i.MX8X LVDS output
i.MX8X LVDS output
2,303 次查看
Kazuma_Sasaki
Senior Contributor I
I would like to output BT.656 format data from LVDS interface.
it is need progressive to interlace conversion into SoC.
I found following description from reference manual. So, LCDIF is able to convert progressive to interlace format.
But, I could not find any description same feature into section of LVDS subsystem. and, We can not use LCDIF due to pin assignment.
I have two questions.
Q1. Can i.MX8X series convert  data format progressive to interlace via LVDS subsystem?
Q2. Is there any way to convert data format progressive to interlace without LCDIF?
From IMX8DQXPRM Rev. D, 11/2018
Thank you in advance for your support.
Kazuma Sasaki.
2,076 次查看
Hi Kazuma
sorry. I am afraid it is not possible to
convert progressive to interlace via ISI module.
4 回复数
2,076 次查看
Hi Kazuma
no
it can be done via ISI module, described in sect.15.6.1 Image Sensing Interface (ISI)
i.MX8QXP Reference Manual.
2,076 次查看
Kazuma_Sasaki
Hi Igor,
I appreciate your support. I have checked sect 15.6.1 Image Sensing Interface in reference manual.
I think that it can convert interlace to progressive (De-interlacing). But, We would like to  convert progressive to interlace.
If I missed your points, please teach me how to convert progressive to interlace via ISI module.
Kazuma Sasaki.
2,077 次查看
Hi Kazuma
2,076 次查看
Kazuma_Sasaki
Hi igor,
Thank you for your answer. I got it. I will consider other solution.
Kazuma Sasaki.
