I am Looking at i.MX8 Quad Max datasheet, Table 81, "LVDS Pins"
Footnote 1 states: In single channel operation the maximum clock speed is 160Mhz; in dual channel operation with single synchronized clock the maximum clock speed is 85Mhz.
Running under Linux, I can place the LVDS display in the mode where even Pixels are on Channel A and odd pixels are on Channel B and each Channel has its own clock that synchronizes the 4 data pairs for that channel.
My question:
How do I place the output in the "Dual Channel" mode described above where all 8 data pairs are synchronized to the same clock. And which clock is this? The Channel A clock or the Channel B clock?
Thanks for your help.
Hamid
