please help me~
2,952件の閲覧回数
Manuel_Salas
Hello @nyc
I tested the same by my side but I had not issues. I connected two i.MX93, one as Master and one as Slave.
I could not replicate your issue.
Is there any step I am missing to replicate your issue?
I am aligned with the same environment and same example:
/SDK_25_09_00_MCIMX93-EVK/boards/mcimx93evk/driver_examples/lpi2c/interrupt_b2b_transfer/master$
Bet regards,
Salas.
2,949件の閲覧回数
nyc
@Manuel_Salas
Could you test the i2c master without connecting to slave?
I've tested this case with FLEXIO I2c, it would product 8 clock and didn't ack then end the transfer, but the native i2c have the problem.
2,928件の閲覧回数
nyc
I've changed to using i2c2
IOMUXC_SetPinMux(IOMUXC_PAD_I2C2_SDA__LPI2C2_SDA, 0U);
IOMUXC_SetPinConfig(IOMUXC_PAD_I2C2_SDA__LPI2C2_SDA,
IOMUXC_PAD_DSE(15U) |
IOMUXC_PAD_FSEL1(2U) |
IOMUXC_PAD_PU_MASK |
IOMUXC_PAD_OD_MASK);
IOMUXC_SetPinMux(IOMUXC_PAD_I2C2_SCL__LPI2C2_SCL, 0U);
IOMUXC_SetPinConfig(IOMUXC_PAD_I2C2_SCL__LPI2C2_SCL,
2,832件の閲覧回数
Manuel_Salas
Hello @nyc
Is now working with I2C2?
Or having the same issue?
Salas.
2,806件の閲覧回数
nyc
@Manuel_Salas
still can't work with LPI2C_MasterTransferNonBlocking(),
only can work with FLEXIO I2C or I2C Polling
2,557件の閲覧回数
Manuel_Salas
Hello @nyc
Salas.
2,942件の閲覧回数
nyc
correction: *it would product 9 clock
3,008件の閲覧回数
nyc
version:25.09.00
boardId:mcimx93evk
deviceId:MIMX9352xxxxM
coreId:cm33_MIMX9352xxxxM
3,073件の閲覧回数
nyc
Anybody can help?
%3CLINGO-SUB%20id%3D%22lingo-sub-2317739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX93%20M33%20lpi2c%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMCIMX93-EVK%20%E3%81%A7%20lpi2c_interrupt_b2b_transfer_master_cm33%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ELPI2C_MasterTransferNonBlocking()%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81SDA%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E4%BD%8E%E3%81%84%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81SCL%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E7%B6%9A%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AF%E3%80%81SCL%20%E3%83%94%E3%83%B3%E3%82%92%E5%A4%96%E9%83%A8%E7%9A%84%E3%81%AB%E3%83%AD%E3%83%BC%E3%81%AB%E5%BC%95%E3%81%8D%E4%B8%8B%E3%81%92%E3%81%9F%E5%BE%8C%E3%81%AB%E3%81%AE%E3%81%BF%E5%81%9C%E6%AD%A2%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%20SDA%20%E3%81%8C%E5%86%8D%E3%81%B3%E3%83%8F%E3%82%A4%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AB%E3%81%93%E3%81%AE%E5%8B%95%E4%BD%9C%E3%82%92%E8%A6%8B%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8B%E4%BA%BA%E3%82%84%E3%80%81%E3%81%9D%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%94%E6%8F%90%E6%A1%88%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9C%E3%81%B2%E3%81%8A%E8%81%9E%E3%81%8B%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376778i90C986AAF3B51A05%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nyc_0-1770976750816.png%22%20alt%3D%22nyc_0-1770976750816.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A25.09.00%3CBR%20%2F%3E%E3%83%9C%E3%83%BC%E3%83%89ID%3Amcimx93evk%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%3AMIMX9352xxxxM%3CBR%20%2F%3E%E3%82%B3%E3%82%A2ID%3Acm33_MIMX9352xxxxM%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%9C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2318387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%81%8A%E6%89%8B%E4%BC%9D%E3%81%84%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2318779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258495%22%20target%3D%22_blank%22%3E%40nyc%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%85%83%E6%B0%97%E3%81%A7%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20SDK%20%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AE%E3%81%9D%E3%81%B0%E3%81%A7%E5%86%8D%E7%8F%BE%E3%81%97%E3%81%9F%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%E3%83%9E%E3%83%8C%E3%82%A8%E3%83%AB%E3%83%BB%E3%82%B5%E3%83%A9%E3%82%B9%3C%2FA%3E%3CBR%20%2F%3E%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%9B%E3%81%9A%E3%81%AB%20i2c%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%82%92%20FLEXIO%20I2c%20%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%818%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%80%81ACK%20%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%9A%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%20i2c%20%E3%81%AB%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322833%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322833%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258495%22%20target%3D%22_blank%22%3E%40nyc%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%822%20%E5%8F%B0%E3%81%AE%20i.MX93%20%E3%82%92%E3%80%811%20%E5%8F%B0%E3%82%92%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%82%E3%81%86%201%20%E5%8F%B0%E3%82%92%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%A8%E3%81%97%E3%81%A6%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E7%A7%81%E3%81%8C%E8%A6%8B%E9%80%83%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%E5%90%8C%E3%81%98%E7%92%B0%E5%A2%83%E3%81%A8%E5%90%8C%E3%81%98%E4%BE%8B%E3%81%AB%E6%B2%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%2FSDK_25_09_00_MCIMX93-EVK%2Fboards%2Fmcimx93evk%2Fdriver_examples%2Flpi2c%2Finterrupt_b2b_transfer%2Fmaster%24%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2323699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2323699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%A8%82%E6%AD%A3%EF%BC%9A*9%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E8%A3%BD%E5%93%81%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2324180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei2c2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EIOMUXC_SetPinMux(IOMUXC_PAD_I2C2_SDA__LPI2C2_SDA%2C%200U)%3B%3CBR%20%2F%3E%20IOMUXC_SetPinConfig(IOMUXC_PAD_I2C2_SDA__LPI2C2_SDA%2C%3CBR%20%2F%3E%20IOMUXC_PAD_DSE(15U)%20%7C%3CBR%20%2F%3E%20IOMUXC_PAD_FSEL1(2U)%20%7C%3CBR%20%2F%3E%20IOMUXC_PAD_PU_%E3%83%9E%E3%82%B9%E3%82%AF%20%7C%3CBR%20%2F%3E%20IOMUXC_PAD_OD_MASK)%3B%3CBR%20%2F%3E%20IOMUXC_SetPinMux(IOMUXC_PAD_I2C2_SCL__LPI2C2_SCL%E3%80%810U)%3B%3CBR%20%2F%3E%20IOMUXC_SetPinConfig(IOMUXC_PAD_I2C2_SCL__LPI2C2_SCL%E3%80%81%3CBR%20%2F%3E%20IOMUXC_PAD_DSE(15U)%20%7C%3CBR%20%2F%3E%20IOMUXC_PAD_FSEL1(2U)%20%7C%3CBR%20%2F%3E%20IOMUXC_PAD_PU_%E3%83%9E%E3%82%B9%E3%82%AF%20%7C%3CBR%20%2F%3E%20IOMUXC_PAD_OD_MASK)%3B%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%E3%83%9E%E3%83%8C%E3%82%A8%E3%83%AB%E3%83%BB%E3%82%B5%E3%83%A9%E3%82%B9%3C%2FA%3E%3CBR%20%2F%3ELPI2C_MasterTransferNonBlocking()%20%E3%81%AF%E3%81%BE%E3%81%A0%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%20FLEXIO%20I2C%E3%81%BE%E3%81%9F%E3%81%AFI2C%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%A7%E3%81%AE%E3%81%BF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258495%22%20target%3D%22_blank%22%3E%40nyc%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AFI2C2%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2329267%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2329267%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258495%22%20target%3D%22_blank%22%3E%40nyc%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%85%83%E6%B0%97%E3%81%A7%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%A7%E8%A1%8C%E3%81%A3%E3%81%9F%E5%94%AF%E4%B8%80%E3%81%AE%E9%81%95%E3%81%84%E3%81%AF%E3%80%81SDA%20%E3%81%A8%20SCL%20%E3%81%AE%20SION%20%E3%83%93%E3%83%83%E3%83%88%E3%82%92%201U%20%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%3CSPAN%3EIOMUXC_SetPinMux%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EIOMUXC_PAD_I2C1_SCL__LPI2C1_SCL%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSTRONG%3E1U%3C%2FSTRONG%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%3E%3CSPAN%3EIOMUXC_SetPinMux%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EIOMUXC_PAD_I2C1_SDA__LPI2C1_SDA%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSTRONG%3E1U%3C%2FSTRONG%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
