i.MX93 M33 lpi2c Master not function
nyc
I’m running the lpi2c_interrupt_b2b_transfer_master_cm33 example on the MCIMX93-EVK.
After calling LPI2C_MasterTransferNonBlocking(), the SDA line stays low, and the SCL line keeps clocking continuously.
The clock only stops after I externally pull the SCL pin low, and then SDA goes high again.
Has anyone seen this behavior before or know what might cause it? Any suggestions would be greatly appreciated. Thank you!
Tags (2)
Manuel_Salas
Hello @nyc
I hope you are doing very well.
I could not replicate the issue.
The only difference that I did in my environment is putting the SION bit to 1U for SDA and SCL:
IOMUXC_SetPinMux(IOMUXC_PAD_I2C1_SCL__LPI2C1_SCL, 1U);
IOMUXC_SetPinMux(IOMUXC_PAD_I2C1_SDA__LPI2C1_SDA, 1U);
Salas.
Manuel_Salas
Hello @nyc
Could you please share the SDK version that you are using?
I want to replicate by my side.
Salas.
nyc
Hi@Manuel_Salas please help me~
Manuel_Salas
Hello @nyc
I tested the same by my side but I had not issues. I connected two i.MX93, one as Master and one as Slave.
I could not replicate your issue.
Is there any step I am missing to replicate your issue?
I am aligned with the same environment and same example:
/SDK_25_09_00_MCIMX93-EVK/boards/mcimx93evk/driver_examples/lpi2c/interrupt_b2b_transfer/master$
Bet regards,
Salas.
nyc
@Manuel_Salas
Could you test the i2c master without connecting to slave?
I've tested this case with FLEXIO I2c, it would product 8 clock and didn't ack then end the transfer, but the native i2c have the problem.
nyc
I've changed to using i2c2
IOMUXC_SetPinMux(IOMUXC_PAD_I2C2_SDA__LPI2C2_SDA, 0U);
IOMUXC_SetPinConfig(IOMUXC_PAD_I2C2_SDA__LPI2C2_SDA,
IOMUXC_PAD_DSE(15U) |
IOMUXC_PAD_FSEL1(2U) |
IOMUXC_PAD_PU_MASK |
IOMUXC_PAD_OD_MASK);
IOMUXC_SetPinMux(IOMUXC_PAD_I2C2_SCL__LPI2C2_SCL, 0U);
IOMUXC_SetPinConfig(IOMUXC_PAD_I2C2_SCL__LPI2C2_SCL,
Manuel_Salas
Hello @nyc
Is now working with I2C2?
Or having the same issue?
Salas.
nyc
@Manuel_Salas
still can't work with LPI2C_MasterTransferNonBlocking(),
only can work with FLEXIO I2C or I2C Polling
Manuel_Salas
Hello @nyc
Salas.
nyc
correction: *it would product 9 clock
nyc
version:25.09.00
boardId:mcimx93evk
deviceId:MIMX9352xxxxM
coreId:cm33_MIMX9352xxxxM
nyc
Anybody can help?
%3CLINGO-SUB%20id%3D%22lingo-sub-2317739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%E2%80%99m%20running%20the%20lpi2c_interrupt_b2b_transfer_master_cm33%20example%20on%20the%20MCIMX93-EVK.%3CBR%20%2F%3E%3CBR%20%2F%3EAfter%20calling%20LPI2C_MasterTransferNonBlocking()%2C%20the%20SDA%20line%20stays%20low%2C%20and%20the%20SCL%20line%20keeps%20clocking%20continuously.%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20clock%20only%20stops%20after%20I%20externally%20pull%20the%20SCL%20pin%20low%2C%20and%20then%20SDA%20goes%20high%20again.%3CBR%20%2F%3E%3CBR%20%2F%3EHas%20anyone%20seen%20this%20behavior%20before%20or%20know%20what%20might%20cause%20it%3F%20Any%20suggestions%20would%20be%20greatly%20appreciated.%20Thank%20you!%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nyc_0-1770976750816.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376778i90C986AAF3B51A05%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nyc_0-1770976750816.png%22%20alt%3D%22nyc_0-1770976750816.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3Eversion%3A25.09.00%3CBR%20%2F%3EboardId%3Amcimx93evk%3CBR%20%2F%3EdeviceId%3AMIMX9352xxxxM%3CBR%20%2F%3EcoreId%3Acm33_MIMX9352xxxxM%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%3C%2FA%3E%26nbsp%3Bplease%20help%20me~%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2318779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258495%22%20target%3D%22_blank%22%3E%40nyc%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20hope%20you%20are%20doing%20very%20well.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ECould%20you%20please%20share%20the%20SDK%20version%20that%20you%20are%20using%3F%3C%2FP%3E%0A%3CP%3EI%20want%20to%20replicate%20by%20my%20side.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2318387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAnybody%20can%20help%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3ECould%20you%20test%20the%20i2c%20master%20without%20connecting%20to%20slave%3F%3CBR%20%2F%3EI've%20tested%20this%20case%20with%20FLEXIO%20I2c%2C%20it%20would%20product%208%20clock%20and%20didn't%20ack%20then%20end%20the%20transfer%2C%20but%20the%20native%20i2c%20have%20the%20problem.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322833%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322833%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258495%22%20target%3D%22_blank%22%3E%40nyc%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20tested%20the%20same%20by%20my%20side%20but%20I%20had%20not%20issues.%20I%20connected%20two%20i.MX93%2C%20one%20as%20Master%20and%20one%20as%20Slave.%3C%2FP%3E%0A%3CP%3EI%20could%20not%20replicate%20your%20issue.%3C%2FP%3E%0A%3CP%3EIs%20there%20any%20step%20I%20am%20missing%20to%20replicate%20your%20issue%3F%3C%2FP%3E%0A%3CP%3EI%20am%20aligned%20with%20the%20same%20environment%20and%20same%20example%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%2FSDK_25_09_00_MCIMX93-EVK%2Fboards%2Fmcimx93evk%2Fdriver_examples%2Flpi2c%2Finterrupt_b2b_transfer%2Fmaster%24%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBet%20regards%2C%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2323699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2323699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ecorrection%3A%20*it%20would%20product%209%20clock%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2324180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI've%20changed%20to%20using%20i2c2%3CBR%20%2F%3EIOMUXC_SetPinMux(IOMUXC_PAD_I2C2_SDA__LPI2C2_SDA%2C%200U)%3B%3CBR%20%2F%3EIOMUXC_SetPinConfig(IOMUXC_PAD_I2C2_SDA__LPI2C2_SDA%2C%3CBR%20%2F%3EIOMUXC_PAD_DSE(15U)%20%7C%3CBR%20%2F%3EIOMUXC_PAD_FSEL1(2U)%20%7C%3CBR%20%2F%3EIOMUXC_PAD_PU_MASK%20%7C%3CBR%20%2F%3EIOMUXC_PAD_OD_MASK)%3B%3CBR%20%2F%3EIOMUXC_SetPinMux(IOMUXC_PAD_I2C2_SCL__LPI2C2_SCL%2C%200U)%3B%3CBR%20%2F%3EIOMUXC_SetPinConfig(IOMUXC_PAD_I2C2_SCL__LPI2C2_SCL%2C%3CBR%20%2F%3EIOMUXC_PAD_DSE(15U)%20%7C%3CBR%20%2F%3EIOMUXC_PAD_FSEL1(2U)%20%7C%3CBR%20%2F%3EIOMUXC_PAD_PU_MASK%20%7C%3CBR%20%2F%3EIOMUXC_PAD_OD_MASK)%3B%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258495%22%20target%3D%22_blank%22%3E%40nyc%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIs%20now%20working%20with%20I2C2%3F%3C%2FP%3E%0A%3CP%3EOr%20having%20the%20same%20issue%3F%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%3C%2FA%3E%3CBR%20%2F%3Estill%20can't%20work%20with%20LPI2C_MasterTransferNonBlocking()%2C%3CBR%20%2F%3Eonly%20can%20work%20with%20FLEXIO%20I2C%20or%20I2C%20Polling%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2329267%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX93%20M33%20lpi2c%20Master%20not%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2329267%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258495%22%20target%3D%22_blank%22%3E%40nyc%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20hope%20you%20are%20doing%20very%20well.%3C%2FP%3E%0A%3CP%3EI%20could%20not%20replicate%20the%20issue.%3C%2FP%3E%0A%3CP%3EThe%20only%20difference%20that%20I%20did%20in%20my%20environment%20is%20putting%20the%20SION%20bit%20to%201U%20for%20SDA%20and%20SCL%3A%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%3CSPAN%3EIOMUXC_SetPinMux%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PAD_I2C1_SCL__LPI2C1_SCL%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSTRONG%3E1U%3C%2FSTRONG%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%3E%3CSPAN%3EIOMUXC_SetPinMux%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PAD_I2C1_SDA__LPI2C1_SDA%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSTRONG%3E1U%3C%2FSTRONG%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBest%20regards%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ESalas.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
